Dg1970 5 #1 Posted December 13, 2017 Hello new member here . This fall I picked up a 1970 raider10 model 6051. Came with snow plow and mower deck . So we just had our first snow and gave the tractor a shot and it worked great until it stoped moving no matter what gear I was in . The transmission is the high/low 3 forward and reverse. I’ve gone through the forums and seen other people with the same problem. I checked all the keys(both wheel hubs and the pully) brake drum doesn’t have one . All were good. Pulled on the shifter that was solid . Checked the diff by spinning the wheels , all seemed good . I pulled the transmission and double checked everything . That’s when I noticed kinda like a dead spot in the diff kinda like the gears were slipping. I split the trans and pulled the diff but couldn’t find anything wrong. No stripped gears . Now I’m baffled. Please help this tractor is great. P.S. it’s a uni drive Share this post Link to post Share on other sites
Skipper 1,790 #2 Posted December 13, 2017 (edited) if you spin the input shaft on the trans, does the wheels/axles then turn? If yes, you look to see why the input shaft is not connected to the engine via belt drive. if no, you have a problem with/in the trans. Edited December 13, 2017 by Skipper 4 Share this post Link to post Share on other sites
SylvanLakeWH 29,559 #3 Posted December 13, 2017 You are in the right place for good info! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,787 #4 Posted December 13, 2017 Are you sure the high/low shifter is fully engaged? They will act like a neutral if not fully engaged. Garry 4 1 Share this post Link to post Share on other sites
Racinbob 12,332 #5 Posted December 13, 2017 It's very easy for that to happen. 1 Share this post Link to post Share on other sites
Dg1970 5 #6 Posted December 13, 2017 Thanks for the fast responses I’ll check when I get home tonight and let everyone know what I come up with 1 Share this post Link to post Share on other sites
Jerry77 1,218 #7 Posted December 13, 2017 Welcome to................Glad you are here..... 1 Share this post Link to post Share on other sites
Dg1970 5 #8 Posted December 13, 2017 Do they offer a gasket/seal kit for this trans ? Share this post Link to post Share on other sites
Racinbob 12,332 #9 Posted December 13, 2017 (edited) You can get what you need from this vendor: https://wheelhorsepartsandmore.com/transmissions.html Edited December 13, 2017 by Racinbob 4 Share this post Link to post Share on other sites
Dg1970 5 #11 Posted December 16, 2017 Sorry guys it’s been a couple days but it looks like it was the high/low stuck in between just waiting on some new seals and gaskets . Should be good to go . Thanks again for your help 😊 3 Share this post Link to post Share on other sites
