mowboy 12 #1 Posted January 7, 2018 I cannot believe I can't locate this on my own, stubborn I guess. But I need help- I'm looking for the rear axel oil seals for what I believe I have (no id tag). That is a 1973 12 hp Auto (1-0465) with 90-1136 Sunstrand hydro.. I thought )and ordered the SKF 11124 (wh # 6449). But went and pulled the old seal out today and it's almost 1/2" wide, so now I think the 11124 is wrong. Any help is appreciated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,387 #2 Posted January 7, 2018 The first page shows what tractors used what transmission Garry 1 1 Share this post Link to post Share on other sites
mowboy 12 #3 Posted January 7, 2018 Thanks -but what I read shows what looks like the oil seal with diagram #4-20, however in the list it does not list 4-20. am I missing something here? I'm positive the hydro is #90-1136 and assumed the transmission was 5089 Share this post Link to post Share on other sites
JoeM 10,101 #4 Posted January 7, 2018 looks like you need number #4-16 seals 6449 1 1/8 axle 100607 1 inch axle looks like the OEM seals are pretty thick. I take it the old seals were thinner when you removed them? Share this post Link to post Share on other sites
pfrederi 20,924 #5 Posted January 7, 2018 (edited) the new seals are thinner but work.11124 You could always double them if you wanted. Modern seals are routinely thinner than older ones.. Edited January 7, 2018 by pfrederi Share this post Link to post Share on other sites
