SylvanLakeWH 30,321 #25301 Posted January 18 3 hours ago, Wishin4a416 said: Ive plowed 3 times Ed and no problems yet. I just hit the button real quick and it lifts about 3 inches. Which is what my manual lift did. It has the wireless remote. As soon as you let off the button it stops. Fingers crossed. Same technique for mine... 3rd season and going great! 1 7 Share this post Link to post Share on other sites
cafoose 3,561 #25302 Posted January 19 The steering on my GT-14 FEL I got from @fast88pu a few years ago at the Big Show was skipping teeth and unpredictable I investigated and found the housing support for the steering shaft was broken. I have a parts GT-14 that had a good support on it so I "borrowed" it Top one in picture is broken. Bottom one is the good one. It came off the donor easily but it's a tight fit getting it on the FEL tractor. I found the starter shield on the shroud is in the way. I started to remove it for better access and it won't come off I removed all the bolts I found that held it on and it wiggles but won't pull off 3 1 Share this post Link to post Share on other sites
Bar Nuthin 2,127 #25303 Posted January 19 17 minutes ago, cafoose said: it wiggles but won't pull off Did you try pulling harder? 4 Share this post Link to post Share on other sites
cafoose 3,561 #25304 Posted January 19 14 hours ago, Bar Nuthin said: Did you try pulling harder? 14 hours ago, cafoose said: I started to remove it for better access and it won't come off I removed all the bolts I found that held it on and it wiggles but won't pull off Dummy me didn't realize I needed to remove the flywheel screen for it to come off Got the new steering tower in place and started reassembling everything 1 2 2 Share this post Link to post Share on other sites
pfrederi 19,611 #25305 Posted January 19 Finished the fuel system today for testing purposes. New pump lines filter. Starts and runs well at full throttle still a little pop at idle but it is too cold out to spend much time fine tuning,. Ran in all gears Hi/Lo. up and down the drive way (see snow on tires, there are no pics of the test run. Ass't camera person doesn't come out when it is this cold ). Really wondering about the one rear axle it sticks out just over an inch from the hub. The hub is up against the tranny housing just like the other side. Wonder if some PO replaced the axle with a longer one from a 6 spd and if so why??? 4 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,260 #25306 Posted January 19 (edited) Got some snow between yesterday and today. Decided to do one pass last night on our driveway. Then did final pass and did my plow account about 20 minutes ago. 415BB428-68EE-4462-B3FC-C93255AE4408.mov Edited January 19 by TonyToro Jr. 2 10 Share this post Link to post Share on other sites
cafoose 3,561 #25307 Posted January 19 6 hours ago, cafoose said: Dummy me didn't realize I needed to remove the flywheel screen for it to come off Got the new steering tower in place and started reassembling everything All back together and steering like new 2 3 Share this post Link to post Share on other sites
ebinmaine 76,821 #25308 Posted January 19 2 hours ago, pfrederi said: Really wondering about the one rear axle it sticks out just over an inch from the hub. The hub is up against the tranny housing just like the other side. Wonder if some PO replaced the axle with a longer one from a 6 spd and if so why??? A 6 or 8 speed transmission should have a good inch of axle shaft showing between the back of the hub and the transmission case. If the other side is flush to the outside of the hub AND touching the transmission case... that's the short axle. Not original. 2 Share this post Link to post Share on other sites
kpinnc 16,739 #25309 Posted January 19 3 minutes ago, ebinmaine said: Not original. Probably the original got chewed up at the bearing and the PO replaced with the wrong part. There are a bunch of different ones that can (obviously) be made to work. PO may have checked the Toro price and just used what he had instead- once he woke up and got up off the floor... 1 2 Share this post Link to post Share on other sites
sqrlgtr 2,019 #25310 Posted January 19 51 minutes ago, cafoose said: All back together and steering like new good to see ya aint lost your touch 1 Share this post Link to post Share on other sites
Easton Rich 825 #25311 Posted January 20 Hehe... I bought another one Share this post Link to post Share on other sites
rjg854 12,744 #25312 Posted Tuesday at 02:48 PM 13 hours ago, Easton Rich said: Hehe... I bought another one pictures Share this post Link to post Share on other sites
sqrlgtr 2,019 #25313 Posted Tuesday at 03:49 PM 59 minutes ago, rjg854 said: pictures He has been around long enough to know the rule! NO pics Din't happen. 1 Share this post Link to post Share on other sites
lynnmor 8,462 #25314 Posted Wednesday at 04:18 PM Did my civic duty today. We are getting new neighbors across the road and I saw them struggling to clear the now packed snow from the driveway with plastic shovels. I asked if I might help and then plowed it down to the tire tracks that I couldn't get under. Turns out the father has a 416-8 ,with many attachments, that he might bring over when he gets the missing parts. I just didn't want them to be unprepared for the possible big snow coming Sunday. 1 5 2 Share this post Link to post Share on other sites
Blue Chips 602 #25315 Posted Wednesday at 09:59 PM 5 hours ago, lynnmor said: Did my civic duty today. We are getting new neighbors across the road and I saw them struggling to clear the now packed snow from the driveway with plastic shovels. I asked if I might help and then plowed it down to the tire tracks that I couldn't get under. Turns out the father has a 416-8 ,with many attachments, that he might bring over when he gets the missing parts. I just didn't want them to be unprepared for the possible big snow coming Sunday. It's priceless to have neighbors who do things for each other. We've been lucky that way in our present location on a short dead-end road where almost everyone knows each other. We help each other out in far too many different ways to list here, and I hope that never changes. 5 3 Share this post Link to post Share on other sites
Skwerl58 782 #25316 Posted yesterday at 12:00 AM Today I got the 414-8 ready to move the snow and sleet that is forecast for tonight and tomorrow. Have chains if needed and the rear tires are filled with rv antifreeze and have a mule drive weight bracket with twenty pounds. Hopefully all is ready. Be safe! 6 4 Share this post Link to post Share on other sites
Jimmy66 44 #25317 Posted 11 hours ago Finally put the snow blade on. We got a good layer of ice here in Georgetown, Texas last night. Blade just gliding on the top. Maybe I'll try putting a wheel weight on the blade and see if that makes a difference. Adjusted the angle and got a little bit of a bite but I I suppose it's a lot to ask for this little tractor to break through the ice. Maybe I can try low gear with the heavy weight on the blade, on my first attempt I was on high 1. 3 Share this post Link to post Share on other sites
Jimmy66 44 #25318 Posted 10 hours ago 2 minutes ago, Jimmy66 said: Finally put the snow blade on. We got a good layer of ice here in Georgetown, Texas last night. Blade just gliding on the top. Maybe I'll try putting a wheel weight on the blade and see if that makes a difference. Adjusted the angle and got a little bit of a bite but I I suppose it's a lot to ask for this little tractor to break through the ice. Maybe I can try low gear with the heavy weight on the blade, on my first attempt I was on high 1. 1 Share this post Link to post Share on other sites
lynnmor 8,462 #25319 Posted 10 hours ago On 1/21/2026 at 4:59 PM, Blue Chips said: It's priceless to have neighbors who do things for each other. We've been lucky that way in our present location on a short dead-end road where almost everyone knows each other. We help each other out in far too many different ways to list here, and I hope that never changes. A little update to this; I saw the neighbor drop off an itty, bitty gas powered snowblower yesterday, I wish them well. They haven't moved in yet so It will be a learning experience. I may still be needed and will help if wanted but with my surgery tomorrow I may not be able. 2 2 Share this post Link to post Share on other sites
Ed Kennell 44,283 #25320 Posted 9 hours ago 21 minutes ago, lynnmor said: I saw the neighbor drop off an itty, bitty gas powered snowblower yesterday I just watched my neighbor pushing one of those tiny blowers. He made one path to the road then disappeared into the garage. His is one of the 7 driveways I usually plow. I called all the neighbors that I had numbers for to let them know I will not be plowing until Monday morning. It is sleeting here now and I want to keep all the ice on top of the snow so I can plow it off. 4 Share this post Link to post Share on other sites
lynnmor 8,462 #25321 Posted 8 hours ago 1 hour ago, Ed Kennell said: It is sleeting here now and I want to keep all the ice on top of the snow so I can plow it off. That is my basic plan but I may need to get started real early to see what works and get it cleared before time to leave. I have the rubber scraper installed and didn't like what I saw, the previous owner apparently ran some hard weld on the bottom of the skids and that may mark the asphalt. When one buys something on FBMP there may be issues even if it looks new, like this plow. 2 Share this post Link to post Share on other sites
EB-80/8inPA 1,963 #25322 Posted 4 hours ago The C160 blow tractor wouldn’t start so I cussed at it. Then I fired up the B-80 plow tractor and used that instead. 3 Share this post Link to post Share on other sites
lynnmor 8,462 #25323 Posted 2 hours ago 6 hours ago, Ed Kennell said: It is sleeting here now and I want to keep all the ice on top of the snow so I can plow it off. Update; it appeared that there won't be much more so I did my driveway and opened the one across the road enough that he can get two vehicles in. This stuff didn't clog the snowblower at all but it really worked it, my gas gauge didn't even bounce when I came in. I might do my driveway next door after the tractor thaws. 1 4 Share this post Link to post Share on other sites
WHX?? 54,054 #25324 Posted 22 minutes ago Flew some parts and red for 520 FEL fuel pump install. Some slight mod to the pump mount it goes right in existing holes. 1 Share this post Link to post Share on other sites
c-series don 11,006 #25325 Posted 14 minutes ago Last night I replaced the transmission drive belt with what I believe is the proper one P/N 7473 on my 417-A. Today I took it out to blow the driveway and it worked fine for about 15 minutes. Then I heard a noise and knew something wasn’t right, so I headed back to the garage. I found the belt had jumped off the pulley and was wedged between the transmission and the pulley. I’ve never had this happen before? There’s two different part numbers given for that belt, I want to confirm this is the correct one? As I was investigating this problem my pager went off for a mutual aid fire call. This was in the height of the storm, to a neighboring department. A department that rarely calls for our help, stating a garage and multiple structures on fire. I am one of the senior members and truck drivers so I was the operator for this alarm. We actually had to follow the town snowplow to get there. The young man in the passenger seat got on the siren, so I yelled at him and said you idiot do you want me to pass him so we can get stuck and not get there? He apologized and I told him in this case slow and steady wins the race. We didn’t get done until dark so my driveway will have to wait until tomorrow, I wasn’t going to have trouble with the tractor in the dark with it still snowing and sleeting. That’s me in the blue coat, I don’t wear turnout gear when I’m driving as I find those big clunky boots unsafe to drive with. IMG_4058.mov 1 Share this post Link to post Share on other sites
