TIGman 2,006 #1 Posted December 16, 2017 Yes! the 1054 is up and running again. The culprit was the little 3" drive belt idler pulley. It was almost stuck solid. The new idler pulley was installed today and the 1054 is back plowing snow. 11 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,574 #2 Posted December 16, 2017 That 1054 is a beast. Must be great for plowing. Glenn 2 Share this post Link to post Share on other sites
953 nut 66,614 #3 Posted December 16, 2017 17 minutes ago, TIGman said: 1054 is back plowing snow. Tig, what spring did you end up using? 1 Share this post Link to post Share on other sites
TIGman 2,006 #4 Posted December 16, 2017 24 minutes ago, 953 nut said: Tig, what spring did you end up using? Actually 953 I'm still using the old one right now temporarily. But am going to try replacing it with one of the suggested ones. So awesome having it back running again. Of my tractors, my "Favorite" work Horse. And the Tri Rib tires on front are working out great. Thanks! again for your suggestion on checking the idler pulley. 2 1 Share this post Link to post Share on other sites
TIGman 2,006 #5 Posted December 16, 2017 2 hours ago, JERSEYHAWG / Glenn said: That 1054 is a beast. Must be great for plowing. Glenn Yes it is Glenn My "Favorite" snow plowing tractor. 2 Share this post Link to post Share on other sites
