TIGman 2,006 #1 Posted December 11, 2017 Got home from work went to start the 1054 it would barely roll over. Battery was good ,so I cleaned all the connections on the starter. Success!! That was till the starter belt broke..... Got it started with pull rope. Yay !! Started plowing off the little bit of snow we had today and the drive belt started slipping/screeching on flat ground.... Almost done plowing and the tractor stopped like I turned the key off. Pushed the tractor up to the house.... I think Murphy kicked my butt today!! lol Oh well..... 5 7 Share this post Link to post Share on other sites
ebinmaine 77,379 #2 Posted December 11, 2017 15 minutes ago, TIGman said: I think Murphy kicked my butt today!! lol KICK BACK !!! 6 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #3 Posted December 11, 2017 Yep Tig...I agree with Eric...fight back. What do you think is wrong with the horse...why did it quit??? Sit back and have one of these 1st. and then get these out. and in no time...you will be 7 Share this post Link to post Share on other sites
953 nut 64,157 #4 Posted December 11, 2017 If a 1054 quits running it must be out of gas (or the battery went dead from no S/G belt). 36 minutes ago, TIGman said: slipping/screeching Probably the idler pulley needs to be replaced. 2 Share this post Link to post Share on other sites
slim67 2,824 #5 Posted December 11, 2017 48 minutes ago, TIGman said: Got home from work went to start the 1054 it would barely roll over. Battery was good ,so I cleaned all the connections on the starter. Success!! That was till the starter belt broke..... Got it started with pull rope. Yay !! Started plowing off the little bit of snow we had today and the drive belt started slipping/screeching on flat ground.... Almost done plowing and the tractor stopped like I turned the key off. Pushed the tractor up to the house.... I think Murphy kicked my butt today!! lol Oh well..... Im sure its nothing you cant fix. Maybe its mule not a horse? 6 Share this post Link to post Share on other sites
TIGman 2,006 #6 Posted December 12, 2017 1 hour ago, 953 nut said: If a 1054 quits running it must be out of gas (or the battery went dead from no S/G belt). Probably the idler pulley needs to be replaced. I'll check out the idler pulley, also wondered about the tension spring? I see the guy had what looks to be the original spring with a small spring added on the end? 1 Share this post Link to post Share on other sites
TIGman 2,006 #7 Posted December 12, 2017 Well I figured out why the tractor died. The ground cable lug where it was connected broke. No ground, no run, imagine that..... A trip to the local farm store will find another starter belt. Also wondering if it has the correct length drive belt? 4 1 Share this post Link to post Share on other sites
953 nut 64,157 #8 Posted December 12, 2017 10 minutes ago, TIGman said: wondering if it has the correct length drive belt? If it has been working properly up to now I would guess it is the correct size. Should be a 4L-820 or A-80 12 minutes ago, TIGman said: imagine that Knew it couldn't be to serious, 3 Share this post Link to post Share on other sites
DougC 2,643 #9 Posted December 12, 2017 When the idler pulley bearing screeched so loud on my 95 520H and the lady next door dropped her leaf rake and jumped into the air and turned around with a scowl on her face, I knew it was time to find and repair the problem..................... 1 4 Share this post Link to post Share on other sites
ebinmaine 77,379 #10 Posted December 12, 2017 2 minutes ago, DougC said: turned around with a scowl on her face, I knew it was time to find and repair the problem You can't help it if SHE doesn't have a sense of humor. 1 2 Share this post Link to post Share on other sites
DougC 2,643 #11 Posted December 12, 2017 7 minutes ago, ebinmaine said: You can't help it if SHE doesn't have a sense of humor. It was a classic bite your tongue moment, trying not to fall off the tractor laughing but act like I wasn't laughing and avoid running into a tree............. 4 Share this post Link to post Share on other sites
953 nut 64,157 #12 Posted December 12, 2017 11 minutes ago, DougC said: lady next door dropped her leaf rake and jumped into the air and turned around with a scowl on her face 2 2 Share this post Link to post Share on other sites
ebinmaine 77,379 #13 Posted December 12, 2017 7 minutes ago, DougC said: It was a classic bite your tongue moment, trying not to fall off the tractor laughing but act like I wasn't laughing and avoid running into a tree............. HAHAHAHAHA! !!!! One of the best moments in life. 1 1 Share this post Link to post Share on other sites
