adsm08 5,012 #2701 Posted July 13, 2019 1 minute ago, ebinmaine said: There's your first piece Well I have one that I made but the coil end keeps coming uncrimped. I finished out with that one, it ran better but still poorly, which is why I think something else is up. I also was putting black smoke and managed to carbon foul a freshly cleaned plug in an hour. I had the carb adjusted to the lean side, so I'm going with incomplete/late combustion over rich running conditions. Share this post Link to post Share on other sites
ZXT 2,402 #2702 Posted July 13, 2019 (edited) 3 hours ago, adsm08 said: Mowed. It ran like crap again. Electrocuted myself trying to reach the carb from the driver's seat while it was running. Got the yard done, but I have to figure this out. Tomorrow I'm going to try and get a new plug wire, maybe a different coil, and check the timing. Rest in peace! Lol! The definition of electrocution is being killed by electrical shock. Yes, I had to be a smart-aleck. If it runs at all I can't see the coil or plug wire being the culprit. It's not lean if its puffing black smoke! Have you had the carb apart lately? Edited July 13, 2019 by ZXT 2 Share this post Link to post Share on other sites
adsm08 5,012 #2703 Posted July 13, 2019 4 hours ago, ZXT said: Rest in peace! Lol! The definition of electrocution is being killed by electrical shock. Yes, I had to be a smart-aleck. If it runs at all I can't see the coil or plug wire being the culprit. It's not lean if its puffing black smoke! Have you had the carb apart lately? Carb was torn down and fully cleaned, spent the night in an ultrasonic cleaner, right after I bought it at the beginning of the season. I have had issues from plug wires bleeding spark through worn insulation before, like my one seems to be doing. I've also had poor quality crimp ends cause running issues. It will let the engine run, but results in incomplete combustion, which I seem to have. 1 Share this post Link to post Share on other sites
ebinmaine 80,340 #2704 Posted July 13, 2019 5 hours ago, ZXT said: If it runs at all I can't see the ......plug wire being the culprit I've had car engines that would run AND give me a light show if you look under the hood in the dark 54 minutes ago, adsm08 said: issues from plug wires bleeding spark through worn insulation 1 Share this post Link to post Share on other sites
cafoose 3,817 #2705 Posted July 13, 2019 2 hours ago, ebinmaine said: I've had car engines that would run AND give me a light show if you look under the hood in the dark Me too once a car I had was giving problems under load so had someone put it in gear and hold the brake in the dark and I had a light show it got worse as I moved the throttle a little. As soon as I put it in park the light show stopped! I replaced the wires and problem solved 1 Share this post Link to post Share on other sites
wallfish 20,511 #2706 Posted July 13, 2019 to the plug wires. Had the same thing happen and the van would loose serious power under load because of bad plug wires. 1 Share this post Link to post Share on other sites
adsm08 5,012 #2707 Posted July 13, 2019 4 hours ago, ebinmaine said: I've had car engines that would run AND give me a light show if you look under the hood in the dark Many moons ago I bought a fresh rebuilt engine from a guy I worked with and dropped it in my truck. I didn't change out the plug wires on it when I got it because they were newer than the ones I had on the old engine, but right away it ran like crap, blew black smoke on heavy accel, and missed at idle. After a month I gave up on it and figured it would break for real eventually, and started messing with other stuff on it. One day I was laying over the fender adjusting a power steering hose while it was running and brushed the coil wire and got bit. Ran to the garage, grabbed the oil coil wire, and BAM, fixed. 3 Share this post Link to post Share on other sites
squonk 47,896 #2708 Posted July 13, 2019 Finally finish up the C-160 summer service. Cleaned deck,new plug wire, changed engine and hydro oil. Then replaced the lift cyl on Big Oly. 3 Share this post Link to post Share on other sites
squonk 47,896 #2709 Posted July 13, 2019 I had nice wires for sale at the show. 1 Share this post Link to post Share on other sites
adsm08 5,012 #2710 Posted July 13, 2019 29 minutes ago, squonk said: I had nice wires for sale at the show. If I'd know mine was going to give out a few weeks later I'd have bought one. I got one from my neighbor who does mower service, it's way too long, but it works. It ran much better, reset the carb that I had been randomly fiddling with, runs much nicer now. Now I just have to get my PTO belt replaced because the one I put on earlier this summer is coming apart. Monday I'll run out to the Napa warehouse and get a new plug wire. Guy at the local store got me a number from the book, warehouse store has them on hand. 1 Share this post Link to post Share on other sites
ZXT 2,402 #2711 Posted July 15, 2019 On 7/13/2019 at 2:06 PM, adsm08 said: If I'd know mine was going to give out a few weeks later I'd have bought one. I got one from my neighbor who does mower service, it's way too long, but it works. It ran much better, reset the carb that I had been randomly fiddling with, runs much nicer now. Now I just have to get my PTO belt replaced because the one I put on earlier this summer is coming apart. Monday I'll run out to the Napa warehouse and get a new plug wire. Guy at the local store got me a number from the book, warehouse store has them on hand. Shortening a spark plug wire isn't hard to do if you decided you wanted to go that route. 1 Share this post Link to post Share on other sites
adsm08 5,012 #2712 Posted July 15, 2019 10 hours ago, ZXT said: Shortening a spark plug wire isn't hard to do if you decided you wanted to go that route. It also has two straight ends, and I really need to have one be a 90* or it is gonna rub through on my hood eventually. 1 Share this post Link to post Share on other sites
adsm08 5,012 #2713 Posted July 16, 2019 Made new plug wire, fine fiddled carb, mowed my yard and the neighbor's because their pushmower's self-propel crapped out (I offered since I was already mowing), runs much more betterer now. Then I went back into the lift pump, AGAIN. The return spring won't stay in place, my bushing keeps popping out of the hole that was egged out originally. I suspect the real issue with that is that I don't ever leave the glues that I've been using to hold it set long enough before I fill the pump up. Well I am leaving for a few days first thing in the morning, so I JB welded the bushing to the case and the spring into the bushing, and it is gonna sit for a week while I am not here to fuss with it. When I get home I'll work the control lever back and forth a bit to see if it pops out, and if it doesn't I'll assume it's good to go. I wouldn't care about the return as much, but when the pump sticks engaged it gets hot and burns up the shaft seals. I've lost three of them this way now, and they ain't cheap. 2 Share this post Link to post Share on other sites
mhlmeader 689 #2714 Posted July 17, 2019 I think I fixed my slipping PTO by pulling the drive pulley a little further away from the engine, more adjustment added to the PTO rod, and deck spins fast like a kitten!!! 1 2 Share this post Link to post Share on other sites
ebinmaine 80,340 #2715 Posted July 17, 2019 1 hour ago, adsm08 said: much more betterer Nice to see you speak Maine 1 2 Share this post Link to post Share on other sites
adsm08 5,012 #2716 Posted July 17, 2019 Just now, ebinmaine said: Nice to see you speak Maine I also speak the Wester PA dialect with irn, and gum bands. 1 Share this post Link to post Share on other sites
Ed Kennell 47,013 #2717 Posted July 17, 2019 13 hours ago, adsm08 said: I also speak the Wester PA dialect with irn, and gum bands. It's difficult to change old habits. I left the western Pa mountains in 1961, but I still catch myself warshing my truck and changing the oral occasionally. 1 6 Share this post Link to post Share on other sites
ebinmaine 80,340 #2718 Posted July 17, 2019 Absolutely fascinates me how a lot of midwesterners add Rs where they shouldn't be and a lot of New Englanders take them all out. It's amazing we can speak to each other at all. 1 2 Share this post Link to post Share on other sites
Stormin 9,988 #2719 Posted July 17, 2019 I's sayin' nowt! Share this post Link to post Share on other sites
PeacemakerJack 11,039 #2720 Posted July 17, 2019 Today—“Vader”(the super-C) is my jobsite tool caddy today as we are redecking the deck on our house. When Kelli and I built it in 2002, it was just the two of us. Now I have three helpers and I’m thankful for them... Caleb is helping with the reconstruction and the littles are removing the nails from the old boards... 2 4 Share this post Link to post Share on other sites
ZXT 2,402 #2721 Posted July 17, 2019 7 hours ago, Ed Kennell said: It's difficult to change old habits. I left the western Pa mountains in 1961, but I still catch myself warshing my truck and changing the oral occasionally. 'round here it'd be "changing the uhl". 1 1 Share this post Link to post Share on other sites
adsm08 5,012 #2722 Posted July 18, 2019 21 hours ago, Ed Kennell said: It's difficult to change old habits. I left the western Pa mountains in 1961, but I still catch myself warshing my truck and changing the oral occasionally. Well do you know the difference between washing and warshing? You wash with water, but to warsh you need warter. 2 Share this post Link to post Share on other sites
adsm08 5,012 #2723 Posted July 18, 2019 20 hours ago, ebinmaine said: Absolutely fascinates me how a lot of midwesterners add Rs where they shouldn't be and a lot of New Englanders take them all out. It's amazing we can speak to each other at all. I know a whole city of New Englanders that put Rs where they don't belong. My college marketing prof was from Boston and one poor girl in that class fought with her all semester over the proper pronunciation of her name. The professor couldn't say any word ending in A without changing it to an ER and this girl refused to respond to "Laner". She would ignore the professor until being addressed 3 or 4 times, then say "Well that is not my name, please say it correctly". 1 1 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #2724 Posted July 18, 2019 The “crew” continues to make headway... Judge and Zach are removing nails from the old wood... @Coulter Caleb is installing the new hidden fastener Trex decking! What’s dad doing???? 🤔 Good question! 8 1 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #2725 Posted July 18, 2019 What Dads do. 2 Share this post Link to post Share on other sites
