rjg854 13,154 #301 Posted March 26, 2018 I do remember reading about that, not to long ago. Great story. Thanks for clearing that up 2 Share this post Link to post Share on other sites
WHX?? 57,277 #302 Posted March 26, 2018 Excellent Bob but how do we know you have a hard to find rare elusive B-160 if there are no pictures! 3 Share this post Link to post Share on other sites
Racinbob 13,021 #303 Posted March 26, 2018 Patience Jim. Let me get the new heart in and get the decals. 4 Share this post Link to post Share on other sites
WHX?? 57,277 #304 Posted March 26, 2018 I have no patience Bob...just ask my wife, my kids, the dog! 7 Share this post Link to post Share on other sites
Tankman 3,528 #305 Posted March 26, 2018 (edited) Edited March 27, 2018 by Tankman 3 Share this post Link to post Share on other sites
dells68 7,499 #306 Posted March 27, 2018 Been working on assembling my 42" C125 deck. The texture is aerosol bedliner to help cover the years of being outside along with my repair sins. Enamel paint on water based bedliner sure is slow to dry - a few spots are still tacky after 3 days. Red is the same Rustoleum I always use. Oh well, it will get a chance to dry out in the sun pretty soon! Before and after pics: 4 9 Share this post Link to post Share on other sites
chip61 666 #307 Posted March 27, 2018 5 hours ago, WVHillbilly520H said: If it's still fairly pliable it should fit snuggly over the oil filter and seal it to the air shroud without any adhesives or sealant, Jeff. Mine looks to be in good shape, but after a couple hours it has worked it's way halfway across the oil filter, so I thought maybe there should be some sort of adhesive.. Thanks for the replies!! Chip Share this post Link to post Share on other sites
ericj 1,580 #308 Posted March 27, 2018 45 minutes ago, chip61 said: Mine looks to be in good shape, but after a couple hours it has worked it's way halfway across the oil filter, so I thought maybe there should be some sort of adhesive.. Thanks for the replies!! what oil filter are you using, lot of filters will work but some are smaller then others. i use the NAPA gold filters, I forget the number off hand but I'm sure someone on here will chime in and tell you eric j Share this post Link to post Share on other sites
R. L. Addison 300 #309 Posted March 27, 2018 Removed frozen tie rods from frozen spindles, frozen spindles from front axle, axle from tractor to check pivot pin (worn) & wheels from spindles. Removed blower housing & head from HH100 engine & found two head gaskets,(both blown) & one stripped bolt hole. Have not checked ign. sys. yet, if system is dead, probably candidate for someone else to build up for their project. I've got three "fresh" Kohlers to test, & that's a good thing to test the hydro with. A day cleaning & reassembly to make it portable tomorrow, & go from there. 2 Share this post Link to post Share on other sites
chip61 666 #310 Posted March 27, 2018 7 hours ago, ericj said: what oil filter are you using, lot of filters will work but some are smaller then others. i use the NAPA gold filters, I forget the number off hand but I'm sure someone on here will chime in and tell you eric j I'm using the NAPA Gold 1762 oil filter. The gasket feels like a tight fit, but it doesn't stay put for very long. That's a lot of air moving through there! 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #311 Posted March 27, 2018 (edited) 53 minutes ago, chip61 said: I'm using the NAPA Gold 1762 oil filter. The gasket feels like a tight fit, but it doesn't stay put for very long. That's a lot of air moving through there! Try removing the air seal and wiping it dry with a rag and some Purple Power or even glass cleaner so it is actually a bit "tacky", it will stay haven't had one come loose in 20 years unless it had oil on it and the filter ...clean and dry shouldn't move, Jeff. Edited March 27, 2018 by WVHillbilly520H Share this post Link to post Share on other sites
chip61 666 #312 Posted March 27, 2018 Just now, WVHillbilly520H said: Try removing the air seal and wiping it dry with a rag and some Purple Power or even glass cleaner so it is actually a bit "tacky", it will stay haven't had one come loose in 20 years unless it had oil on it and the filter clean and dry shouldn't move, Jeff. I'll do that this weekend when I go to Mathews. Thanks Share this post Link to post Share on other sites
Southerncannuck 73 #313 Posted March 27, 2018 So today I adjusted the valves. The exhaust was slightly loose and the intake was very tight. Unfortunately I created an oil leak in the process. So....today I learned that gaskets need permatex. 2 Share this post Link to post Share on other sites
oliver2-44 11,610 #314 Posted March 28, 2018 Use some " Aviation Permated " iGreat stuff, my dad did Aircraft work ( Jack of all trades) years ago so we had it around the farm shop. I use it on used gasket sometimes 1 Share this post Link to post Share on other sites
cafoose 3,749 #315 Posted March 28, 2018 13 hours ago, oliver2-44 said: Use some " Aviation Permated " iGreat stuff, my dad did Aircraft work ( Jack of all trades) years ago so we had it around the farm shop. I use it on used gasket sometimes Do you mean this: https://www.amazon.com/Permatex-80019-Aviation-Gasket-Sealant/dp/B000HBM3QQ Share this post Link to post Share on other sites
oliver2-44 11,610 #316 Posted March 29, 2018 Yes, that's it. Once you smell it you will never forget the smell. Not a bad smell, just different Share this post Link to post Share on other sites
pfrederi 20,823 #318 Posted March 29, 2018 Took the turfs and chains off the L107 and put the AGs on for summer. Was nice to run around today with out rattling my teeth. The chains are from my fathers Chevy back in the 50s and are much thicker than the current stuff, hence rough ride especially on frozen ground. I converted her to studs and lugnuts a few years ago makes the swap quick and easy 2 Share this post Link to post Share on other sites
Bruce's 414-8 4 #319 Posted March 29, 2018 got my 414-8 ready for mowing season, oil changed, chassis and front end greased, deck blades sharpened, deck spindles greased, air filter cleaned, points adjusted, spark plug cleaned and re-gapped and it cranked right up like it has for the last 32 years. 4 Share this post Link to post Share on other sites
PeacemakerJack 11,021 #320 Posted March 29, 2018 18 minutes ago, Bruce's 414-8 said: got my 414-8 ready for mowing season, oil changed, chassis and front end greased, deck blades sharpened, deck spindles greased, air filter cleaned, points adjusted, spark plug cleaned and re-gapped and it cranked right up like it has for the last 32 years. to the best forum on the planet! Glad to have you on board! Beware of spending too much time on here though—it will make you want to own more of them!!! I’m interested to hear more about this tractor if you’ve owned it for 32 years... 1 Share this post Link to post Share on other sites
R. L. Addison 300 #321 Posted March 29, 2018 Today I finished cleaning front axle & spindles & reassembled. Steers much easier than my C141 & thinking about putting Charger front end under "C", maybe another day. Rest of the day spent pressing out hitch pin as I am almost sure drive may have to be split for repair. Took pictures but can't put them on yet. Hopefully.................................. Ron Share this post Link to post Share on other sites
953 nut 67,221 #322 Posted March 29, 2018 @Bruce's 414-8 With regular maintenance your will last another three decades or more. 2 Share this post Link to post Share on other sites
dells68 7,499 #323 Posted March 30, 2018 Finished putting a mower deck under my 857 last night. The lights are some I had. Someone had punched holes in the hood long before I bought it, so no harm, no foul mounting them. Got a pic of Emory's cart after I got it Rhino lined and painted. I needed to mow the yard, so I got out the 68 Lawn Ranger. Had to pull start it because the battery is dead, but after several pulls the Ole Tecumseh roared to life. Drove around in circles for a while and now I feel much better! 4 8 Share this post Link to post Share on other sites
19richie66 17,922 #324 Posted March 30, 2018 Love them both but that cart turned out nice with the bed lining. 👍 1 1 Share this post Link to post Share on other sites
PeacemakerJack 11,021 #325 Posted March 30, 2018 9 hours ago, dells68 said: ...so I got out the 68 Lawn Ranger...Drove around in circles for a while and now I feel much better! Ahhhhhhhhhh- therapy...it’s the best! After a long day at work and a nice conversation with Richie on the way home, I got on JackRabbit and drove him around the back yard for a couple of minutes and then down to the mailbox and back. Definitely a good couple of moments of decompression... 1 5 Share this post Link to post Share on other sites
