Lee1977 7,709 #26476 Posted July 19 2 hours ago, Blaine said: Thank you. I did not know that’s what what they were made for. If it doesn’t survive that’s were the next one will go. With that much aluminm bolted to it will be insterting to see if it survives. 1 Share this post Link to post Share on other sites
Blaine 241 #26477 Posted July 19 1 hour ago, Lee1977 said: With that much aluminm bolted to it will be insterting to see if it survives. Battery was 11.6v yesterday when i bolted it on and before i mowed for about an hour. It barely started on that 11.6 but the voltage went up after it was running, so that’s all i needed to see. Just checked it. Battery was 11.9v with the key off and went up to 12.0v with some throttle after i started it. Not my favorite number, but it appears juice is going in and not out, so as long as it starts….but 12.0v probably isn’t the greatest for battery life. I think this has the small 10A stator. Share this post Link to post Share on other sites
ebinmaine 79,702 #26478 Posted July 19 59 minutes ago, Blaine said: Battery was 11.6v yesterday when i bolted it on and before i mowed for about an hour. It barely started on that 11.6 but the voltage went up after it was running, so that’s all i needed to see. Just checked it. Battery was 11.9v with the key off and went up to 12.0v with some throttle after i started it. Not my favorite number, but it appears juice is going in and not out, so as long as it starts….but 12.0v probably isn’t the greatest for battery life. I think this has the small 10A stator. That's definitely not enough. Static reading should be 12.45 or higher. Running reading should be more in the range of 13.5 to low 14s. 2 Share this post Link to post Share on other sites
pfrederi 20,870 #26479 Posted July 19 (edited) 10 amp systems work just fine. Have you load tested the battery??? Assume you have a good ground for the regulator have you checked your stator output AC voltage. Edited July 19 by pfrederi 2 1 Share this post Link to post Share on other sites
Blaine 241 #26480 Posted July 19 5 minutes ago, pfrederi said: 10 amp systems work just fine. Have you load tested the battery??? Assume you have a good ground for the regulator have you checked your stator output AC voltage. I have not load tested it. I just bought a few weeks ago just for the raider and this is the first any charge has gone into the battery from the kohler. I did have a battery charger on it maybe 2 weeks ago to top it up because it was low from tinkering with the ignition and electrical. How is the stator AC checked and what can I expect to see? Connected at the regulator or open circuit AC? Share this post Link to post Share on other sites
8ntruck 9,052 #26482 Posted July 19 Cart work with Morgan, the 14-8. 2 loads of firewood. Fortunately, we got a break in the temperature and Canadian smoke today so I didn't sweat and choke too much. Just enough work to get up to operating temperature so I could do an oil change on him. 2 Share this post Link to post Share on other sites
Blaine 241 #26483 Posted Monday at 09:16 AM 13 hours ago, pfrederi said: I put the battery on a 1 amp charger for a few hours while i replaced the front brakes and changed the oil on my car. With the battery at 12.7v, it would only hit 13.0v when throttled up, but it would hold that with the lights on. Test C open stator voltage was 21.2vac. I tried adding an extra ground from the battery to a mounting bolt of the regulator but it made no difference. It was getting late and i didn’t do test A correctly, but with B+ disconnected at the regulator and checking B+ terminal of the regulator and ground, i was seeing -2.4v, which didn’t make sense. Thanks Paul. Share this post Link to post Share on other sites
ebinmaine 79,702 #26484 Posted Monday at 09:54 AM Couple pics of the 1973 8 HP 4 speed we've been working on with its owner @Natejc_98 Should be ready for a test drive! 11 1 1 Share this post Link to post Share on other sites
Handy Don 16,958 #26485 Posted Monday at 05:15 PM On 7/12/2026 at 7:39 AM, ebinmaine said: I've never had a grease gun that didn't seep the separating grease as it sat on the shelf or hung on the wall. I'D LOVE A LEAK FREE GREASE GUN. On 7/12/2026 at 6:50 PM, Dan 312-8 said: My grease gun has been stowed in a former wallpaper dip trough for more years than I can remember On 7/12/2026 at 1:07 PM, rick said: I kept an old coffee can on the floor under my grease gun. I had mounted a grease gun holder on the wall. The oil dripped in to the coffee can. On 7/12/2026 at 12:22 PM, ebinmaine said: On 7/12/2026 at 9:26 AM, c-series don said: I cut a plastic water bottle in half and slip it on the bottom of my grease guns as they hang on a nail. The bottle fits snug enough that it doesn’t slip off but loose enough to allow any liquid to seep into the bottle. Problem solved, no more drips on my work bench! Poland Spring bottles seem to fit perfectly!! I've been hanging my grease gun in a spot that's low on the wall and keep an old rag under it. Best compromise I guess. I’m having a good chuckle here at the inherent contradiction of wanting grease to penetrate once applied to a bearing or joint but NOT to seep out of the grease gun! Same applies to trying to constrain penetrant decanted into tiny bottles with needle nozzles or with threaded caps 😁 2 5 Share this post Link to post Share on other sites
Chris689 308 #26486 Posted Tuesday at 12:40 AM Well I went ahead and put a Farmall cub seat on my 10-8. Old seat was trashed and rotted so I had this. And I can put an aftermarket cover on it at some point. 8 3 Share this post Link to post Share on other sites
MainelyWheelhorse 2,872 #26487 Posted Tuesday at 02:52 AM Today, I got the 42” RD mowing deck finished up and back on. I also tested it. It’s much quieter and goes great. 8 3 Share this post Link to post Share on other sites
ineedanother 2,598 #26488 Posted Wednesday at 12:47 AM LED! IMG_2766.MOV 2 Share this post Link to post Share on other sites
Pullstart 70,716 #26489 Posted Wednesday at 03:16 PM Snapped this cool picture today! 1445 Auto, Allis Chalmers WD45, and 57 Pontiac Star Chief I call it “Generational Wealth” 14 Share this post Link to post Share on other sites
Ed Kennell 46,597 #26490 Posted Thursday at 04:48 PM Made a couple mods to the Wheel Horse tiller. The front cover plate was missing, so I scrounger a piece of steel from an old real estate sign with the intension of sanding it and using the red primer method of creating a matching patina. When I got it installed, I just couldn't sand off the eagle. The tiller was only 22 inches wide, so I added two pairs of tines to each side to make it as wide as the rear tires. 3 10 Share this post Link to post Share on other sites
sqrlgtr 3,271 #26491 Posted Thursday at 06:33 PM 1 hour ago, Ed Kennell said: I just couldn't sand off the eagle. Pretty sure they are still on the endangered list so right call Ed 1 1 1 Share this post Link to post Share on other sites
nyquil junkie 318 #26492 Posted Thursday at 09:41 PM I drug home a 520HC engine-less roller the other day, I'm contemplating on putting an engine on it and making it a cow field maintenance buggy. Its in good shape, except for the no engine thing. Because... why not. 4 Share this post Link to post Share on other sites
sqrlgtr 3,271 #26493 Posted Friday at 09:25 PM 23 hours ago, nyquil junkie said: I drug home a 520HC engine-less roller the other day, I'm contemplating on putting an engine on it and making it a cow field maintenance buggy. Its in good shape, except for the no engine thing. Because... why not. Yeah I was wanting @cafoose HC after he blew her up, (he went for a BS Vangaurd swap instead) but couldn't trade him out of it, was wanting a little more ground speed fer running around the back 40 . Share this post Link to post Share on other sites
cafoose 3,775 #26494 Posted 21 hours ago 6 hours ago, sqrlgtr said: Yeah I was wanting @cafoose HC after he blew her up, (he went for a BS Vangaurd swap instead) but couldn't trade him out of it I love my HC mows nice and I can zip around quickly, @sqrlgtr would have to pry my cold dead hands off it when I croak 4 Share this post Link to post Share on other sites
Sodaking27 1,287 #26495 Posted 8 hours ago Little work on the 314H today. New front rims, bearings, tires and tie rods. Quick touch up of some of the body parts. 5 2 Share this post Link to post Share on other sites
ineedanother 2,598 #26496 Posted 8 hours ago 12 minutes ago, Sodaking27 said: Little work on the 314H today. New front rims, bearings, tires and tie rods. Quick touch up of some of the body parts. @Sodaking27 where did you source the rims? You like? 1 Share this post Link to post Share on other sites
Sodaking27 1,287 #26497 Posted 7 hours ago 54 minutes ago, ineedanother said: @Sodaking27 where did you source the rims? You like? @ineedanother They are wheel horse rims. I purchased one off flea bay and the other I picked up from a friend of mine. 2 Share this post Link to post Share on other sites
ML3 2,393 #26498 Posted 4 hours ago Worked on 416H. Started w/decarbon & valve adjustment. Neither of which were really too bad. Since that all went well it looks like its gonna be worth putting some time & money into it. Glad to see cooling fins, especially on back cylinder were clean. 9 pin looks good also but I'll still do some preventive repairs to avoid any issues. 1 Share this post Link to post Share on other sites
ebinmaine 79,702 #26499 Posted 3 hours ago 41 minutes ago, ML3 said: do some preventive repairs to avoid any issues This IS the way. Share this post Link to post Share on other sites
ineedanother 2,598 #26500 Posted 1 hour ago Got quite a bit done today while it was raining which we needed. The drought here has been bad (technically exceptional which is the worst category). Swapped dash panels between the 16 Auto and 161 because I switched the electric and manual PTOs. All good to go but a bit of work on the harnesses. Also drilled and tapped the hubs for a second set screw on the 161. Surprised that hadn't been done but it's good to go now. Need to do an oil change on the 161 gear box and get the rear wheel weights on and it will be ready for the FEL 2 Share this post Link to post Share on other sites
