Rob J. 1,942 #16951 Posted September 10, 2022 4 hours ago, Gregor said: Deestones are just so much smaller than Carlisles or other tires. Here is Carlisle and Deestone, Both are 23 X 10.50 - 12 I want to put AG’s on my 753 eventually. I won’t put Dees on the back but I am considering putting them on the front. Tri-ribs, some people swear by them but the jury is still out with me. Really can’t beat a Carlisle no matter what it is really. Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #16952 Posted September 10, 2022 Need to get the new tires on Dug! Gave a light wash after gettin muddy! Dug made short work of the macabre task of moving a deer carcass to the back 40. But with the rain today the slope back there just about did us in! The uphill tire started spinning and I kept sliding down toward the smelly carcass I was trying to be rid of! Thank goodness for the end loader! Pushed Backwards then pulled Dug forward slowly zig zagging our way up to level ground. Took some time and 3 or 4 hands to manipulate all the controls, but made it up and got Dug washed and back in the barn. 1 Share this post Link to post Share on other sites
Ed Kennell 46,879 #16953 Posted September 10, 2022 Cleaned out Fred's fuel tank. Have one small rust hole to weld up, then some paint. 7 3 1 Share this post Link to post Share on other sites
Gregor 4,848 #16954 Posted September 10, 2022 Over time I have seen several posts about breaking the bead on tires. To be honest, I never paid a whole lot of attention to them, because when I wanted new tires, I simply took the wheels to the local tire shop, and told them what to put on. I went to the local tire shop today. They quoted me $400 for 2 Carlisle turf tires mounted on my rims. I thought thay was a bit steep. I brought my tires back home. Now I had to break the beads. It aint easy! Driving over the tire with my truck, did no0thing, although, it does hold the tire still while you attack it with a sawzall, oscillating saw, grinder, and cold chisel, but I did get the tires off.One tire had something very sticky, and ugly inside. That was not fun to clean up. Both were quite rusty inside. Last year I bought a cheap little HF sand blaster, but I didn't have compressor enough to run it properly. Now I have access to a VERY large compressor, and it worked much better. My main focus was the bead area, and it cleaned really well. I also did the outside. They are not show quality, but good enough for a plow tractor. If you do a lot of painting, you NEED to get a sand blaster. So much better than a wire wheel, a brush, sand paper. I should have had this thing 10 years ago. When I think of all the money I spent having things blasted, I could have bought my own large compressor. 4 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #16955 Posted September 10, 2022 15 minutes ago, Gregor said: They quoted me $400 for 2 Carlisle turf tires mounted on my rims 15 minutes ago, Gregor said: I thought thay was a bit steep Ya' don't say...? I can't imagine what they charge to put bicycle tires on... Don 1 Share this post Link to post Share on other sites
ineedanother 2,793 #16956 Posted September 10, 2022 10 minutes ago, Gregor said: I went to the local tire shop today. They quoted me $400 for 2 Carlisle turf tires mounted on my rims. I thought thay was a bit steep. My main focus was the bead area, and it cleaned really well. Like a lot of other things, tires have gotten expensive and tire shops have to mark them up to stay in business. I've gotten accustomed to soaking rims in an e-bath to get rid of that rust but that just isn't for everyone. I would suggest though that you at least get some heavy rust primer on the inside of those and roll or brush some rustoleum or something in there. You'll typically add moisture when you put air in so a bit of extra effort now can pay dividends keeping the rims strong over time. 3 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #16957 Posted September 10, 2022 2 minutes ago, ineedanother said: I've gotten accustomed to soaking rims in an e-bath to get rid of that rust but that just isn't for everyone. Someone told me that vinegar would also help with the rust and corrosion... although I don't know if that's true or not... Don 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,074 #16958 Posted September 10, 2022 25 minutes ago, Gregor said: They quoted me $400 for 2 Carlisle turf tires mounted on my rims. That’s crazy… Discount Tire in April - all 4 tires - old off new on - Carlisle Turf Master - $285… 3 Share this post Link to post Share on other sites
Heatingman 977 #16959 Posted September 10, 2022 32 minutes ago, Gregor said: Over time I have seen several posts about breaking the bead on tires. To be honest, I never paid a whole lot of attention to them, because when I wanted new tires, I simply took the wheels to the local tire shop, and told them what to put on. I went to the local tire shop today. They quoted me $400 for 2 Carlisle turf tires mounted on my rims. I thought thay was a bit steep. I brought my tires back home. Now I had to break the beads. It aint easy! Driving over the tire with my truck, did no0thing, although, it does hold the tire still while you attack it with a sawzall, oscillating saw, grinder, and cold chisel, but I did get the tires off.One tire had something very sticky, and ugly inside. That was not fun to clean up. Both were quite rusty inside. Last year I bought a cheap little HF sand blaster, but I didn't have compressor enough to run it properly. Now I have access to a VERY large compressor, and it worked much better. My main focus was the bead area, and it cleaned really well. I also did the outside. They are not show quality, but good enough for a plow tractor. If you do a lot of painting, you NEED to get a sand blaster. So much better than a wire wheel, a brush, sand paper. I should have had this thing 10 years ago. When I think of all the money I spent having things blasted, I could have bought my own large compressor. Was that just to put on tires you provided? 1 Share this post Link to post Share on other sites
ineedanother 2,793 #16960 Posted September 10, 2022 Just now, Snoopy11 said: Someone told me that vinegar would also help with the rust and corrosion... although I don't know if that's true or not... Don Acids (acetic, phosphoric, others...) can help to clean that rust but those etch the iron and take just about as long to get results. I don't care for having to dispose of acids either and they're more expensive than electrolysis. Lots of opinions out there but at least we all agree that rust needs to be cleaned up. I don't have the before pics on these front that I'm doing but they were just about as bad as what @Gregor is working with. E-bath for a day or two, primer, paint on the inside. I'll get the tires mounted once that paint is good and cured. The bead will probably get scratched and maybe dinged when they're mounted which is why I'll wait to paint the rims themselves until the tires are on and tubes are in. 2 3 Share this post Link to post Share on other sites
Evguy 566 #16961 Posted September 10, 2022 13 minutes ago, SylvanLakeWH said: That’s crazy… Discount Tire in April - all 4 tires - old off new on - Carlisle Turf Master - $285… My local tire place charges 15 per, last time no charge on 3 because rusty rims had minor leak. Got them home and no leak. 4 Share this post Link to post Share on other sites
Gregor 4,848 #16962 Posted September 10, 2022 I took 23 X 8.50 - 12's off of these rims. I assume I can put 23 X 10.50 - 12's back on. ??????? 3 Share this post Link to post Share on other sites
953 nut 68,367 #16963 Posted September 10, 2022 1 hour ago, Gregor said: If you do a lot of painting, you NEED to get a sand blaster. So much better than a wire wheel, a brush, sand paper. Before placing any rusted parts in the media blaster it is a good idea to use a needle gun, it will cut your blasting time by 75% and your glass beads will last a lot longer. 6 Share this post Link to post Share on other sites
SylvanLakeWH 32,074 #16964 Posted September 11, 2022 1 hour ago, Gregor said: I took 23 X 8.50 - 12's off of these rims. I assume I can put 23 X 10.50 - 12's back on. ??????? I did on a C 105 no issues… 4 Share this post Link to post Share on other sites
Burnerman 759 #16965 Posted September 11, 2022 On 9/9/2022 at 5:16 PM, Heatingman said: How well does that bead breaker work on the the really old ones? I have been able to break every bead so far. Even rusty ones that have had stop leak put in them. I had it bolted to a half sheet of plywood. (These tires were super easy) If you lag it to the floor you can do car tires. It was worth it for $70. 4 Share this post Link to post Share on other sites
ineedanother 2,793 #16966 Posted September 11, 2022 2 hours ago, Gregor said: but I did get the tires off. One tire had something very sticky, and ugly inside. Fix-a-flat or some similar potion I suspect... 2 Share this post Link to post Share on other sites
ineedanother 2,793 #16967 Posted September 11, 2022 1 minute ago, ineedanother said: Fix-a-flat or some similar potion I suspect... Ugly stuff inside tires reminds me of something from when I grew up in farming country in SW PA where we took glass jugs to the milk dairy within view of where we lived. The milk house was attached to the barn and Dave (whom I worked for too when I was young), the local dairy farmer would flip the switch to churn the milk in the big steel tank and tip the red hose into our jugs, open the valve, and viola! we had fresh milk which was about 35* and friggin delicious. Really great stuff that you had to shake to mix the cream back into before poring a glass. There was also a tin cup there in the milk house to have a drink during the process but I digress. When our tubeless tires in our tractors leaked, my dad would break the bead and pour 1/4 or 1/2 cup of fresh milk in and re-inflate them. The milk would (I suppose) curdle and seal the tire. I never thought much of it at the time but I can attest to the fact that it worked. 3 1 1 Share this post Link to post Share on other sites
Heatingman 977 #16968 Posted September 11, 2022 Could not help myself. Almond really pops on the rims. Just about ran out of daylight. And moved them inside just after sunset. 4 7 1 Share this post Link to post Share on other sites
oliver2-44 11,676 #16969 Posted September 11, 2022 8 hours ago, Rob J. said: I want to put AG’s on my 753 eventually. I won’t put Dees on the back but I am considering putting them on the front. Tri-ribs, some people swear by them but the jury is still out with me. Really can’t beat a Carlisle no matter what it is really. Go one size larger on the Deestone tires compared to Carslile and they will be about be the same size. Share this post Link to post Share on other sites
Heatingman 977 #16970 Posted September 11, 2022 (edited) Couple more passes around the border and this will be looking good. Edited September 11, 2022 by Heatingman 4 5 Share this post Link to post Share on other sites
Heatingman 977 #16971 Posted September 11, 2022 Decided to try an air brush to touch up the rims where my hanging supports were. Worked very well, highly recommended getting one for such work. Almost no overspray, barely any fumes, and did a great job. Think I might even use it to paint all the little brackets, and pulleys and such. 4 1 Share this post Link to post Share on other sites
oliver2-44 11,676 #16972 Posted September 11, 2022 @Heatingman what airbrush do you have. Share this post Link to post Share on other sites
Heatingman 977 #16973 Posted September 11, 2022 3 minutes ago, oliver2-44 said: @Heatingman what airbrush do you have. I picked this one up this morning from Menards, and an upgraded hose from Harbor Fright. 2 1 Share this post Link to post Share on other sites
Heatingman 977 #16974 Posted September 11, 2022 The airbrush really saved this rainy day in regards to what I had planned to get done with the tractor. Was able to paint the frame, trans, splindles, and hubs inside without having to set up as spray booth, or tarps for overspray, etc… Took a while to paint the larger parts, but really was able to get into the nooks and crannies of the parts easily. I’ll definitely be using this thing more, even when painting with the full size paint gun to get into those hard to reach areas. 11 1 Share this post Link to post Share on other sites
Monstrosity 1,153 #16975 Posted September 12, 2022 Well I was messing around with the 1054 I put the engine from the c125 on the frame and I need to do some fabrication. The base for the engine mount is wide and I kinda want to keep it isolated mounting. So lengthing the frame seems to be in the plans now. I set the c series hood on it and it doesn't look bad lol 5 2 Share this post Link to post Share on other sites
