WHX?? 51,732 #7476 Posted November 4, 2020 Threw a Brinly hitch on the plow mule I got from Lowell at plow day. Had to saw the old hitch pin off. Easier than pulling all the weights off to get at with an impact hammer, sides I know a guy that makes them. 8 1 Share this post Link to post Share on other sites
JohnD 145 #7477 Posted November 5, 2020 Ya got a beautiful day for it! She's wearing some nice colors too! 1 Share this post Link to post Share on other sites
8ntruck 7,820 #7478 Posted November 5, 2020 I got the welder out this afternoon and made some progress on my de-thatcher attachment. Here is a picture of the 3rd fitting. Lift linkage and gage wheels, and some trimming for clearances yet to go. 3 3 Share this post Link to post Share on other sites
ebinmaine 72,556 #7479 Posted November 5, 2020 5 hours ago, 8ntruck said: I got the welder out this afternoon and made some progress on my de-thatcher attachment. Here is a picture of the 3rd fitting. Lift linkage and gage wheels, and some trimming for clearances yet to go. I like it. Of course with a new implement you can justify a new tractor purchase. 1 Share this post Link to post Share on other sites
953 nut 59,889 #7480 Posted November 5, 2020 2 hours ago, ebinmaine said: with a new implement you can justify a new tractor purchase. No justification needed, buy another and then figure out what it is for! 2 1 Share this post Link to post Share on other sites
Jhook 849 #7481 Posted November 5, 2020 First coat of rustoleum "hammered" paint applied to the wheel weights. Another coat today then will install this weekend. I really like the finish this paint gives. 9 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #7482 Posted November 5, 2020 After prepared, i primed the new Part... 5 Share this post Link to post Share on other sites
ebinmaine 72,556 #7483 Posted November 5, 2020 8 hours ago, Jhook said: I really like the finish this paint gives Me too.. Looks pretty cool. 1 Share this post Link to post Share on other sites
Pullstart 66,689 #7484 Posted November 6, 2020 6 hours ago, Tractorhead said: After prepared, i primed the new Part... what is it Stefan? Share this post Link to post Share on other sites
Pullstart 66,689 #7485 Posted November 6, 2020 While I wait for Senior parts... I spun around the heavy lugged tire from Uncle Jim. The were both “passenger side” tires. Ripped the tube, so I replaced the valve stem and pressured it up for monitoring. 2 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #7486 Posted November 6, 2020 2 hours ago, pullstart said: what is it Stefan? Last time i used the Sweeper to collect Leaf, i realized, i must interrupt very often to dump. When leaf is collected with the sweeper stuffed after it was mulched before the third of ammount can be collected until you must dump first time. I wanna keep my Mowerdeck as it is in Original Condition, but i see on my last mowing with the new Blades, And the removed sideshields, it is a hell of a Turbine on sideexchange. So my idea is to cover the rear and drain it just with 2 directed channels, where i will collect a Tube and send it into a Trailer, so i can ride a longer time and clean a bigger Areal, and have to dump maybe just once. not much interrupt’s on my Ride while dump, Seattime is important... it is just a Try but maybe it‘s working better than i believe of it ain‘t work at all an my idea is Stupid, however i will give it a Try. 4 1 Share this post Link to post Share on other sites
lynnmor 7,813 #7487 Posted November 6, 2020 2 hours ago, Tractorhead said: Last time i used the Sweeper to collect Leaf, i realized, i must interrupt very often to dump. When leaf is collected with the sweeper stuffed after it was mulched before the third of amount can be collected until you must dump first time. I use my rear discharge deck to mulch the leaves before the sweeper picks them up. Depending on the type of leaves or moisture content, it can get too heavy to unload and also damage the sweeper. 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #7488 Posted November 6, 2020 13 minutes ago, lynnmor said: I use my rear discharge deck to mulch the leaves before the sweeper picks them up. Depending on the type of leaves or moisture content, it can get too heavy to unload and also damage the sweeper. That was a Way i did normally before, means mulching before sweep. The Way i will go now, is use a easy flip- Trailer, where the dump go in. So it will be collected in the Trailer ( open to build) where dump was blown in. When that works so far, than i can easily dump on the Forrest at my allowed Dump port. Easy and simple doing with some Seattime on the Horse - it‘s a try, but we will see if and how it works. 3 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #7489 Posted November 6, 2020 Ouuuuch that hurts.... i should maybe next thing plan firstly on Pc in 3D ahead, how i did it with my FEL- Project. While i start to finish my Work i think to myself - huh something is Wrong, than i see the mistake . waaaahhhh - feel like an complete idiot because of that construction mistake. i didn‘t doublecheck the clearance to Rear tyres... Dang... Much too close, no hose will fit, the first thought was in the middle section, but than i thought it may be a better idea to go more to the outside edge i didn‘t doublecheck it. painful mistake 1 Share this post Link to post Share on other sites
ebinmaine 72,556 #7490 Posted November 6, 2020 35 minutes ago, Tractorhead said: Ouuuuch that hurts.... i should maybe next thing plan firstly on Pc in 3D ahead, how i did it with my FEL- Project. While i start to finish my Work i think to myself - huh something is Wrong, than i see the mistake . waaaahhhh - feel like an complete idiot because of that construction mistake. i didn‘t doublecheck the clearance to Rear tyres... Dang... Much too close, no hose will fit, the first thought was in the middle section, but than i thought it may be a better idea to go more to the outside edge i didn‘t doublecheck it. painful mistake No worries man. Grind and reweld. All good. 1 Share this post Link to post Share on other sites
WHX?? 51,732 #7491 Posted November 6, 2020 20 hours ago, pullstart said: While I wait for Senior parts... I spun around the heavy lugged tire from Uncle Jim. The were both “passenger side” tires. Ripped the tube, so I replaced the valve stem and pressured it up for monitoring. They really aren't that bad of a set one doesn't mind they are mismatched. Like you said Kev in the plow field ain't nobody gonna care long as they move the tractor. 1 Share this post Link to post Share on other sites
Jhook 849 #7492 Posted November 6, 2020 Wheel weights are finished, will be installed on the 315 tractor tomorrow. Got a coat of primer on the 62' hood and as you can see the rear fenders have been painted for a week or so now. They are sitting in the background. Will have hood painted tomorrow. Then have to pull the predator out and disassemble for a quick paint job while the weather is nice. 2 Share this post Link to post Share on other sites
WHNJ701 4,165 #7493 Posted November 7, 2020 I went through the magical box of spare briggs parts. I knew I had enough to build one spare engine but looks like I have enough to build 2. So I cleaned up and painted the parts universal gloss black. I know the one block needs rings, do that over winter. It's nice just have them just in case something engine less shows up. These are pre 1964 143302 and 143402 5 3/4hp. I have no tractor restorations this winter. I am planning the engine department all organized. 4 5 Share this post Link to post Share on other sites
953 nut 59,889 #7494 Posted November 7, 2020 On 11/6/2020 at 3:37 AM, Tractorhead said: means mulching before sweep I mulch and sweep at the same time, 42" rear discharge deck and a 42" lawn sweeper. 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #7495 Posted November 7, 2020 Seems i must do it that Way, until i have finalized my new Deck rearplate again. My biggest problem was that the Surface is extremely uneven, it differs sometimes to more as 8 cm on the brooms between touching the ground or be just in air with a lot of gap, so a successful work only with the broom’s from the Sweeper is nearly impossible on smaller things, a collecting only with the Sweeper is so on some areas heavy to realize, even while riding crosswise. I like the Seattime on my Horses no doubts, but i also want that the Work is done niceley after. The suction of the Deck with the changed Blades now is a Blast, i wanna use that winning effect for a easier Collecting. i think to rebuilt it again from Scratch, because it‘s just screwed and the Prototype was made of Aluminum, 3 mm thick. 2 Share this post Link to post Share on other sites
Jhook 849 #7496 Posted November 7, 2020 315 is looking good. Time to put the other wheel weight on. 3 3 Share this post Link to post Share on other sites
Jhook 849 #7497 Posted November 7, 2020 Also thru the worst set of front caps i have on the front. This ones a worker not a show piece so my nicer caps will stay in their boxes 1 Share this post Link to post Share on other sites
peter lena 9,251 #7498 Posted November 7, 2020 HERDER, noting your carbon issue , relates to significant ENGINE VARNISH ISSUES, coming from oil related contamination , EVER HERD OF RISLONE OIL TREATMENTS ? their products really work , using this zinc , has really transformed my 3 kohlers , https://www.amazon.com/Rislone-4405-Supplement-Concentrate-Treatment/dp/B0075559UY/ref=sr_1_1?dchild=1&gclid=CjwKCAiAqJn9BRB0EiwAJ1SztQtJiWn0BhPeNXbh3i0nqtbiMqS2DX06jw7k0Fv6xuv1d6vSujuXNRoCIEMQAvD_BwE&hvadid=323447289259&hvdev=c&hvlocphy=9003310&hvnetw=g&hvqmt=b&hvrand=12791173623736993426&hvtargid=kwd-301586437419&hydadcr=6364_9585392&keywords=rislone+oil&qid=1604765701&sr=8-1&tag=googhydr-20 , if you use it , you will shortly notice the oil going black , that's cleaning out varnish , and the engine running easier and smoother, leave it in till almost black , then hot drain it, and do it again , your engine also likes 30 wt rotella oil , and 5-30 over winter , pete 1 Share this post Link to post Share on other sites
Lee1977 7,194 #7499 Posted November 7, 2020 16 hours ago, ebinmaine said: No worries man. Grind and reweld. All good. Just cut it into at the center and weld it back with the holes in the center. 1 Share this post Link to post Share on other sites
KrazeyOlDave 860 #7500 Posted November 7, 2020 On 11/2/2020 at 3:32 PM, Herder said: Had time to de-carbon the cylinder, adjust the valves and gave her an oil change. No more taping and this little magnum runs like a top. I am starting to like this one. What is the torque specs for the head bolts? I have to do mine soon. Share this post Link to post Share on other sites
