wheelhorser 7 #1 Posted December 16, 2017 (edited) Anyone know a trick to get a 1533 bearing out without too much damage? Edited December 16, 2017 by wheelhorser Share this post Link to post Share on other sites
953 nut 67,607 #2 Posted December 16, 2017 Need to use the proper puller. Lots of auto parts stores have them to loan out. 3 Share this post Link to post Share on other sites
dclarke 4,271 #3 Posted December 17, 2017 (edited) This is what I use. A piece of flat steel, 1/8"x3/4"x1-1/8" and a 10" long punch (brass bolt). Cut the flat steel just long enough to slip thru the inner race of the bearing, place it as pictured and tap it out from the outside. Move the flat from side to side on the bearing as you drive it out. Edited December 17, 2017 by dclarke 6 Share this post Link to post Share on other sites
squonk 47,470 #4 Posted December 17, 2017 A cross between Richards and Denny's ideas. Axle brg puller. you rock the pivoting end into the inner race to grab it and pull with a slide hammer. 3 Share this post Link to post Share on other sites
wheelhorser 7 #5 Posted December 19, 2017 THANKS FOR ALL THE FEEDBACK,USED DENNYS IDEA WITH A PIECE OF SMALL FLAT STEEL UNDER THE LIP HIT IT TWICE WITH LONG BOLT AND HAMMER AND IT FLEW OUT. 3 Share this post Link to post Share on other sites
