Ed Kennell
What have you done to your Wheel Horse today?
Chris689
On 4/6/2026 at 5:14 PM, ebinmaine said:
Niiiiice work!
Thank you. I’ve been looking for a front hitch for a couple years now. I found a few on eBay a while ago but haven’t seen em on there since. I ran across the thread on here a few days ago and remembered I got a seized up mule drive with my 73 and figured it was the perfect candidate.
BrianKoch
On 4/5/2026 at 10:23 AM, BrianKoch said:
Happy Easter Gentlemen!
This morning I began the process of figuring out what is leaking on the 312A’s hydro pump. Lot of cleaning ahead of me…
I also ordered a new motion control plate as this one is pretty wallowed out.
Update:
I refilled the reservoir with SAE 30 motor oil and waited and waited and waited. Then, I noticed oil weeping out from under the cam follower arm. After looking at the parts diagram, it doesn’t appear there is a serviceable seal underneath. Anyone have more experience with this issue?
Also, in preparation for the upcoming replacement cam plate operation, I removed the 106661 eccentric cam and sure enough it needs replacing due to excessive wear. Grass is growing day by day. Gotta get this horse out to pasture soon!
Edited by BrianKoch
cleat
3 hours ago, BrianKoch said:
Update:
Here is the parts diagram for an Eaton 1100.
I think the control shaft and seal should be the same on your Eaton 700
Hydro.pdf
For some reason they pictured it upside down.
The control shaft is #37 and your seal is #36
rjg854
Good day for changing oils and putting the snow blower and plow tractors away for the year. And getting the Commando 8 ready for mowing duties.
sqrlgtr
No pictures hard to prove you done anything :ychain:.
  • Haha 2
rjg854
Pictures of dirty oil aren't really interesting are they :confusion-scratchheadyellow:
  • Haha 1
WHX??
No but the red porn that dirtys that oil is...:ychain:
  • Haha 3
SylvanLakeWH
:scared-eek:
squonk
21 hours ago, CasaytheMann said:
I changed the oil and oil filter, and greased all 4 zircs. The recycler deflector had both bottom corners broken off, which sent grass all over the place, so I installed a piece of flooring and metal retainer to block it off. Buying a new deflector and parts for $75+ isn't in my budget at the moment. On a side note, I went down to the local Autozone to buy some sae30 oil. I didn't see any on the shelf so I asked an employee if they had any in the back warehouse. I told him I needed 2 qts. He came back with 2. When they rung it up, it showed it was 1 cent a qt. The manager said it was discontinued and they just wanted to get rid of it. I told them I'd buy whatever they had left. Walked out with 7 qts for 8 cents (sales tax was 1 cent).
Are you sure it's DETERGENT SAE 30? Seems to cheap even of they aren't going to carry it anymore. I bought a gallon of Rotella 30W at the WaWa today .
squonk
Today was "Get the tractors ready to mow day"  Went to the WaWa to get some Rotella 30W and a couple tubes of Red n Tacky
Engine Oil change, added EZ oil drain valve ,grease and blade sharpening on the 875
Engine Oil change, Trans oil (Mobil 1 10W40 Napa 1410 filter) grease. New battery and blade sharpening on the C-160
  • Like 6
  • Excellent 2
CasaytheMann
CasaytheMann
Installed a seat cover and spark plug.
  • Like 4
sqrlgtr
Put a little bling bling on that came from Vinyl Guy. Changed engine and hydro oil and filters and added oil filter cooling tin gasket.
Edited by sqrlgtr
  • Like 8
sqrlgtr
9 minutes ago, rjg854 said:
Here you go then
The line up
now thats more like it :handgestures-thumbupright:
squonk
Added adjustable seat tracks to HHHOOOWWWAAARRRDDD!!! s1.jpg.ca1132996a99840c1589ca36c49de8a6.jpg
  • Like 5
  • Excellent 2
ebinmaine
Are the seat tracks able to go further back?
Is there a specific regulation dictating the count volume of each given letter?
Was "3 per" a conscious 🤔 decision?
squonk
Seat can go back farther and if you want to drill or elongate some holes even farther back yet.
HHHOOOWWWAAARRRDDD!!! letters sounded about right! ( If you'd come to the show and hear me yell that at him you'd agree!) :lol:
  • Haha 1
Sparky
  Hmmm…I have a set of those out in the shed. Been sitting there for years attached to a seat I’ve never used. I’ll have to go out and find em and see how they operate. I love extra leg room.
  • Heart 1
sqrlgtr
Installed vacuum gauge on 520 today. Not going lie was kinda dreading getting steering wheel off but was easiest one Ive ever tackled :D. Had to take lift control lever off but the hydro control got to stay just loosened up to allow dash to move out of way. The harder tractor pulls the lower reading number on gauge, I had it in my mind it would read the other way. Also does anyone know if someone makes/sells steering wheel center cap for the 520? BTW big thanks to @Bow_Extreme for vacuum gauge.
Edited by sqrlgtr
  • Excellent 3
cleat
Here is the link to wheel horse parts and more.
He is a vendor on this site as well and great to deal with.
https://wheelhorsepartsandmore.com/product/square-steering-wheel-insert-wheel-horse-logo/
Edited by cleat
  • Excellent 2
76c12091520h
Correct size and texture, no logo, available here
sqrlgtr
Thanks to all for the help on steering wheel center have one ordered.
Thegearhead0324
I used the 1257 and dump cart to haul 2 truck engines (one at a time) from the back shed to the driveway so I can sell them. They’ve been taking up room in the shed for years.
  • Excellent 2
