ebinmaine 81,218 #27001 Posted Sunday at 02:20 AM 1 minute ago, EB-80/8inPA said: I’m afraid I did. A fresh battery really helps bring out the best, too! No worries. Just get new wiring with good strong magic smoke holderer coating. 1 2 1 Share this post Link to post Share on other sites
CRF857 1,451 #27002 Posted Sunday at 08:42 PM Supposed to rain this morning. So I mulched what little leaves were on the ground. Then dropped the decks from the C141 and the 520. Then got the pressure washer set up and cleaned both of them. Both decks are scheduled to be redone this winter. Will be installing snow blades on both tractors. Weights and chains also. May get started on that after the Chicago Bears finish whupping up on the Saints! 3 3 Share this post Link to post Share on other sites
Bar Nuthin 3,582 #27003 Posted Sunday at 11:06 PM When I first got my C-120 the snowplow was in rough shape and the blade was bent and worn down to the carriage bolts. I got lucky and found a NOS blade that had never been on a tractor. Fast forward to this year, I found a frame that was in excellent shape and picked it up cheap. Today I swapped the frames, gave everything the "Greasy Pete" treatment and put my front weights on the C-160. 6 5 Share this post Link to post Share on other sites
SylvanLakeWH 32,883 #27004 Posted 20 hours ago Got them all out for a warm up run around the hood. The C-105 is ready for snow. 5 5 Share this post Link to post Share on other sites
Sodaking27 1,419 #27005 Posted 16 hours ago Worked on the newly acquired 520. Muffler, headlights, battery installed. Tracked down the wiring issue to the fuse block that was installed by the previous owner. Hopefully have it running tomorrow. 3 5 Share this post Link to post Share on other sites
Chris689 351 #27006 Posted 14 hours ago Got the wheel studs installed on both the No Name and the C120. Then got the new to me wheel weights installed on the No Name. Both machines should now be ready for winter. 5 5 Share this post Link to post Share on other sites
ebinmaine 81,218 #27007 Posted 13 hours ago 1 hour ago, Chris689 said: wheel studs Excellent upgrade. Every tractor through our shop gets them now. 2 Share this post Link to post Share on other sites
CRF857 1,451 #27008 Posted 12 hours ago Installed the snow blade on to C141. Fabbed the bracket to limit side to side movement. Chains and weights tomorrow, maybe. 4 Share this post Link to post Share on other sites
ebinmaine 81,218 #27009 Posted 12 hours ago 6 minutes ago, CRF857 said: Installed the snow blade on to C141. Fabbed the bracket to limit side to side movement. I have a similar setup to install sometime. My vertical piece is too short though because I have oversized tires on the front. Every time the plow dropped into a dip or off the edge of the yard it geta jammed up. 1 Share this post Link to post Share on other sites
Chris689 351 #27010 Posted 12 hours ago 1 hour ago, ebinmaine said: Excellent upgrade. Every tractor through our shop gets them now. I wish I had done it sooner. Makes mounting the C120 wheels much easier since their loaded with rv antifreeze. 1 Share this post Link to post Share on other sites
pfrederi 21,332 #27011 Posted 30 minutes ago 12 hours ago, CRF857 said: Installed the snow blade on to C141. Fabbed the bracket to limit side to side movement. Chains and weights tomorrow, maybe. You may want to elongate the hole (front to rear) in your plate to allow for the movent of the plow frame relative to the tractor as it moves up and down. Share this post Link to post Share on other sites
cleat 9,412 #27012 Posted 16 minutes ago 11 minutes ago, pfrederi said: You may want to elongate the hole (front to rear) in your plate to allow for the movent of the plow frame relative to the tractor as it moves up and down. I have been using this stabilizer for 10 years with just a round hole without issue. Just need to lubricate the rod once in a while so it does not squeak. 1 Share this post Link to post Share on other sites
pfrederi 21,332 #27013 Posted 12 minutes ago 2 minutes ago, cleat said: I have been using this stabilizer for 10 years with just a round hole without issue. Just need to lubricate the rod once in a while so it does not squeak. I see your pin can rotate back and forth...as can the the original post. my rig is fixed and needs the elongation. Share this post Link to post Share on other sites
