Simplecity 23 #1 Posted December 31, 2017 Good Evening All and Happy New Year Have a K301 D038515 Spec# 47147C that has a badly gouged fuel pump arm. I know that there are plastic bodied replacements, however I would like to keep this as original as possible. Any leads on these parts? As a last resort I could attempt to buildup the damaged area with some weld. Thanks to all who respond. Simplecity Share this post Link to post Share on other sites
953 nut 62,119 #2 Posted December 31, 2017 Used pumps can be had through quite often. The valve body and inlet/outlet fittings from yours can be put on the one you buy. 1 Share this post Link to post Share on other sites
ebinmaine 74,515 #3 Posted December 31, 2017 Could also check with one of our fine vendors. Definitely - rebuild and reuse the old metal one. Share this post Link to post Share on other sites
