Blasterdad 3,167 #20701 Posted January 25, 2024 1 hour ago, BrianKoch said: Anybody else despise Easter White Pines… I'm pretty sure this guy does... 5 Share this post Link to post Share on other sites
ebinmaine 80,449 #20702 Posted January 25, 2024 17 minutes ago, SylvanLakeWH said: Michigan State Tree. Maine too. We're "The Pine Tree State" They drop pitch all over. They can't be burned indoors without 3 to 6 YEARS of seasoning. Useless to me. 2 Share this post Link to post Share on other sites
JCM 11,402 #20703 Posted January 26, 2024 Over the course of many years I have used thousands of board feet of Eastern White Pine for all sorts of projects, interior and exterior. Examples, 2 camps and 1 cabin for siding, ship lap , rough sawn. For bar tops. coffee tables, mantels, shelving , work benches etc etc. The list goes on and on. Love pine. 3 Share this post Link to post Share on other sites
ebinmaine 80,449 #20704 Posted January 26, 2024 7 minutes ago, JCM said: Over the course of many years I have used thousands of board feet of Eastern White Pine for all sorts of projects, interior and exterior. Examples, 2 camps and 1 cabin for siding, ship lap , rough sawn. For bar tops. coffee tables, mantels, shelving , work benches etc etc. The list goes on and on. Love pine. To work with. Yes. Most of my house is pine. My entire barn is pine. Framing, siding etc. To grow in a predominantly hardwood forest being pruned for firewood....? I'll let someone else grow it for me. Share this post Link to post Share on other sites
GAJoe 852 #20705 Posted January 26, 2024 I tried to crank the C-160. It's been a couple months since I ran her. I had put stabil in the gas, ran it until it died after closing the fuel valve, and put a maintenance battery charger on it back then knowing that it'd be a while until I cranked it again. I tried to crank it and it began to turn over but quickly the noise changed to a radio static sounding noise. The positive battery terminal had corrosion on it so I removed the battery and cleaned up the posts and clamps real good. I put all back together but still just the static sounding noise. So I tried twice initially and just once after getting it back together. I figured that I should ask the experts on here. The engine does turn over fine by hand. What does this sound like the problem may be? What do you recommend that I do next? Thanks for your help, Joe Share this post Link to post Share on other sites
Jon Paulsen 291 #20706 Posted January 26, 2024 9 minutes ago, GAJoe said: What does this sound like the problem may be? Starter not engaging the flywheel? Share this post Link to post Share on other sites
rick 310 #20707 Posted January 26, 2024 Check your battery voltage. 3 Share this post Link to post Share on other sites
GAJoe 852 #20708 Posted January 26, 2024 12 minutes ago, rick said: Check your battery voltage. 13.6 Share this post Link to post Share on other sites
Ed Kennell 47,097 #20709 Posted January 26, 2024 What is the battery voltage while starting? 2 Share this post Link to post Share on other sites
GAJoe 852 #20710 Posted January 26, 2024 The Starter bendix gear is not turning. The solenoid is making the buzzing static sound I believe. Share this post Link to post Share on other sites
ebinmaine 80,449 #20711 Posted January 26, 2024 4 minutes ago, GAJoe said: The Starter bendix gear is not turning. The solenoid is making the buzzing static sound I believe. Remove and clean the solenoid, and all the wire ends connecting it. If that doesn't work you may need a new solenoid 1 1 Share this post Link to post Share on other sites
GAJoe 852 #20712 Posted January 26, 2024 30 minutes ago, ebinmaine said: Remove and clean the solenoid, and all the wire ends connecting it. If that doesn't work you may need a new solenoid Will do. Also the voltage of the battery pulls down below 5 v. The water level had dropped. I added some water and put it back on the charger alone. 1 Share this post Link to post Share on other sites
ebinmaine 80,449 #20713 Posted January 26, 2024 3 minutes ago, GAJoe said: Will do. Also the voltage of the battery pulls down below 5 v. The water level had dropped. I added some water and put it back on the charger alone. Check for leaks. Any battery below 12.45 volts at rest is considered rechargeable but suspicious. If it's more than 3 seasons old.... replace it. 1 1 Share this post Link to post Share on other sites
Pullstart 71,145 #20714 Posted January 26, 2024 Realized once again I’m 5 pages behind on this thread… And did some fixing and building on an old disc. I have three, might as well let at least one go… but why not fix it first? 2 5 Share this post Link to post Share on other sites
Ed Kennell 47,097 #20715 Posted January 26, 2024 55 minutes ago, GAJoe said: battery pulls down below 5 v. Connect a good battery or jump start pack and try to start it. Your battery is no good. 5 Share this post Link to post Share on other sites
pfrederi 21,091 #20716 Posted January 26, 2024 A battery that drops below 9 volts cranking is toast 8 Share this post Link to post Share on other sites
GAJoe 852 #20717 Posted January 27, 2024 19 hours ago, ebinmaine said: Check for leaks. Any battery below 12.45 volts at rest is considered rechargeable but suspicious. If it's more than 3 seasons old.... replace it. 14 hours ago, pfrederi said: A battery that drops below 9 volts cranking is toast 18 hours ago, Ed Kennell said: Connect a good battery or jump start pack and try to start it. Your battery is no good. Guess I'll be getting a new battery. As always, good advise here, Thanks you Guys Joe 3 Share this post Link to post Share on other sites
ebinmaine 80,449 #20718 Posted January 27, 2024 11 minutes ago, GAJoe said: Guess I'll be getting a new battery. As always, good advise here, Thanks you Guys Joe Keep the questions coming Joe 1 Share this post Link to post Share on other sites
ohiofarmer 3,475 #20719 Posted January 27, 2024 Got out the workers to winterize them. The C160 auto. The 314 -8 and the 520H for snow plow duty. All now have real gas in them and the 520 needed a new spring on the transmission idler. I use neoprene rubber bands for that and the belt stays steady with a low oscillating rate. Now it's rebuild a centering device to hold the snow blade steady. My last year cobble job in not holding up. Suggestions welcomed 1 Share this post Link to post Share on other sites
Ed Kennell 47,097 #20720 Posted January 27, 2024 8 minutes ago, ohiofarmer said: Now it's rebuild a centering device to hold the snow blade steady. Dozer blade support - Page 2 - Implements and Attachments - RedSquare Wheel Horse Forum 1 1 Share this post Link to post Share on other sites
BrianKoch 370 #20721 Posted January 27, 2024 (edited) Gentlemen, Today I installed new valve retainers on the ‘69 Charger 12. Had to upgrade the bolt and lock nut assembly on the valve spring compressor (Lisle 23300) as the wimpy bolt and nut kept allowing the clamp to slide down rendering it useless. After that, I set the lash and now am reassembling the cover. Feels good to have this horse one step closer to running again! Edited January 27, 2024 by BrianKoch 7 1 Share this post Link to post Share on other sites
Tuneup 1,459 #20722 Posted January 28, 2024 So, too many dreary, rainy days and haven't gotten outside. Wreck 520 has two exhaust bolts to extract. One of them has a decent size hole I drilled center. One more bit, a cleaning tap, and I'll likely be OK. This has been my 'got no money' method for my whole life but for repairing the 48" deck and working for 40 years, I have a Harbor Freight mig setup. Still living on the cheap! Time to weld a nut. Problem is that the cheap HF helmet is too dang dark. Can't see what I'm doing and got tons of welders' advice - no help. It's just trash. Didn't have this problem in 1977 in welding class! Will invest in something better when I next need it for a significant job but for today, it's off to the races. First, the rear head comes off and may preclude me even having to weld, depending on that intake seat. 2 Share this post Link to post Share on other sites
ebinmaine 80,449 #20723 Posted January 28, 2024 10 minutes ago, Tuneup said: Can't see what I'm doing and got tons of welders' advice - no help. @Handy Don has a great wisdom in reminding all of us that proper safety gear is likely the best investment possible. I have an eye condition that doesn't allow me to adjust from light to dark very quickly at all. I do use a low priced auto darkening helmet. That helps. But my biggest salvation was getting a brighter light above my welded area. 1 1 Share this post Link to post Share on other sites
Tuneup 1,459 #20724 Posted January 28, 2024 31 minutes ago, ebinmaine said: @Handy Don has a great wisdom in reminding all of us that proper safety gear is likely the best investment possible. I have an eye condition that doesn't allow me to adjust from light to dark very quickly at all. I do use a low priced auto darkening helmet. That helps. But my biggest salvation was getting a brighter light above my welded area. Yup, shone a 300 watt bulb on the job. No help. I think the one suggestion that the initial flash that darkens the shade has your eye overreact and over darken and to close the eyes until the flash passes. In related news, the P220 can be saved. Although it's breaking bolts left and right, it apparently has only 512 hours on it. The rear cylinder is burning oil pretty well. The intake area rather grimy so hopefully the seal but I'm going to re-ring it anyway. Intake seat nice and tight. 3 Share this post Link to post Share on other sites
Tuneup 1,459 #20725 Posted January 28, 2024 Well, three fails on the welding stud removal but I've got the wire speed and heat just right now. Had to add more of both. Regroup, work on a car and will come back to it. 1 Share this post Link to post Share on other sites
