Dan.gerous 2,696 #15901 Posted May 26, 2022 On 5/25/2022 at 12:21 AM, WHX?? said: Story of my life.... What you get out of hog farming @Dan.gerous ? What about pork chops, what about pulled pork, what about pork fat rules, what about BACON! You guys over ther figure on subsisting on tea & scones? We have a freezer full of pork Also drink a lot of tea.... 4 Share this post Link to post Share on other sites
Tuneup 1,459 #15902 Posted May 26, 2022 21 hours ago, JoeM said: Interested to see the results. I got a cub engine on solid mounts, no gears, and it will shake your teeth out. I am actually thinking something else is wrong. Idles nice and as it comes up through the RPM it hits some bands of vibration and of course one of them is full throttle. One of these days, might just change flywheel and put a run-out gauge on the output shaft to see if it is bent. Too close to show time going to back burner. I sanded the old muffler with sheetrock sandpaper - just perfect for all that scale. Gave it a coat of black. Now, off to get the pipe nub to attach it. After that, START! Note on the vibration. When on its rubber mounts, it always had a serious vibration band just off idle. Narrow band not in any working RPM but interesting. Changing to solids ended that and she was very smooth. I am anxious to see how the gear removal will affect it. 4 day weekend coming so, yippee! 6 Share this post Link to post Share on other sites
953 nut 69,634 #15903 Posted May 26, 2022 11 hours ago, WHGuy413 said: mowed this evening with my late grandfathers 416H. Always love to hear of a treasured family being loved by subsequent generations of the family. 3 1 Share this post Link to post Share on other sites
Aaron Coffman 55 #15904 Posted May 26, 2022 Put on a new "Stens" replacement gas cap for my 1981 Wheel Horse Manual C-125. Before and after photos are below. Very happy with the new product! 6 1 Share this post Link to post Share on other sites
Aaron Coffman 55 #15905 Posted May 26, 2022 53 minutes ago, 953 nut said: Always love to hear of a treasured family being loved by subsequent generations of the family. That's the best way to do it! I got my 1981 Wheel Horse Manual C-125 from my grandfather and am working on fixing up a 1976 Wheel Horse A-90 that my Pap bought new and passed down to my father and now to me. Definitely started a new addiction! haha 2 5 Share this post Link to post Share on other sites
JoeM 10,315 #15906 Posted May 26, 2022 1 hour ago, 953 nut said: being loved by subsequent generations of the family. hoping they say that about one of mine in a few long years! 4 1 Share this post Link to post Share on other sites
peter lena 10,080 #15907 Posted May 26, 2022 @WHGuy413 amazing , clean deck and sharp blades ! nice looking set up , also the cut and lay of the cut fits the yard , looks like it should . changed over my cut pattern , so its exactly oposet what I was doing , looks better and just fits the various angles and slopes I have . go green , pete 3 Share this post Link to post Share on other sites
peter lena 10,080 #15908 Posted May 26, 2022 @Aaron Coffman , welcome aboard , being a newbie , have you ever checked that trans dip stick right there ? how about the related shift boot ? if oil is milky or funky looking or if shift boot is torn / ripped , time to change both . always look for related issues as you check things , use a razor blade to cut off shifter boot , use dielectric grease on shifter shaft top and related boot hole for easy installation. pete 1 1 Share this post Link to post Share on other sites
BrianKoch 370 #15909 Posted May 26, 2022 Made new battery cables. 3 5 Share this post Link to post Share on other sites
peter lena 10,080 #15910 Posted May 26, 2022 @WHGuy413 amazing , clean deck and sharp blades ! nice looking set up , also the cut and lay of the cut fits the yard , looks like it should . changed over my cut pattern , so its exactly oposet what I was doing , looks better and just fits the various angles and slopes I have . go green , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,808 #15911 Posted May 26, 2022 3 hours ago, Aaron Coffman said: Definitely started a new addiction It's good that you seem to recognize that early on. Construction on a larger building is highly advised. 3 1 Share this post Link to post Share on other sites
peter lena 10,080 #15912 Posted May 26, 2022 @BrianKoch nice job on those . bolt one to battery ground bolt point behind dash , other end to corner of engine , clutch pedal side , use serrated washers and dielectric grease . that will enhance grounding for electrical rectifier , on engine tin , also go from rectifier area with a separate wire for better headlight grounding , you will also probably notice your amperage gauge , working with more action due to better grounding . also like your large mount holes , look like 3/8 " ? keep it sparky , pete Share this post Link to post Share on other sites
Aaron Coffman 55 #15913 Posted May 26, 2022 31 minutes ago, ebinmaine said: It's good that you seem to recognize that early on. Construction on a larger building is highly advised. A large building is definitely on my wish list! 1 Share this post Link to post Share on other sites
Aaron Coffman 55 #15914 Posted May 26, 2022 2 hours ago, peter lena said: @Aaron Coffman , welcome aboard , being a newbie , have you ever checked that trans dip stick right there ? how about the related shift boot ? if oil is milky or funky looking or if shift boot is torn / ripped , time to change both . always look for related issues as you check things , use a razor blade to cut off shifter boot , use dielectric grease on shifter shaft top and related boot hole for easy installation. pete Thank you for the advice! 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #15915 Posted May 26, 2022 Finally got the axle seal replaced on the C-100. Seemed to all go well so hopefully no more puddling oil under it... pressed in pic didn't turn out well but it seated well running the skinny tires for now. Will get tubes for the wide v-tread next! 6 6 Share this post Link to post Share on other sites
Dan.gerous 2,696 #15916 Posted May 26, 2022 Third wheelhorse in their temporary new home. One more joining them tomorrow but the last one will stay for yard maintenance until the day we leave. Off early in the morning to pick up the two Yanmar diesels 15 Share this post Link to post Share on other sites
Tuneup 1,459 #15917 Posted May 27, 2022 Always something! Ran out of 1/4" spring clamps so had to hit Ace in town and all they had were worm clamps. Hate those things but the bulb is on. Gave it a few squeezes and the .020 K301 puffed to life without its balance gears. @JoeM, there is increased vibration right through to the seat. It's tolerable. I haven't adjusted high idle yet but it's enough to make the hood rattle. I had to add strips of narrow tubing to where the hood mounts to the tower. Quiet now. Mowed a little in the back. Remarkable compression. She'll idle even lower, though I won't keep it there. Needs to spend more time under load to seal those rings. In the end, if I could reinstall the gears on nice new spindles with nice new bearings, I would. 4 2 Share this post Link to post Share on other sites
peter lena 10,080 #15918 Posted May 27, 2022 @Tuneup once I started installing those fuel check valves , found those dark green 1/4" spring clamps to be a size to size fit on fuel lines. use just a touch of dielectric grease on the nipple end of fitting for fuel line , goes together like butter , slide on clamp , easy ,pete 2 Share this post Link to post Share on other sites
Achto 32,816 #15919 Posted May 27, 2022 Installed an hour meter on the 867 that I restored over the past winter. I did not want to cut a hole to mount a 2" gauge so I opted for one with an inductive pick up that I could hide inside of the hood. These are great little hour meters that will literally work on any engine that has a spark plug. No battery power required. For anyone that may be interested in one of these hour meters. https://www.amazon.com/Magicalmai-Inductive-Motorcycle-Snowmobile-Waterproof-Hour/dp/B07Y3ZYBLW/ref=sr_1_8?crid=22NAEGQFGZR19&keywords=small+engine+hour+meter+waterproof&qid=1653694140&sprefix=small+engine+hou%2Caps%2C106&sr=8-8 9 6 3 Share this post Link to post Share on other sites
sjoemie himself 3,232 #15920 Posted May 28, 2022 That is a nice unit. My dad uses those on his vintage 2-stroke dirt bike to keep track of when the piston needs changing. Works like a charm. I've been looking for an analog rpm-gauge which can be installed in a similar way but so far haven't been lucky enough to find one. They all seem to be digital. If anyone knows a source please let me know. 3 Share this post Link to post Share on other sites
Tractorhead 9,217 #15921 Posted May 28, 2022 27 minutes ago, sjoemie himself said: That is a nice unit. My dad uses those on his vintage 2-stroke dirt bike to keep track of when the piston needs changing. Works like a charm. I've been looking for an analog rpm-gauge which can be installed in a similar way but so far haven't been lucky enough to find one. They all seem to be digital. If anyone knows a source please let me know. Analog gauges was available about 5years ago for Marine Engines, but actually i also find just digital gauges. use also one on of the Digital on the Bavarian, this is a combo of RPM and Hour meter. it starts automatically if engine turn over. very handy but only digital available. 5 Share this post Link to post Share on other sites
pfrederi 21,204 #15922 Posted May 28, 2022 I bought one of those digital hour meters (Briggs and Stratton brand) when I bought our JD GT235. Worked great for about 5 years then the internal non replaceable battery died. 20 years later tractor still runs great but no hour count... 3 Share this post Link to post Share on other sites
sjoemie himself 3,232 #15923 Posted May 28, 2022 Well I did find this but there's little to no product description available. Now I don't mind a bit of a gamble but electronics are a bit of a mystery to me so I have no idea if I can make it work or not. 1 Share this post Link to post Share on other sites
Handy Don 17,513 #15924 Posted May 28, 2022 Went looking for a combo panel mounted digital volt and amp meter. Cannot find one able to show both positive and negative amperage. Looking like I’ll have two separate meters. 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #15925 Posted May 28, 2022 (edited) 55 minutes ago, Handy Don said: Went looking for a combo panel mounted digital volt and amp meter. Cannot find one able to show both positive and negative amperage. Looking like I’ll have two separate meters. Maybe something like this 2“ gauges be interesting? https://www.marine-discount24.com/faria-chesapeake-ss-white-drehzahlmesser-0-6000-u-min-1.html https://www.marine-discount24.com/faria-voltmeter-ss-white-fa13805.html https://www.marine-discount24.com/faria-dress-white-amperemeter-60a-lade-und-entnahmestrom-1.html They be from a Maritime Shop but they are not really cheap. As a combo i didn‘t find anything in that size. edit- The ammeter shall be strong enough for a Wheelhorse Starter. Edit end - Edited May 28, 2022 by Tractorhead 2 Share this post Link to post Share on other sites
