Achto 32,816 #14651 Posted February 21, 2022 Those larger filters do not always fill full. If the engine runs good at all RPMs, then I wouldn't worry about it. 3 Share this post Link to post Share on other sites
johnnymag3 2,646 #14652 Posted February 21, 2022 Tear out the screen, and install a good quality filter....Those screens are known to block fuel flow partially.. John 1 1 Share this post Link to post Share on other sites
peter lena 10,080 #14653 Posted February 21, 2022 (edited) @Maxwell-8 , are you going to put a couple of flange bearings on that shaft ? get some lucas grease on that steering fan gear area ,especially the bottom stub end fit as well as related linkage , and front axel center mount and wheels off the floor greasing for top grease release, in addition to wheel bearing pack . make that battery related ground bolt point , your add on cable to engine corner , serrated washer , and electrical bolt lug , to be your ignition and headlight grounding source . very simple , but very reliable . just telling you what I do , ( you don,t have to ) to make things work . pete Edited February 21, 2022 by peter lena duplication of reply 1 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #14654 Posted February 21, 2022 42 minutes ago, peter lena said: wheel bearing Will be ordering some from Skipper soon! 42 minutes ago, peter lena said: lucas grease We don't have that on this side of the pond. 43 minutes ago, peter lena said: just telling you what I do , ( you don,t have to ) But I will! 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #14655 Posted February 21, 2022 (edited) 9 minutes ago, Maxwell-8 said: We don't have that on this side of the pond Wonder how much it would cost to send it to Belgium... from here in the states... Probably OUTRAGEOUS cost... Don Edited February 21, 2022 by Snoopy11 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #14656 Posted February 21, 2022 4 minutes ago, Snoopy11 said: Wonder how much it would cost to send it to Belgium... from here in the states... Probably OUTRAGEOUS cost... Don shipping, guessing 40$ for a box, then customs which are often half of the value of the product. 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #14657 Posted February 21, 2022 2 minutes ago, Maxwell-8 said: shipping, guessing 40$ for a box, then customs which are often half of the value of the product. Oh, my... well... in that case... THAT isn't an option.... Costs roughly 5 dollars for a tube here in the states... Don 2 Share this post Link to post Share on other sites
D_Mac 9,339 #14658 Posted February 21, 2022 Was a nice day today. After my doctor's appointment I decided it was a good day to wake up the 1075. It hasn't been startered and driven all winter. Poured some gas in it, primed the fuel pump, choked it, turned the key and it fired right up. Had to put a little air in the front tires, I will look to replace them this spring. Really like this tractor. Short Frame, Big Block, Tall Stack, Custom Decals, Baby Moons, Wheel-A-Matic !!! 2 8 1 Share this post Link to post Share on other sites
Poppa Phill 61 #14659 Posted February 21, 2022 5 hours ago, TJ Salyers said: @Achto Since I got it running right it just doesn't seem like it's getting any fuel to the fuel filter because it's almost completely dry when it's running would you just keep the screen or would you just rip it out. TANK SCREENS SUCK. when I find em clogged on customer atvs mowers etc, I can em and install a good quality inline unit. serviceable and peace of mind. if you really ant to keep the fuel clean going in, use a neck strainer. they come in all sizes and wont interfere with the fuel cap. I make most of mine, buy em when i dont have time. Ive found that the same ones that come on the cheap power generators work very well. make sure your pump is up to snuff as well. my 310-8 is going for a trailer ride to the shop as soon as I can get a couple client atvs out. tank clog showed up after that last bout of snow . had to call in a plow.. Tank filter bye bye and some new lines.. gonna do some more practicing on what Im preachin..... 3 Share this post Link to post Share on other sites
TJ5208 1,841 #14660 Posted February 21, 2022 8 hours ago, Achto said: Those larger filters do not always fill full. If the engine runs good at all RPMs, then I wouldn't worry about it. The filter I have on it now is completely empty when I run it but it runs perfect. 2 Share this post Link to post Share on other sites
Achto 32,816 #14661 Posted February 21, 2022 13 minutes ago, TJ Salyers said: The filter I have on it now is completely empty when I run it but it runs perfect. It probably just looks empty. If gas was not passing through it, it would not run at all. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #14662 Posted February 21, 2022 12 minutes ago, Achto said: It probably just looks empty. If gas was not passing through it, it would not run at all. Here it is not the best pics. Share this post Link to post Share on other sites
TJ5208 1,841 #14663 Posted February 21, 2022 I think I need a smaller fuel filter. 1 Share this post Link to post Share on other sites
Achto 32,816 #14664 Posted February 21, 2022 2 minutes ago, TJ Salyers said: I think I need a smaller fuel filter. If the tractor is running, why worry about it? 4 Share this post Link to post Share on other sites
TJ5208 1,841 #14665 Posted February 21, 2022 Just now, Achto said: If the tractor is running, why worry about it? Well I don't know why I worry about it but it doesn't have anything in it I'm kind of concerned about it. As my dad says if it ain't broke don't fix it. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #14666 Posted February 21, 2022 1 minute ago, Achto said: If the tractor is running, why worry about it? I guess it just kind of aggravates me the tractors pretty much running on fumes. 1 Share this post Link to post Share on other sites
Achto 32,816 #14667 Posted February 21, 2022 1 minute ago, TJ Salyers said: As my dad says if it ain't broke don't fix it. Trust me when I say that your tractor is not running on fumes. 2 4 1 Share this post Link to post Share on other sites
lynnmor 9,042 #14668 Posted February 21, 2022 That fuel filter has gas in it but they usually trap some air because of the horizontal mounting, I like a clear filter so I can see if there is gas and how much dirt is trapped. 5 Share this post Link to post Share on other sites
TJ5208 1,841 #14669 Posted February 21, 2022 (edited) 2 minutes ago, lynnmor said: That fuel filter has gas in it but they usually trap some air because of the horizontal mounting, I like a clear filter so I can see if there is gas and how much dirt is trapped. Okay I understand that but when I hit it against the side of the engine it just sounds really hollow and when it's out in the sunlight you can't see nothing I thought you would be able to. Edited February 21, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
lynnmor 9,042 #14670 Posted February 21, 2022 1 minute ago, TJ Salyers said: Okay I understand that but when I hit it against the side of the engine it just sounds really hollow and when it's out in the sunlight you can't see nothing I thought you would be able to. Me thinks that you worry too much. 6 Share this post Link to post Share on other sites
TJ5208 1,841 #14671 Posted February 21, 2022 Just now, lynnmor said: Me thinks that you worry too much. Me do to but I guess I don't understand what could happen if it runs low on gas all the time but it still runs. 1 Share this post Link to post Share on other sites
Ed Kennell 47,481 #14672 Posted February 21, 2022 54 minutes ago, TJ Salyers said: The filter I have on it now is completely empty when I run it but it runs perfect. at last......The energy crisis is over. We have a fuel free internal combustion engine. 10 Share this post Link to post Share on other sites
wallfish 20,647 #14673 Posted February 21, 2022 19 hours ago, TJ Salyers said: I think I need a smaller fuel filter. If you need to see fuel in the fuel filter to verify the engine is actually running on fuel then please move it to place where it will be located in a vertical position. Then you can see it full of fuel instead of seeing some air trapped inside of it. It's better located before the fuel pump anyway (like stated in your other thread) to keep the vasilene and crap out of the pump too. This fuel filter thing has already been covered in your other thread 1 Share this post Link to post Share on other sites
D_Mac 9,339 #14674 Posted February 21, 2022 So did I mention I fired up my 1075 that's been sitting for a few months? 1 2 1 Share this post Link to post Share on other sites
Chestnut 315 #14675 Posted February 22, 2022 2 hours ago, TJ Salyers said: I guess it just kind of aggravates me the tractors pretty much running on fumes. I have it on good authority an Onan will not run on fumes. If it's running fine it's getting copious quantities of gas. Accept the fact that you've fixed it and it's running fine. Take the win and celebrate. 4 1 Share this post Link to post Share on other sites
