Docwheelhorse 2,740 #1 Posted December 10, 2017 (edited) Hello All, Received a call from an older gentleman that owns a 516 auto he bought new. Well it has the "cheaper" Eaton 700 and no hydro lift. Its controlled by shifter between legs. He thinks its an 88 or 89 and the pump completly quit... he brought it to a dealer and they want almost $2000 to fix it 😭 He called me looking for a trans... I dont have a 700 ---but--- I do have (2) 417 hydros with Eaton 1100s and the between your legs shifter. They are engineless parts csrcasses. How much work would it be to convert the 516 to an 1100 transaxle? Can the lift hydraulic port be blocked off or a hose put between output and return? Instead of having to pull the whole lift assembly apart. Thanks Tony Edited December 10, 2017 by Docwheelhorse 2 Share this post Link to post Share on other sites
953 nut 59,800 #2 Posted December 10, 2017 This thread should answer all your questions. 1 Share this post Link to post Share on other sites
JoeM 8,294 #3 Posted December 10, 2017 Bolts right up, the linkage looks a little different but is really not. Just have to flop over the cam plate. I connected the hydraulic lift inlet hose straight to the filter. bypassing the valve. nothing else I can remember. 2 1 Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted December 11, 2017 12 minutes ago, OILUJ52 said: Bolts right up, the linkage looks a little different 1 hour ago, 953 nut said: This thread should answer all your questions. Easy conversion - wheelhorseman can make you a hose to bypass the hyd lift...retain the long rod that goes to the cam plate...it is longer than the one on the 1100.. I needed it on my 516 conversion ...I used the cam plate as is...didn't flop over....your 516 is an 88 - only year it was made...I purchased a complete transaxle assembly including hubs from richmondred01 for mine...it was super easy...might be harder if you only get the pump. 1 Share this post Link to post Share on other sites
cleat 7,249 #5 Posted December 11, 2017 I would add the lift too if possible. If you get the parts from a donor machine, it should be pretty straight forward. I would not want to use a manual lift after being spoiled with hydraulics. Either way, the 1100 is the way to go, don't know why Wheel Horse put the 700 in a 500 series. Cleat 1 Share this post Link to post Share on other sites
