kpinnc 18,754 #26501 Posted Sunday at 04:21 AM 7 hours ago, ebinmaine said: This IS the way. 1 Share this post Link to post Share on other sites
sqrlgtr 3,286 #26502 Posted 7 hours ago Put new LED bulbs in the C-160 today. Super bright 4 Share this post Link to post Share on other sites
Desko 678 #26503 Posted 3 hours ago Did some work on the 520 today which included replacing the bent/busted dash and bezel along with a new light switch from A-Z, and a new vacuum gauge, I don’t know if you can get a new one that says toro anymore but Stewart Warner still makes the style that came on the older 520s which works for me. Still need to get new bulbs for the rest of the gauges though. While I had everything out of the way I also fixed the wiring and replaced the fuse box which took care of most of the electrical issues but still need to address the 9 pin. It was also charging all over the place so I threw a new regulator on and that seems to be working good now so hopefully it’ll be a solid worker when it’s all back together 2 Share this post Link to post Share on other sites
MainelyWheelhorse 2,882 #26504 Posted 3 hours ago (edited) Today after a Zoom meeting I had in the morning. I worked on the C-141’s loose hub, and accidental red oversprayed headlight lens. After a paint thinner wipe on the clear part of the lens, and a wipe of the bulbs it was all set. the old setscrew (left) and the new (right) After a clean off with some PB Blaster and a skim of high temp wheel bearing grease I was going to put the old hub back but it still wobbled so…. 3 hours later… I robbed one off the trailer I have. I swapped the old warped hub for the identical and in better condition good hub on the trailer. Once that was on, I put the tire back on, I was done. It seemed to be much more solid feeling. Edited 3 hours ago by MainelyWheelhorse Share this post Link to post Share on other sites
