Ed Kennell
What have you done to your Wheel Horse today?
Bar Nuthin
Me and the neighbor loaded a few of them up and took them to Portland, IN antique engine and tractor show.
Spent the better part of the day riding around the swap meet area and picking up a few things along the way.
Only managed to cover about half of the swap meet area and one pass through the antique engine area.
Huge event and it doesn't even officially open until Wednesday.
IMG_5760.jpg.2a96f95b0a15e8a3e4cea3193d38028e.jpg IMG_5761.jpg.ce99b47dc94b547aacf9889f4c6eacff.jpg
  • Excellent 6
953 nut
:wwp:                                            :text-coolphotos:                               :woohoo:
Handy Don
Send the jet to pick me up, please. I’ll be waiting... :)
  • Haha 3
sqrlgtr
Added some liquid ballast and installed some new front wheel bearings on “Vince” the 1257. Installed some thrust bearings on front spindles also. Did improve ease of  steering.
  • Excellent 3
Bar Nuthin
Tomorrow, I'll see if I can get some pictures that show the massive scale of the event. Garden tractors are only a small segment.
Acres and acres of swap meet vendors, antique tractors, hit and miss engines, food vendors, consignment barn...
  • Like 5
  • Excellent 3
Bar Nuthin
Might have went through a couple tanks of gas trying to take in the Portland Tri-State show.
More pictures in a separate post.
Edited by Bar Nuthin
  • Like 4
sqrlgtr
Mounted some Vredstien V61’s and turned  some silver wheels white.
  • Excellent 7
sqrlgtr
Finished up on the C160 front end today replaced tie rods with some l had made a while back. Also added thrust bearings on the spindles. Good thing I had the homegrown tie rods ready, one of the old ones fell apart when I took it off :). Steers way easier than before even with the wider wheels and 5 rib V61 tires.
Edited by sqrlgtr
  • Excellent 4
Chris689
Got the hood painted up today for the C120. Now that my Simplicity mower has brakes I can take the C120 out of service and pull the rest of the sheet metal. Hopefully all the tin will be painted before temps drop.
  • Excellent 7
  • Heart 1
MainelyWheelhorse
Today I got the group out took the deck off the 308 and pressure washed and armor alled them in preparation for the get together. the 308 was having an issue so I ended up pushing it back to it's spot. It's probably gas I need to get gas before I go.
  • Like 4
C100guy94
Started making a temporary lift are for my plow
ebinmaine
Why is it temporary?
C100guy94
I guess I just don't give my work enough credit and would rather the original or repop
I mean I do plan to round the edges but it's not very thick. 1/8 flat stock with another small patch of left over peice down the spine in hopes it will make it rigid enough.
I also know what I put my old 414-8 threw and I snapped your standard bolts easy. Then when I went to grade 8 bolts I started bending and wallering out the holes and bending lift arm and plow bracket pretty bad.
To be far I was young but cleared a solid acre or acre and a half of rough land hill sides.
WHX??
Saw this at a show. Owner called it a battery quick disconnect :lol:
  • Excellent 2
  • Haha 3
ebinmaine
I like it. That is called, "technically correct."
Giving me terrible ideas to use on my own truck.
:ROTF:
Handy Don
A set of old vice grips at Zagray: $3
Fancy official certified battery cable clamp: $10
:D
ebinmaine
:D
So you see my ridiculous logic!
Imagine the looks that would get at car shows too.
Handy Don
Only downside is having toothmarks on the battery posts. But who sees that stuff?!
SylvanLakeWH
The tie down is what makes it...!!!
:scared-shocked: twice, cut once... :scared-eek:
Lucky 13!!! :lol:
