Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
1 minute ago, EB-80/8inPA said:
I’m afraid I did.  A fresh battery really helps bring out the best, too!
No worries. Just get new wiring with good strong magic smoke holderer coating.
  • Excellent 2
CRF857
Supposed to rain this morning. So I mulched what little leaves were on the ground. Then dropped the decks from the C141 and the 520.
Then got the pressure washer set up and cleaned both of them.
Both decks are scheduled to be redone this winter.
Will be installing snow blades on both tractors. Weights and chains also.
May get started on that after the Chicago Bears finish whupping up on the Saints!
  • Excellent 2
Bar Nuthin
IMG_6198.jpg.fc50173d64c83c4d7a6ff5aeb0cbbce3.jpgWhen I first got my C-120 the snowplow was in rough shape and the blade was bent and worn down to the carriage bolts. I got lucky and found a NOS blade that had never been on a tractor.  Fast forward to this year, I found a frame that was in excellent shape and picked it up cheap.
Today I swapped the frames, gave everything the "Greasy Pete" treatment and put my front weights on the C-160.
  • Like 5
  • Excellent 4
SylvanLakeWH
Got them all out for a warm up run around the hood. The C-105 is ready for snow.
Sodaking27
Worked on the newly acquired 520. Muffler, headlights, battery installed. Tracked down the wiring issue to the fuse block that was installed by the previous owner. Hopefully have it running tomorrow.
