Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
1 minute ago, EB-80/8inPA said:
I’m afraid I did.  A fresh battery really helps bring out the best, too!
No worries. Just get new wiring with good strong magic smoke holderer coating.
  • Excellent 2
  • Haha 1
CRF857
Supposed to rain this morning. So I mulched what little leaves were on the ground. Then dropped the decks from the C141 and the 520.
Then got the pressure washer set up and cleaned both of them.
Both decks are scheduled to be redone this winter.
Will be installing snow blades on both tractors. Weights and chains also.
May get started on that after the Chicago Bears finish whupping up on the Saints!
  • Excellent 3
SylvanLakeWH
Got them all out for a warm up run around the hood. The C-105 is ready for snow.
  • Like 4
  • Excellent 5
Sodaking27
Worked on the newly acquired 520. Muffler, headlights, battery installed. Tracked down the wiring issue to the fuse block that was installed by the previous owner. Hopefully have it running tomorrow.
  • Excellent 5
Chris689
Got the wheel studs installed on both the No Name and the C120. Then got the new to me wheel weights installed on the No Name. Both machines should now be ready for winter.
  • Like 4
  • Excellent 5
ebinmaine
1 hour ago, Chris689 said:
wheel studs
Excellent upgrade.
Every tractor through our shop gets them now.
CRF857
Installed the snow blade on to C141.
Fabbed the bracket to limit side to side movement.
Chains and weights tomorrow, maybe.
  • Like 4
ebinmaine
I have a similar setup to install sometime.
My vertical piece is too short though because I have oversized tires on the front. Every time the plow dropped into a dip or off the edge of the yard it geta jammed up.
Chris689
1 hour ago, ebinmaine said:
Excellent upgrade.
I wish I had done it sooner. Makes mounting the C120 wheels much easier since their loaded with rv antifreeze.
