pfrederi 17,199 #1 Posted January 11, 2018 (edited) People are always claiming they have to have 1-1/8" axle 8 pinion transaxles. The others are apparently felt to be too weak. However i got to wondering how many of us have actually broken a 1" axle or a 10 pinion differential. I would exclude pullers with souped up engines or running duals. I have 16 or so horses and work on a few neighbors WHs. I have never broken an axle or torn up a differential. the only transxale failure I have come across was the axle needle bearing on my brothers C-81. it failed chewed up the axle (didn't break) and destroyed the 1533 bearing...and it was the vaunted 8 pinion 1-1/8" Edited January 11, 2018 by pfrederi 1 3 Share this post Link to post Share on other sites
C-101plowerpower 1,605 #2 Posted January 11, 2018 i pull a plow through holy uneven ground (means a lot of sudden loss and gain of traction) and havent broken the 1" 4pinion(yet) but then again if i feel its to rough i dont plow 1 Share this post Link to post Share on other sites
Skipper 1,788 #3 Posted January 11, 2018 I applaud you for setting up this poll. I will excuse myself from participating, since I have had a wheel horse for such a short period of time, that it would be misleading for me to vote. 2 Share this post Link to post Share on other sites
Racinbob 10,476 #4 Posted January 11, 2018 While it's agreed that the 8 pinion 1-1/8" is the strongest I'm quick to add, when appropriate for the thread, that the 4 pinion 1" is one tough unit and not to discount it. I've been on these things since before the 8 pinion 1-1/8" even made the scene. I've worked them harder than what they were intended for but I have yet to break one. 3 2 1 Share this post Link to post Share on other sites
JoeM 7,769 #5 Posted January 11, 2018 About the only 1 inch axle issue, a keyway chucked out and ruined the hub. This was on a B100 Automatic. I think my teenage kids may have help that one along! 1 Share this post Link to post Share on other sites
wallfish 16,070 #6 Posted January 12, 2018 voted before reading your post. Snapped a 1 1/8 with the loader/back hoe but it was on dualies. 1 1 Share this post Link to post Share on other sites
BOB ELLISON 2,976 #7 Posted January 12, 2018 I had to replace a axle on my c160 only because the PO thought he could remove the hub with a hammer. 1 1 Share this post Link to post Share on other sites
prondzy 3,867 #8 Posted January 12, 2018 Only broke a 4 pinion differential. Here are the extreme circumstances that i broke them with. Pulling a single bottom plow 12in. 1/4 mile passes for 4 hours when it broke, i havent had this happen with an 8 pinion uet. 2 Share this post Link to post Share on other sites
Road-Track 39 #9 Posted January 19, 2018 I just had my 14hp automatic break the left rear axle....I didn't see that the chains on the rear wheels were frozen over and I just put the tractor in drive... Guess I have another project for the list. I will pull the engine and put it in my 16 hp, since I took that out for a premptive rebuild. Should I rebuild or look for another Eaton 1100 transmssion? Share this post Link to post Share on other sites
WHX?? 47,093 #10 Posted January 19, 2018 I would pull the Eaton apart and check the rest of the internals. It's no good like it is anyway. If they look good just look for a replacement axle. the other side of the coin if you get a whole 1100 you might have parts for future. 1 1 Share this post Link to post Share on other sites
Road-Track 39 #11 Posted January 23, 2018 (edited) On January 19, 2018 at 12:37 PM, WHX14 said: I would pull the Eaton apart and check the rest of the internals. It's no good like it is anyway. If they look good just look for a replacement axle. the other side of the coin if you get a whole 1100 you might have parts for future. Thanks WH14, I have a whole C125 transaxle on the way! I will also take the other transaxle apart and repair, for a spare. If I can find a good 108361 left axle. Here are some pictures of the spiral break of the left axle... Is this normal? From what I can see from the Hydro and 8 spd parts explodes the axles are the same for both. Is this true? Edited January 23, 2018 by Road-Track add pictures Share this post Link to post Share on other sites
