clueless 3,259 #1 Posted January 13, 2018 Will the 37" two blade deck fit under a 520 with the forward swept axle? Share this post Link to post Share on other sites
Sparky-(Admin) 23,277 #2 Posted January 13, 2018 Sure will. No front tire clearance issues under a regular 300 or 400 series so the deck should be even farther away from the front wheels on a swept axle machine. I would be more concerned about that 20hp Onan being able to spin that deck !! Share this post Link to post Share on other sites
clueless 3,259 #3 Posted January 13, 2018 57 minutes ago, Sparky said: Sure will. No front tire clearance issues under a regular 300 or 400 series so the deck should be even farther away from the front wheels on a swept axle machine. I would be more concerned about that 20hp Onan being able to spin that deck !! If your 300 or 400 series have the 8" front wheels there is a clearance issues. Share this post Link to post Share on other sites
evanloock 236 #4 Posted January 13, 2018 I have a 37 inch deck on a 520-HC. With the guage wheels set at lower cutting heights, the right guage wheel will rub the rear tire when the deck is raised to transport position. This can be aleviated by using a narrower guage wheel with a spacer or narrower rear tires. This is the only issue with using the 37 inch deck on a 520 with a "swept" front axle. Share this post Link to post Share on other sites
