AMC RULES 37,250 #6476 Posted September 7, 2020 1K. Be sure you wear your mask! 1 Share this post Link to post Share on other sites
Jhook 849 #6477 Posted September 7, 2020 Messaged them and they said they fixed the issue, it was low on fluid. I doubt that but i will still offer the 1,000 and buy it if they accept Share this post Link to post Share on other sites
Tractorhead 9,215 #6478 Posted September 7, 2020 I would just buy it after an Testdrive with all hydraulic functions. If the hydo fluid was that low, that the rear only goes low i would check it closely for any leaks and hopefully it does not have any harder wear because of that issue. a hydraulic low on fluid can wear quick while sucking air. Without a testdrive or a demonstration of it, and the whole fuction i would max rate it at 600- 800$ hydraulic parts can be quickly very expensive to fix. the bucket can be fixed with a new Steelplate, that‘s not an complete KO criteria in my opinion. but you shall be able to fix it. just my 2 cents. 1 Share this post Link to post Share on other sites
johnnymag3 2,633 #6479 Posted September 7, 2020 My 2 cents say STEER CLEAR Of this deal....use your hard earned $ elsewhere 1 Share this post Link to post Share on other sites
johnnymag3 2,633 #6480 Posted September 7, 2020 Ok so I need help.....as always.,,,,, I tried to install a sleeve and a pulley on the 1257 Tractor. Otherwise known as 19. The other half of Covid, the 310-8. You may remember, I got both tractors in the 3rd week of March from the original owners.... anyways........Covid 19 Each one has a name. What am I missing??? There is a space of about 3/8 of an inch between the clips,and the clutch disc. I put the PTO bearing sleeve on, and the clips are not even close....What gives? What am I missing, or what do I need...Seems awful weird....HELP WH scientists Share this post Link to post Share on other sites
Pullstart 68,518 #6482 Posted September 7, 2020 Johnny, it goes sleeve, Disc, then those tabs and bolts to hold it to the tapped ring. Will that take up the extra room? Share this post Link to post Share on other sites
johnnymag3 2,633 #6483 Posted September 7, 2020 Im going to give it a re assemble tomorrow....things were just out of sorts with this 301K...It plowed all its life, and never had a PTO on it.....Just a blade...since 1967....one guy one driveway oneowner Quote Share this post Link to post Share on other sites
johnnymag3 2,633 #6484 Posted September 7, 2020 This thing barks with the Magnaflow....its snaps to high heaven....wicked compression, good bones......My neighbors love it when I drop in the muffler to baffle the SNAP....But it barks like a Harley....They are more than 30 year neighbors, so They know where im coming from,,,,and I know my limits Share this post Link to post Share on other sites
johnnymag3 2,633 #6485 Posted September 7, 2020 Thanks PULLSTART................ My mind is not as sharp as it was 40 years ago 1 Share this post Link to post Share on other sites
adsm08 3,849 #6486 Posted September 7, 2020 Scored some new toys for the horsies today. ST-326 blower, seems to be complete except the chute adjustment cable, everything but the gauge wheels moves freely, $75. 42 inch deck, complete with mule drive and PTO belt, missing spindle belt and needs blades, $150. $225 out the door. 3 2 Share this post Link to post Share on other sites
Rp.wh 1,103 #6488 Posted September 7, 2020 Today I had to replace a carb on the old 702 and decided to put on the grader blade even though it isn’t finished and had to try it out and of course when I was done the kids wanted to go for a tub ride 9 3 1 1 Share this post Link to post Share on other sites
Greentored 3,220 #6489 Posted September 8, 2020 A couple neighborhood fellas and myself got a little silly over the holiday weekend and hooked Hoss up. Was a good test for the hopped up K321, pulling 7-8 full grown men, the table, plywood and frame up a couple steep neighborhood hills- was flawless. 2 3 3 2 Share this post Link to post Share on other sites
Redneckdavis 308 #6490 Posted September 8, 2020 Went to the pull Saturday. First place with the horse. I won a whole $15😀 . Anddddddd now I need an engine. 😞 Rod knocking badd. Also Compression check found 65psi in both cylinders. Gnna have to.rebuild or replace before next pull 2 1 2 Share this post Link to post Share on other sites
AMC RULES 37,250 #6491 Posted September 8, 2020 Seems that $15 is gonna come in right handy! 1 4 Share this post Link to post Share on other sites
AMC RULES 37,250 #6492 Posted September 8, 2020 Last night it took an impact hammer to drive the frozen hitch pin out of this old parts carcass... now, here today on the 854, thing is working smooth as silk. 2 3 Share this post Link to post Share on other sites
AMC RULES 37,250 #6493 Posted September 8, 2020 (edited) 7New set of sealed bearings on the front of this crusty old '57... 20200908_151029.mp4 figure it's gotta be good for at least another 63 years! Edited September 9, 2020 by AMC RULES 1 3 Share this post Link to post Share on other sites
Tractorhead 9,215 #6494 Posted September 8, 2020 Whow, they running great Craig. btw. Are all old Wheelhorses uses Bearings in the frontaxle? and if so, what Dimensions are they. i ask especially for my 656, but i‘m actually not that far but so i can allready oder a Set. Thanks in advance Share this post Link to post Share on other sites
johnnymag3 2,633 #6495 Posted September 8, 2020 I have sets of those bearings if you ever need one, or some Dimensions are all I need.....Thanks to the 90 year old gentleman I bought this collection from Share this post Link to post Share on other sites
Tractorhead 9,215 #6496 Posted September 8, 2020 4 minutes ago, johnnymag3 said: I have sets of those bearings if you ever need one, or some Dimensions are all I need.....Thanks to the 90 year old gentleman I bought this collection from That‘s my question, i dig not actually so deep into my horse, to know if there are Bearings on the Frontwheels or only sleeves. Share this post Link to post Share on other sites
johnnymag3 2,633 #6497 Posted September 8, 2020 Ive seen both.....Hard plastic, and bearings Share this post Link to post Share on other sites
johnnymag3 2,633 #6498 Posted September 8, 2020 Take off the front wheel and let us know....someone here has what you need Share this post Link to post Share on other sites
Tractorhead 9,215 #6499 Posted September 8, 2020 Is it possible to convert from plastics to bearings? Share this post Link to post Share on other sites
johnnymag3 2,633 #6500 Posted September 8, 2020 Yes, but you may have to use different rims Share this post Link to post Share on other sites
