pfrederi 18,634 #1 Posted December 23, 2017 Started on one of my winter projects today, tearing down a Sundstrand Hydro gear. This is the third hydro I have come across with a Red Wheel Horse filter. Wonder how many years it has been since they made those. Obviously maintenance was not the POs strong point... Filter doesn't want to come off either...married to the transaxle after all these years... 2 Share this post Link to post Share on other sites
doc724 925 #2 Posted December 23, 2017 My C125 from 1981 was like that also, but mine came off easily. The first year WH used the Eaton 1100. Share this post Link to post Share on other sites
oliver2-44 10,686 #3 Posted December 23, 2017 My 1974 C160 Sundstrand had a red filter when I got it last year. I couldn't budge it with al the normative tools. Finally out came the 4 ft pipe wrench. I grabbed right at the housing back and after a slight crush it spun off. It was like the slight crushing broke the sticking Rubber O ring Share this post Link to post Share on other sites
KC9KAS 4,744 #4 Posted December 23, 2017 I too have had to resort to severe methods to remove "old" filters on the hydro's. I have several different type of oil filter removal tools, but sometimes drastic measures are needed! I wish I had a 4' (aluminum) pipe wrench! 1 Share this post Link to post Share on other sites
ztnoo 2,300 #5 Posted December 23, 2017 29 minutes ago, oliver2-44 said: Finally out came the 4 ft pipe wrench. Its hard to beat leverage when removing a stubborn whatever it is...... 4 feet is a pretty hefty lever for that application. "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world". - Archimedes 2 Share this post Link to post Share on other sites
953 nut 59,754 #6 Posted December 23, 2017 Paul, I will be watching this thread with great interest. I have found that a few light blows on a small chisel angled on the rim will start a filter cartridge turning. 1 1 Share this post Link to post Share on other sites
pfrederi 18,634 #7 Posted December 24, 2017 Victory...Tried filter pliers (no movement), strap wrench (slipped), Chain wrench (crushed the filter housing, couldn't get close to the inside edge because the parking brake shaft was too close to the filter. Hammer and chisel won the day 5 Share this post Link to post Share on other sites
953 nut 59,754 #8 Posted December 24, 2017 1 hour ago, pfrederi said: Hammer and chisel won the day works every time. 1 Share this post Link to post Share on other sites
AMC RULES 37,196 #9 Posted December 24, 2017 The before... ...and then, beaten to a bloody pulp. 2 Share this post Link to post Share on other sites
shallowwatersailor 3,214 #10 Posted December 24, 2017 I have had good luck with driving a screwdriver through the fllter and then turning. GM would always put the engine filter on so tight at the engine factory, that was sometimes the only way yo get it off. 3 Share this post Link to post Share on other sites
cleat 7,242 #11 Posted December 24, 2017 On 12/23/2017 at 4:02 PM, oliver2-44 said: My 1974 C160 Sundstrand had a red filter when I got it last year. I couldn't budge it with al the normative tools. Finally out came the 4 ft pipe wrench. I grabbed right at the housing back and after a slight crush it spun off. It was like the slight crushing broke the sticking Rubber O ring We have a 48" aluminum pipe wrench at work. I have only used it a couple of times, it is a beast (could not even imagine a cast iron model). 36" I use all the time. You must have lots of room around the filter to fit in a large pipe wrench like that. Share this post Link to post Share on other sites
oliver2-44 10,686 #12 Posted December 25, 2017 In the process of trying to get the filter off Various ways I ended up with the rear fenders and rear wheel off with it on a jackstand Share this post Link to post Share on other sites
Sarge 3,465 #13 Posted December 26, 2017 I spy a very interesting looking chisel - what brand is that ?? Older Chrysler slant six engines were notorious , folks would crank their filters down and generally had to use pry bars to roll back the face plate enough to crack them loose - even a chisel wouldn't work . Book said hand tighten , and they meant it - by hand only , no tools , fool....lol . Sarge 2 Share this post Link to post Share on other sites
pfrederi 18,634 #14 Posted December 26, 2017 1 hour ago, Sarge said: I spy a very interesting looking chisel - what brand is that ?? Older Chrysler slant six engines were notorious , folks would crank their filters down and generally had to use pry bars to roll back the face plate enough to crack them loose - even a chisel wouldn't work . Book said hand tighten , and they meant it - by hand only , no tools , fool....lol . Sarge Proto Bought them a couple years ago to replace the ones i got from my Father. The were at east 75 years old and had spent most their life breaking cement and rocks.... 2 Share this post Link to post Share on other sites
squonk 43,726 #15 Posted December 26, 2017 (edited) On 12/24/2017 at 12:34 PM, pfrederi said: Victory...Tried filter pliers (no movement), strap wrench (slipped), Chain wrench (crushed the filter housing, couldn't get close to the inside edge because the parking brake shaft was too close to the filter. Hammer and chisel won the day It's bleeding! I used to run into stuck filters on Chevy motorhomes. They always seemed to have about 20,000 miles on them and they had the black AC-Delco filter that was installed at the factory. We would always end up puncturing the can and tearing it all off leaving the round metal filter mounting which is on the left in Paul's pic. Used an air hammer with a punch in one of the holes and applied pressure in a counter clockwise direction. 95% of the time it would come off. The other 5% the oil filter threaded block adapter would shatter. Luckily this was a cheap cast iron piece held on with 2 bolts. You couldn't get to the bolts with the filter base on but once it broke off it was a matter of putting it in a vise and getting the bolt. Used to keep a few adapters in stock just for this occasion. Edited December 26, 2017 by squonk 1 Share this post Link to post Share on other sites
Sarge 3,465 #16 Posted December 28, 2017 I figured it had to be a high quality brand - those rock chisels are made from some interesting steel for sure , wish they still made them from whatever that alloy was...Proto makes some very good tools even today . Sarge Share this post Link to post Share on other sites
