ebinmaine 80,449 #4326 Posted April 4, 2020 1 hour ago, pullstart said: Hey everybody, look! It’s Trina doing the work again! Where’s EB? He's burnin rods... 1 2 1 Share this post Link to post Share on other sites
Stormin 9,988 #4327 Posted April 4, 2020 Ever since I rebuilt my Wheel Horse C-125's engine, I could never get it to run as I'd like it. Idling was the main issue. I've been working on it of and on, but just lately it's been hard to start. Today I decided to swap the carb for a reconditioned one I got off Richard. (Anglo Traction). Getting it going and warmed up, I played around with the mixture screws, until I got it running something like. Still wouldn't start like it should and I found the spark plug dry. It has a primer bulb fitted BTW and usually three squeezes and away it would go. I was having to juggle the throttle and choke till it would fire up. I'm going to try another pump. I also checked the points gap. That was ok. 18-19 thou. The starter motor had started sticking as well and seem a tad lazy. That was removed and I found the gears on the Benndix a bit worse for wear. Also the bearing on the Bedix end, has some play. Motor is now on the bench and if/when I can, I'll see if I can rebuild it. I had a spare starter motor somewhere. Now found and fitted. After fitting it I tried starting the engine. Usual thing. No change. Juggle! Jiggle! Ay up! What's that spark doing there? Where you ask? Engine end of the P.T.O. operating rod. Best check engine to chassis earth. Broken cable found. Tucked away at the back of the engine, below the starter motor. The eye on one end had broken off. New cable now fitted and also more accessible. That's as far as I got. Tomorrow I'll see how things go. If starting is not any better, I'll fit another pump and maybe check valve clearances. 6 Share this post Link to post Share on other sites
Pullstart 71,149 #4328 Posted April 4, 2020 17 minutes ago, ebinmaine said: He's burnin rods... WOO HOO! 1 Share this post Link to post Share on other sites
ebinmaine 80,449 #4329 Posted April 4, 2020 Just now, pullstart said: WOO HOO! Patience man. Patience. Share this post Link to post Share on other sites
Stormin 9,988 #4330 Posted April 4, 2020 3 hours ago, ebinmaine said: I think someone needs Trina to show him how to focus the camera. 2 1 5 Share this post Link to post Share on other sites
ebinmaine 80,449 #4331 Posted April 4, 2020 13 minutes ago, Stormin said: I think someone needs Trina to show him how to focus the camera. Best I could do on this smartphone. That was actually at long-distance magnified 8x Share this post Link to post Share on other sites
19richie66 17,932 #4332 Posted April 4, 2020 Practicing Social distancing. 3 6 2 Share this post Link to post Share on other sites
muz123 1,193 #4333 Posted April 4, 2020 Got the 36” Tiller on one 520, and the 60” on the other today. Also did some maintenance on the deck too. 6 1 1 Share this post Link to post Share on other sites
McGrew 461 #4334 Posted April 4, 2020 I had to have new septic tank drain lines installed..Oh joy! The contractor started yesterday morning, and my once relatively nice backyard is now a real mess. With 3 dogs, no grass, and lots of rain, it will be a mess for a while. I got the Raider 10/14 out and put the wheel weights and blade on it to smooth out some of the dirt after the contractor left. Pics tell the story: Danny 2 11 Share this post Link to post Share on other sites
WHX?? 57,879 #4335 Posted April 4, 2020 You always run around with gals on topless tractors Kev or the other way around!?! Looks like today I and a few others worked on our tractors instead of out joyriding .. I was with Muz on deck work for a special project tractor....shut up EB ....how one can operate without a POWER WASHER not mentioning names....ahemm.. is beyond me. 1 1 8 Share this post Link to post Share on other sites
rjg854 13,329 #4336 Posted April 4, 2020 So this morning I took the snow thrower off the 16 Automatic and hooked up the york rake and regraded the driveway. Tomorrow after it has a chance to dry out a bit I plan on using the grader blade and smooth it out a bit more. 6 10 Share this post Link to post Share on other sites
Pullstart 71,149 #4337 Posted April 5, 2020 What to do... what to do... 3 2 2 5 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #4338 Posted April 5, 2020 Ok,ok,ok—I think that we will try to pull some of the “steeds” out of hibernation and go for a tractor ride around the property. I’ll add that a fire pit bonfire will also be on our agenda for later today. Maybe a little catch and baseball this afternoon...🤔 this should be fun... 3 2 4 Share this post Link to post Share on other sites
pfrederi 21,091 #4339 Posted April 5, 2020 Put the 310-8 to work hauling repotted maples out to the field. I have an area protected with an electric fence to get small trees started with out being eaten..... These were seeds I planted last spring. Now I need the smaller pots for the 50 or so Acorns I got from my red oak last fall and kept in the refrigerator all winter. Thye are just about all sprouting. 9 4 2 2 Share this post Link to post Share on other sites
Stormin 9,988 #4340 Posted April 5, 2020 Well the valve clearances were ok. Also after lifting the head, I could see on inspection of the valve seats and valve heads, all was ok there. No sign of burn or damage. With the carb' being removed to check the valve clearances, I spun the engine to see how the fuel pump performed. A good spurt of fuel shot out at each revolution. So that was ok. Nailed everything back together and tried starting. Engine eventually fired up but was surging. Though on low rev's was smoother. Bit of trying different positions of the governor spring and then it hit me. Earlier I'd checked the governor arm position on the spindle. Guess what? When setting it yesterday, I'd turned the spindle the wrong way. Clockwise instead of anticlockwise. Rectified that and the surging decreased. Well it would' wouldn't it! Played around with the mixture settings, till eventually I was more or less happyish with things. Had a run around and all seemed well. Tomorrow I'll see how it starts again. I still think the original trouble was the original carb. My boo! boo! with the governor didn't help things. But as my father used to say, "The man who never made a mistake, never made anything". 5 2 2 Share this post Link to post Share on other sites
Stormin 9,988 #4341 Posted April 5, 2020 P.S And the broken earth wire. 1 Share this post Link to post Share on other sites
WHX?? 57,879 #4342 Posted April 5, 2020 6 hours ago, PeacemakerJack said: a fire pit bonfire will also be on our agenda for later today. Nay nay on the fire pit Jack.... DNR suspended all burning permits... 1 Share this post Link to post Share on other sites
ZXT 2,402 #4343 Posted April 5, 2020 10 minutes ago, WHX24 said: Nay nay on the fire pit Jack.... DNR suspended all burning permits... A permit to burn? What's that? I'll be cooking some weenies over a fire here in a bit. 1 Share this post Link to post Share on other sites
ebinmaine 80,449 #4344 Posted April 5, 2020 19 minutes ago, WHX24 said: Nay nay on the fire pit Jack.... DNR suspended all burning permits... 8 minutes ago, ZXT said: A permit to burn? What's that? I'll be cooking some weenies over a fire here in a bit. That's one good thing about Maine. A Small Contained fire on your own land is ALWAYS legal. Old state law. IIRC it's called a Warming fire. For heating food or people. 3 Share this post Link to post Share on other sites
WHX?? 57,879 #4345 Posted April 5, 2020 This time of year ZXT you have to have a burning permit for any type of outside fire....pits, trash barrels etc... The permits are free and you are supposed to go get one from someone in yer 'hood you gives them out. Jack and I are rural so have no idea who gives them out. Fire danger is high till green up but the powers that be worry about sending crews out because of the covids. I guess I can relate people around here do stupid things. 3 Share this post Link to post Share on other sites
Achto 32,449 #4346 Posted April 6, 2020 1 hour ago, WHX24 said: This time of year ZXT you have to have a burning permit for any type of outside fire....pits, trash barrels etc... The permits are free and you are supposed to go get one from someone in yer 'hood you gives them out. Jack and I are rural so have no idea who gives them out. Fire danger is high till green up but the powers that be worry about sending crews out because of the covids. I guess I can relate people around here do stupid things. There's a simple loop hole in that permit thing, They can not say anything about a cooking fire, so grab a package of hot dogs & light er up. 2 1 Share this post Link to post Share on other sites
WHX?? 57,879 #4347 Posted April 6, 2020 ... if yer burnin burgers it's just "discouraged" 2 Share this post Link to post Share on other sites
Chestnut 315 #4348 Posted April 6, 2020 10 hours ago, ebinmaine said: I didn't know about that Maine law. Had a burn pile last week in Maine. Fire chief told us to go online for a permit. Went online and got a 404 message. Seems that the website doesn't even open to take your $7 until 5PM, even though burns are allowed all day if it's raining or if there's snow cover. Decided to use the live free or die rules where permits aren't needed if raining or snow covered. Overnight snow had covered everything but was almost gone by the afternoon. That's one good thing about Maine. A Small Contained fire on your own land is ALWAYS legal. Old state law. IIRC it's called a Warming fire. For heating food or people. 1 Share this post Link to post Share on other sites
Stormin 9,988 #4349 Posted April 6, 2020 Well the C-125 started well this morning, so I'm a happy bunny. 3 2 2 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #4350 Posted April 6, 2020 After a variety of yard projects yesterday, got five tractors out of hibernation and played with the kids for awhile. Caleb had fun on Comanche. I think we need to do a refresh on his 56 year old motor. It smokes pretty good on startup but clears out decently after about 8-10 minutes of run time. Claudia drove “JackRabbit” (418-C) and loved the fact that she was so much faster than the old 854 that her older brother was driving. Not sure what Caleb was saying to her here but maybe something like, “just remember, that’s my tractor too!” The little guys ran around on Cubs while I was on GhostRider. It was a fun half hour or so!!!! 1 5 Share this post Link to post Share on other sites
