seven 202 #1 Posted December 17, 2017 It will only stay running when I shoot a little fuel in carb. So decided to pull carb off when I took the bowl off I could see the needle was stuck in there so I took it out and the little rubber tip was making it stick.is there either different needle for this? the other question is the needle supposed to be connected to the float cause mine is not? Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted December 17, 2017 There would be a small wire that connected the float to the needle valve, 1 Share this post Link to post Share on other sites
seven 202 #3 Posted December 18, 2017 Thx but my needle doesn't have a collar for a clip to go into? Share this post Link to post Share on other sites
skrusins 128 #4 Posted December 18, 2017 If I remember I've seen them both ways. If you hadn't problems in the past then clean it up. You can also look up the rebuild kit for that carb and it will tell you what you need or not. 2 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #5 Posted December 18, 2017 Seems to me that I read a service bulletin that kohler changed to the wire connection type needle valve for that very reason. I got a rebuild kit for $15.00 and replaced mine. 1 Share this post Link to post Share on other sites
seven 202 #6 Posted December 18, 2017 This isn't the first time it's done that so definitely need to find out where to get the newer parts Share this post Link to post Share on other sites
pfrederi 19,247 #7 Posted December 18, 2017 If your engine has a Walbro Fixed jet carb there is no connecting clip. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #8 Posted December 20, 2017 Garry 2 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #9 Posted December 20, 2017 Thank you Garry . That's the post I read and referred to. Share this post Link to post Share on other sites
pfrederi 19,247 #10 Posted December 20, 2017 3 hours ago, gwest_ca said: Garry Thanks Garry never saw that TSB. Kohler really likes their rebuild kit $48 for a couple gaskets and a needle even the Stens version is $29 Share this post Link to post Share on other sites
