Sparky-(Admin) 26,360 #24401 Posted August 31, 2025 40 minutes ago, nylyon said: You got me doing the same now, have to admit it looks good! It’s addictive!! Once you start its hard to go back to doing boring circles Share this post Link to post Share on other sites
nylyon-(Admin) 9,059 #24402 Posted August 31, 2025 Last time I mowed, I went in a circle, felt guilty for the rest of the day 7 Share this post Link to post Share on other sites
Handy Don 17,474 #24403 Posted September 1, 2025 1 hour ago, nylyon said: Last time I mowed, I went in a circle, felt guilty for the rest of the day 1 hour ago, Sparky said: It’s addictive!! Once you start its hard to go back to doing boring circles Get creative and try a Zamboni pattern that uses constant radius turns! 2 Share this post Link to post Share on other sites
horseman with no horse 68 #24404 Posted September 1, 2025 cut the grass today with the commado 800 and the deck DavidTmercer sold me, little bit mulchy but it was very tall. 6 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #24405 Posted September 1, 2025 (edited) On 8/31/2025 at 8:59 PM, Handy Don said: Get creative and try a Zamboni pattern that uses constant radius turns! My mowing circles are a mix between going around gardens, houses, and trees, due to the big hill in front of my house there’s also the no spin or tip angle when mowing the side hill. 😁 Edited September 3, 2025 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
c-series don 12,449 #24406 Posted September 2, 2025 Although you can’t see any of the stripes in this picture I mow it a different direction every time. It’s good for the grass and helps eliminate rutting. 5 10 Share this post Link to post Share on other sites
WHX?? 58,143 #24407 Posted September 2, 2025 I put stripes in the dirt too. Picked this spring tooth at a flea market for 10 dolla. Bent the hitch tongue with the heat wrench to get it to trail properly. Works great for keeping a fire lane open. 4 12 Share this post Link to post Share on other sites
ebinmaine 80,714 #24408 Posted September 2, 2025 6 hours ago, WHX?? said: I put stripes in the dirt too. Picked this spring tooth at a flea market for 10 dolla. Bent the hitch tongue with the heat wrench to get it to trail properly. Works great for keeping a fire lane open. That's slick. Was the original pulling point higher? So you bent the tongue down? Share this post Link to post Share on other sites
ebinmaine 80,714 #24409 Posted September 2, 2025 Super busy weekend with all kinds of tractor fun!! 2 10 Share this post Link to post Share on other sites
WHX?? 58,143 #24410 Posted September 2, 2025 4 hours ago, ebinmaine said: Was the original pulling point higher? So you bent the tongue down? Yep musta been. Woulda had to have been a very high pulling point at the angle it was. 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #24411 Posted September 2, 2025 3 minutes ago, WHX?? said: Yep musta been. Woulda had to have been a very high pulling point at the angle it was. That obviously has some age to it. Was it intended to be pulled by animals originally? Share this post Link to post Share on other sites
lynnmor 9,040 #24412 Posted September 2, 2025 5 hours ago, ebinmaine said: Super busy weekend with all kinds of tractor fun!! I've read about the cheap Chinese primers decomposing quickly, that is one reason I haven't used them. Is there a good one available? The new one you installed looks a bit better than most. 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #24413 Posted September 2, 2025 29 minutes ago, lynnmor said: I've read about the cheap Chinese primers decomposing quickly, that is one reason I haven't used them. Is there a good one available? The new one you installed looks a bit better than most. Attwood 93014LP7 I believe is the part number I use now. Prices vary quite a bit online so be careful with your purchase. I've seen them anywhere between $17 up to about $35 for the exact same thing. 1 Share this post Link to post Share on other sites
horseman with no horse 68 #24414 Posted September 2, 2025 14 hours ago, c-series don said: Although you can’t see any of the stripes in this picture I mow it a different direction every time. It’s good for the grass and helps eliminate rutting. i cut one direction and then cut the opposite way when im done with the first direction. gramps said he likes it that way and its good for the grass 1 Share this post Link to post Share on other sites
Lee1977 7,772 #24415 Posted September 2, 2025 Mt weeds don't care witch way I mow them, they just grow wet or dry don't make much difference. I mow them short, so they look more like grass. Every time the State resurfaces the road they come back fill in beside with trash that came out of a side ditch some where. Gave up on trying to have a deason lawn years ago. 2 Share this post Link to post Share on other sites
kpinnc 18,967 #24416 Posted September 2, 2025 1 hour ago, Lee1977 said: Mt weeds don't care witch way I mow them, they just grow wet or dry don't make much difference. In the spring, I try and make the yard look nice. By late summer, so long as it's the same color when cut to the same length I am good! 2 1 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #24417 Posted September 3, 2025 (edited) Today was get ready for the M&G day. The C-141 got a repainted lower dash and the headlight lens got redone. The 312 got the rear drivers side tire fixed with fix a flat. I mowed the weeds too. The 308 got a new battery hooked up, and needed the drivers rear AG tire reseated on the bead. The 312 and 308 got the attachments taken off in preparation for the M&G. And I put my 50 foot air hose on an old reel to get it picked up. Tomorrow after work, I’ll wash them, swap the newly painted lower dash on the C-141, and figure out what I can thin out at the meet and greet. No picts as I was really busy. Edited September 3, 2025 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
Dan 312-8 617 #24418 Posted September 3, 2025 On 9/1/2025 at 9:34 PM, c-series don said: Although you can’t see any of the stripes in this picture I mow it a different direction every time. It’s good for the grass and helps eliminate rutting. The Oliver Plantation! 1 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,059 #24419 Posted September 3, 2025 Striping with the recycler 3 5 Share this post Link to post Share on other sites
adsm08 5,149 #24420 Posted September 3, 2025 Just now, nylyon said: Striping with the recycler I mean, I guess if you both got the body for it more power to you. 4 Share this post Link to post Share on other sites
nylyon-(Admin) 9,059 #24421 Posted September 3, 2025 1 Share this post Link to post Share on other sites
stvski80085 279 #24422 Posted September 3, 2025 Took the suburban for a spin. Started first pull after racinbob rebuilt carb for me. Worked out great since I only have use of left arm right now. steve 4 7 Share this post Link to post Share on other sites
Sparky-(Admin) 26,360 #24423 Posted September 3, 2025 20 hours ago, nylyon said: Love it!!! 2 Share this post Link to post Share on other sites
953 nut 69,336 #24424 Posted September 3, 2025 6 hours ago, stvski80085 said: Worked out great since I only have use of left arm right now. Cool tractor, hope your arm heals up quickly. 1 Share this post Link to post Share on other sites
Osk 28 #24425 Posted September 3, 2025 I need throttle and choke cables for my 1961-401 Wheelhorse. Any leads will be greatly appreciated. Part numbers will be helpful also. Thanks. 1 1 Share this post Link to post Share on other sites
