sqrlgtr 2,770 #25951 Posted 18 hours ago 1 minute ago, ML3 said: Thanks. I really tried to make it as subtle as possible. Took very little modification to make it work. It clatters & rolls coal. Had to remove & make/modify exhaust, air filter, crank breather, & fuel overflow reservoir. Didnt wanna drill/tap original fuel tank. Ebay diesel. Think its the same on Amazon. It has a decompression lever. Its hard starting in cold weather but if its over 60° it always starts on the 1st pull. I will have to check them out really have soft spot for diesels. Share this post Link to post Share on other sites
ebinmaine 78,554 #25952 Posted 18 hours ago 44 minutes ago, WHX?? said: The holes would just not line up and 38 minutes ago, ineedanother said: I need to do another. Did it once without too much trouble but I remember one of the four fighting a bit. I just make Trina install em.... Right...... "Make" & "Trina" anything. 🥋 3 Share this post Link to post Share on other sites
ML3 2,291 #25953 Posted 18 hours ago Just now, sqrlgtr said: I will have to check them out really have soft spot for diesels. Its the 2nd one I installed. 1st one was in a RJ. I never completed it & sold it at a local show to a guy from out of state. He offered me too much $$ to say no. 2 Share this post Link to post Share on other sites
sqrlgtr 2,770 #25954 Posted 18 hours ago 2 minutes ago, ML3 said: Its the 2nd one I installed. 1st one was in a RJ. I never completed it & sold it at a local show to a guy from out of state. He offered me too much $$ to say no. what kind of HP are they? I have got a few extra 400 Suburban parts laying around (hood,frame,frontaxle etc.) and was thinking of making some sort of custom out of them and thought a diesel would be interesting to use. 1 Share this post Link to post Share on other sites
Achto 31,696 #25955 Posted 17 hours ago 1 hour ago, ineedanother said: Canceled date night with the wife Understanding wife or brave man. Either way that usually don't end well. 1 4 Share this post Link to post Share on other sites
WHX?? 56,397 #25956 Posted 17 hours ago 1 hour ago, ebinmaine said: I just make Trina install em.... Well now just ain't you a regular freakin hero... 1 5 Share this post Link to post Share on other sites
Achto 31,696 #25957 Posted 17 hours ago 1 hour ago, WHX?? said: Not only that @Achto busted a brand new piston ring and invented some brand new french. Sad but true. Got up early this morning in hopes to wrap up an engine rebuild. Got to the point of installing the rings on the piston. Bottom ring went well, got to the second ring and of course it dropped in the top groove. Was carefully walking it around and.......snap. After the words of choice stopped I lit a thinking stick and went for about a 1/4 mile walk to calm down. Well as they say "Crap happens". I'm over it, new parts are on the way, hopefully next time will turn out better. 4 1 Share this post Link to post Share on other sites
ineedanother 2,232 #25958 Posted 17 hours ago 2 minutes ago, Achto said: I lit a thinking stick 1 Share this post Link to post Share on other sites
C100guy94 30 #25959 Posted 15 hours ago On 5/6/2026 at 9:04 PM, WHX?? said: Set a camera up on the cat food what to see was eating it and got this ... Well the nice thing about trail cameras is this horse pic ... Moved the trail cam to the asparagus patch to see if deer were eating that ... It was what they call a bluebird day. That bird just did a drive by and a posser I'd say. Lol Share this post Link to post Share on other sites
ebinmaine 78,554 #25960 Posted 6 hours ago 10 hours ago, WHX?? said: Well now just ain't you a regular freakin hero... Yyyeppp 1 Share this post Link to post Share on other sites
Ed Kennell 45,914 #25961 Posted 4 hours ago On 5/6/2026 at 9:04 PM, WHX?? said: Moved the trail cam to the asparagus patch to see if deer were eating that ... It was what they call a bluebird day. That's an amazing photo. Muddy makes a much higher speed and quality camera than I have. Share this post Link to post Share on other sites
ML3 2,291 #25962 Posted 2 hours ago 15 hours ago, sqrlgtr said: what kind of HP are they? I have got a few extra 400 Suburban parts laying around (hood,frame,frontaxle etc.) and was thinking of making some sort of custom out of them and thought a diesel would be interesting to use. Advertised as 3hp. Power seems more than adequate but only work it may see is hauling a yard cart around. I did it more for cruising at shows & to do something different, other than a Predator. Most important thing to do is prime the injection pump before trying to start for the 1st time. Share this post Link to post Share on other sites
Tuneup 1,455 #25963 Posted 1 hour ago Son called to say the '76 C120 stalled down in the meadow. They mow it about once a month - hard on the 42RD. The left wheel mount had snapped a month ago and I welded it. All seemed fine then. I had refurbished the K301 and trans about 10 years ago. She's a beast - can't have many hours, though I pulled it from the backyard of an old church friend where it sat for many years. I brought the 516 over and the 48SD finished it for them. Well, the RD was soaked with oil. Found that I had not torqued the oil pan. The bolts loosened and the gasket blew. Luckily, the stall wasn't a seize. The fuel pump - a Briggs-like pulse pump - filled with oil and starved it for fuel before it would starve for oil. Phew! We're lucky that way. Pulled the engine, replaced the gasket and refreshed the deck a bit. Good time for the youngest to see how. All good and ready for another season in the meadow. I was sure to check the rod and balance gears to ensure my brain hadn't failed there. Close one! 2 Share this post Link to post Share on other sites
