Ed Kennell
What have you done to your Wheel Horse today?
ebinmaine
2 hours ago, Sparky said:
   Wish I was going to Jim’s in September…
Trina says you need to deliver that transmission up here. We'll take you out on our forest trails.
Rough. Terrain.
Mebbe hike across the street.
I'm willing to supply coffee.
  • Haha 2
kpinnc
4 hours ago, 953 nut said:
What the heck,     no hydros?
I go 4 of those too. 2 Sundstrand and 2 Eatons. :rolleyes:
  • Excellent 2
Ed Kennell
Did some maintenance on the 42" SD that I replaced with the 48" SD.
New blades
New idler pulley
Scraped and wire brushed
Oil soak then store till next spring
IMG_20260814_153039259_BURST001.jpg.e1417200911aecf61545926ef98f832c.jpgIMG_20260814_152950803_BURST000_COVER.jpg.c3fb712d54c61c868b62c53c11c25d2f.jpgIMG_20260814_161003592_PORTRAIT.jpg.c8324a16c3d27774feeb29a44eadfe14.jpgIMG_20260815_090215889_HDR_PORTRAIT.jpg.ef95310a8179abc681d2d983a2bf7c7e.jpg
  • Like 5
  • Excellent 4
ML3
Got the Bervac swapped onto 416. Also swapped rear hitch, larger wheels/tires from Workhorse. Still have a few more preventive maint items to get done. Got lift assist springs installed/adjusted & 150lbs of weight on hitch.
Now I gotta figure out what to do with the Workhorse. Be nice to have it for parts but dont really want it sitting around......
  • Excellent 6
Ed Kennell
Looks good...now for a blizzard and a video!
c-series don
Ok Ed, you asked for it! 🤣
sqrlgtr
Installed front wheel weights on my 312-89F204851-F975-473D-BE07-784CB653C9CA.jpeg.73be589efa936afa0bfe76faf96ce0c6.jpeg
Edited by sqrlgtr
  • Like 5
ineedanother
Did a diesel fuel flush and gear oil change on the 161 before installing the ARK for the first time. Lessons learned...black hoods are too wide to clear the hydraulic pump and a shaker plate calls for an inch or so shorter belt :rolleyes: It's always something.
  • Excellent 5
MainelyWheelhorse
Mowed the Fire Station and my lawn. Halfway through my lawn I broke a deck belt. Fortunately when the deck belt broke on the 312 it was at my house and not at the Fire Station. The 308 finished up the lawn, but that is needing attention as it REALLY doesn’t like running the PTO under load. It’s to the extent it starts sputtering, spitting black smoke and shutting off at idle. I’ve got that other running M12 if needed though.
  • Sad 3
Syrmore
  • Excellent 2
702854boy
32 minutes ago, Syrmore said:
Why's that deck look wide?
