kennethdizeo 4 #1 Posted December 18, 2017 hello...i am in need of a WH 418 or 417...front wheel 8" 16 x 6.5 asap...my tractor is broked down...will pay fair price ! Kenny 440 319 4774 Share this post Link to post Share on other sites
953 nut 64,155 #2 Posted December 18, 2017 You will probably get better results by posting in our classifieds. The model number is located under the seat on the left side, you will want to include it in your request. If ti is a 418C the front rims are not the same as the 418A. http://www.wheelhorseforum.com/classifieds/wanted/?do=form&d=2 Also, A-Z Tractor has been a very good source, give them a call. http://a-ztractor.com/about/ Share this post Link to post Share on other sites
SPINJIM 1,996 #3 Posted December 19, 2017 Also, check the axle length on your 418. I tried to put a rim from a 417-8 on my 418A (same tire size) , and found out the axle length is about an inch shorter. Good luck. Jim Share this post Link to post Share on other sites
953 nut 64,155 #4 Posted December 19, 2017 2 hours ago, SPINJIM said: Also, check the axle length on your 418. I tried to put a rim from a 417-8 on my 418A (same tire size) , and found out the axle length is about an inch shorter. Good luck. Jim Same here, that is why I said to be sure the model is the same. I put a rim from a 418A on the 418C and had to make a one inch spacer. 1 Share this post Link to post Share on other sites
