Ed Kennell
What have you done to your Wheel Horse today?
Beap52
On 6/12/2026 at 9:05 PM, oliver2-44 said:
Now that were some of you handymen with welder could make a good old fashioned manure spreader.
I've spred 2 truck/trailer loads on the lawn this spring.
pfrederi
16 hours ago, ebinmaine said:
Trina and her momma did some firewood splitting and stacking today.
The Ugly Bruce tractor was elected for towing the new Boss splitter.
Great work yo are lucky to have good help...but I am too old for all that work.  5 tons of Anthracite delivered is a lot less work:P
ebinmaine
I burned coal when I was a kid. I don't know the tonnage but we used to get a couple homemade bins filled that took up the space of one cord of wood, each.
We would start the fire with wood and keep it going with anthracite.
I wouldn't be opposed to using that again if we were to set ourselves up. But the firewood right now is free except for the fuel and maintenance on the machines used to process it.
  • Like 5
Bar Nuthin
Posted (edited)
Trying to sort out which tractors will pull different responsibilities/tasks, but decided the heavy weights belonged on the C-160. Thing runs sweet after putting the carb back together today! Actually, all three are running excellent!
I've pretty much designated the No Name to lawn duty. Guessing the 160 will be my go-to for the MacKissic chipper. Then this winter one of these two will be sporting a 48" snowplow and the other will be on standby with the snowblower.
Edited by Bar Nuthin
  • Excellent 5
ebinmaine
8 minutes ago, sqrlgtr said:
order one from
I've gotten a couple from @76c12091520h Brian Badman.
Excellent hitches.
sqrlgtr
Posted (edited)
I was not aware he had hitch’s.:handgestures-thumbsup:
Edited by sqrlgtr
ebinmaine
Yep. There's one on my Ugly Bruce tractor. :handgestures-thumbupright:
rjg854
Excellent hitches.
Just got one from him myself, excellent quality and I thought very reasonable.  :handgestures-thumbupright:
  • Excellent 2
sqrlgtr
U fellers got any pics. Proof is in the pudding I mean pics :hide:.
rjg854
Can't get pictures at the moment but maybe after supper 😜
ebinmaine
sqrlgtr
Nice I had seen those hitches before but didn't realize he made some to sell. I noticed the angle iron is turned different than mine and don't know if it would have worked with the hydro filter, but it might not make any difference but that is the reason I turned mine the way I did. Like I mentioned above it would be hard to build one yourself if you had to buy all the materials and come out much cheaper than buying one already made and probably be going in the hole if you figured your time in it.
ebinmaine
That's why I bought... instead of building.
I do still need to modify one sometime though.
Cinnamon Horse has a very high front end so the hitch points down.
rjg854
Posted (edited)
@sqrlgtr
Probably got the pictures already but I wasn't going through all those pages to find out so here's what I just tookPXL_20260626_003223167.jpg.d4070977d6e28c3ff904a7cc8428103a.jpgPXL_20260626_003155859.jpg.7b93ebf4311cd8aa14144284b041639e.jpgPXL_20260626_003134309.jpg.409012d23c98ec0528da845714136a3a.jpg
Edited by rjg854
Add
  • Excellent 3
76c12091520h
1 hour ago, sqrlgtr said:
K & B section of the vendors classifieds, about the 10th item down on the first page :handgestures-thumbupright:
  • Excellent 3
wfopete
Gave my D 160 a shroud seal to help it cool better.
sqrlgtr
Posted (edited)
Finished and mounted receiver hitch today. Worked out great. Will flip hitch over and it will be just about perfect height for my trailers. :handgestures-thumbupright:. I had mentioned having angle iron turned differently then the one @76c12091520h Brian Badman sells but pretty sure either way will work with  the hydro filter on the Eaton 1100 rear.
Edited by sqrlgtr
  • Excellent 3
8ntruck
:text-yeahthat:  if you flip that hitch over, the hitch ball will probably ABOVE the axle centerline.
Pulling something attached to a tractor above the drive axle centerline encourages the tractor to flip over backwards.  Be very very careful if you use it this way.
Leave the toung jack an inch or two above the ground - that will act as a wheelie bar to help prevent a back flip.
The hitch I built for my 14-8 places the hitch ball above the axle.  The front end gets really light, really quick.  This is encouraging me to make a hitch to mount to the front of the tractor.
ebinmaine
I've used at least four different garden tractor hitches.
All four have the ball mount on the high side.
To counteract the light front end I have the big chipper on the Cinnamon Horse. I've also used a 100 lb plus home made weight.
8ntruck
Yup.  That will work - up to a point.  But usually that point is farther into the crazy zone of tractor operation than we dare to go......
  • Haha 1
ebinmaine
Not me. I ain't set quite right.
I've pulled loads of firewood up outta the forest that were well over 1000 lbs. Many times.
  • Haha 1
sqrlgtr
me thinks the ball/tongue will still be even to top of axle and I tried making the hitch as tight as possible to tractor. Actually going to drill a new hole for the hitch pin and slid ball in another inch or so that will help also, I hope. :handgestures-fingerscrossed:.. This is going to be my firewood hauler at least thats the plan anyhow. Ive pulled some pretty heavy loads with a hitch that I made that goes on the sleeve type hitch and this one isn't much taller if any at all, just hated putting all that tongue weight on my lift cables :D.
Lee1977
Posted (edited)
Here is the one I built for my 520. I built three simular to this one.  The fourth is braced to the top of the transmission
Edited by Lee1977
