peter lena 10,094 #26876 Posted Friday at 01:00 PM @Sodaking27 looks clean , is that a reflexion on that hood ? stay after my paint with lubrication , maintenance , use a graphite or lubrication on my plow blade ? very easy slide off , makes that first plow off , wide and easy . do any mods to the PLOW QUADRANT / SWING SET UP ? did this years ago , unthreaded shoulder bolts , with flat washers and elastic Lok nut, lets you dial in lubricated swing / movement area , also did threaded rod , and heim joints to replace sloppy swing rods. quadrant slide pin , works like a rifle bolt , detail / improve , every stage , nothing sarcastic , implied , only a suggestion , pete 1 Share this post Link to post Share on other sites
Sodaking27 1,381 #26877 Posted Friday at 05:57 PM 314H is officially ready for snow duty. Weights painted and installed. 11 2 Share this post Link to post Share on other sites
pfrederi 21,241 #26878 Posted Sunday at 07:18 PM Woke up the snow horses and brought them down from the shed. Everybody started OK. 2 7 Share this post Link to post Share on other sites
Sparky-(Admin) 26,551 #26879 Posted 7 hours ago Slowly getting the C-145 into snowplow mode. Tonight I got the stud kit and inside weights mounted. Also installed the F-Plate braces that I got from @ri702bill. Next will be the outside weights, axle bracket and finally the 48” 5 sector plow. 1 7 Share this post Link to post Share on other sites
ri702bill 13,225 #26880 Posted 7 hours ago Nice to see that the frame was in good shape to begin with... 1 Share this post Link to post Share on other sites
