ebinmaine 80,464 #7376 Posted October 29, 2020 2 hours ago, Achto said: Running a grader blade without hydraulics is thirsty work! Verification by BBT. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,464 #7377 Posted October 29, 2020 @Robert K that's a right slick looking set-up. I'm VERY impressed. If a taller bracket AND longer actuator were both put into play you could have a bit of slide space to give float and still be able to bottom out for down pressure. Gives me ideas this one does..... 2 Share this post Link to post Share on other sites
Robert K 37 #7378 Posted October 29, 2020 (edited) 22 minutes ago, ebinmaine said: @Robert K that's a right slick looking set-up. I'm VERY impressed. If a taller bracket AND longer actuator were both put into play you could have a bit of slide space to give float and still be able to bottom out for down pressure. Gives me ideas this one does..... Indeed. I will for sure be changing out to a 6" possibly even an 8". Had to make sure I built it for easy access in raising the hood. Not a lot of room between the blade and tractor. And thank you! Edited October 29, 2020 by Robert K 1 Share this post Link to post Share on other sites
ebinmaine 80,464 #7379 Posted October 29, 2020 15 minutes ago, Robert K said: . Had to make sure I built it for easy access in raising the hood. Not a lot of room between the blade and tractor. And thank you! On my big wheel tractor I'm going to mount the fuel tank out front. I'm getting around the hood tilt by putting a solid pin across the bottom of the hood. I'll unlatch the rear then lift whole thing straight up. On my snowplow horse I have oversized tires. I needed to move the plow assembly forward. I increased the clearance from blade to front tires by fabbing up plow brackets out of an old frame that moves the entire plow frame forward 2". 1 Share this post Link to post Share on other sites
OldWorkHorse 3,156 #7380 Posted October 29, 2020 Picked up a small in between projects project... 4 Share this post Link to post Share on other sites
ebinmaine 80,464 #7381 Posted October 29, 2020 20 minutes ago, OldWorkHorse said: Picked up a small in between projects project... That's the perfect size right there. 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #7382 Posted October 29, 2020 (edited) Fistly i smelled Fuel in the Shed and see while inspect few dribbs below the Horse. Know allready, that will happen, and after Today i was prepared. So i ordered allready a new Fuelline, but wait for changing because here is no longer plain Fuel available, so it was clear for me it is just a question of time, that i must change it, but i was prepared and change the Fuelline completely to a Bioethanol usable one.. Edited October 29, 2020 by Tractorhead 5 Share this post Link to post Share on other sites
Tractorhead 9,217 #7383 Posted October 29, 2020 (edited) Dang, i‘m today the idiot quick klicker...😎 The scratch Plow Frame... after i changed the Fuelline, i start continoue with the new Plow Frame i built. The idea was clear, the prep was parently done, so i cutted today the rungs. after checking double if all seems to fit i started the Welder. while Welding things together, i have an idea, wow to solve a Quickmount. The Baseframe Welded and rechecked, if all aligning Well. Thinkering on the front swing, test if it will work. While i testing, i get finally the idea how i like to solve the „quickmount“ what was on the „open todo“ list. The solution is as simple as nice. 2x 3/4“ Bolts will be set in 2 pipes, that they can be quick slided in for mount or slide out to remove. A Clamp will fix them when mounted. The pipes welded on... how the system works... on the Axles two mounts will be screwed on they get two holes (one on the left and one on the right) Mount position Release position.. Edited October 29, 2020 by Tractorhead 9 1 Share this post Link to post Share on other sites
pfrederi 21,097 #7385 Posted October 29, 2020 31 minutes ago, AMC RULES said: Enough already. Get a job spend time at work not doing the marvelous restoration work that makes the rest of us envious!!! 1 7 1 Share this post Link to post Share on other sites
WHX?? 57,923 #7387 Posted October 29, 2020 (edited) On 10/28/2020 at 3:27 PM, AMC RULES said: The way you got that shined up like a baby's bottom Madge you should go stainless exhaust pipe & fttings! Betcha Plunger has got a source! Edited October 29, 2020 by WHX24 2 Share this post Link to post Share on other sites
WHX?? 57,923 #7388 Posted October 29, 2020 (edited) 1 hour ago, pfrederi said: Enough already. Get a job spend time at work not doing the marvelous restoration work that makes the rest of us envious!!! That's what I'm sayin Paul.... me thinks W P gave him the heave ho! Evidentally he is a "non-essential" worker. If I was retired i wouldn't get that much done! Edited October 29, 2020 by WHX24 speeling 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #7389 Posted October 30, 2020 (edited) The combination of my use or lose annual leave in conjunction with this truncated Covid work schedule has me working 24 hr pay periods through the end of the year. So, damn the luck, what can I say guys? Terrible thing this pandemic is...geeze o man! Edited October 30, 2020 by AMC RULES 6 2 Share this post Link to post Share on other sites
19richie66 17,932 #7390 Posted October 30, 2020 M 21 minutes ago, AMC RULES said: The combination of my use or lose annual leave in conjunction with this truncated Covid work schedule has me working 24 hr pay periods through the end of the year. So, damn the luck, what can I say guys? Terrible thing this pandemic is...geeze o man! Must be absolutely horrible. But....... a man has to do what a man has to do. 2 1 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #7391 Posted October 30, 2020 TRULY is! 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #7392 Posted October 30, 2020 Just doin' my part for my fellow man! 3 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #7393 Posted October 30, 2020 Certainly not perfect yet, but well on it's way here today. 2 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #7394 Posted October 30, 2020 Yes it's far from finished, but I just had to see it now 5 3 Share this post Link to post Share on other sites
johnnymag3 2,646 #7395 Posted October 30, 2020 I heard through the grapevine you were going to do that exhaust in STAINLESS !!! Share this post Link to post Share on other sites
AMC RULES 37,259 #7396 Posted October 30, 2020 Madge doesn't call the shots here. 4 Share this post Link to post Share on other sites
johnnymag3 2,646 #7397 Posted October 30, 2020 It would be nice, dontcha think??? What a few extra bucks ? Share this post Link to post Share on other sites
lynnmor 9,026 #7398 Posted October 30, 2020 CHINA!!! Get that thing fired up to kill the viruses. 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #7399 Posted October 30, 2020 The owner is cheap, and is happy with what I'm giving him... but, now if you guys want to chip in a full custom stainless exhaust for this thing, I'm sure he would greatly appreciate it! 3 1 2 Share this post Link to post Share on other sites
Ed Kennell 47,119 #7400 Posted October 30, 2020 2 hours ago, AMC RULES said: A real nut roaster with the muffler tween your legs. 1 1 2 Share this post Link to post Share on other sites
