ti-jean 45 #1 Posted December 8, 2017 Hi all for one years did'n have problem so went I try how my tractor was run to be ready for the winter the engin begin to surging up and down wen it was warm so this week I remove to the top of the carb was very dirty in there so I take all the intake from the engine and get a good clean all so remove the gas tank and and get a good clean I also replace a few piece of the gas line so now I try to figure what is going rung no air leak from the intake I also check the carb gasket no air leak there wen the engin is warm I engage the pto and begin to surge for gas again if I put juste a bit of choke engin begin to run smooth and even after Il open top of the carb again remove all the inside parts pray so Suzuki carb cleaner put the top of the carb try it again everything was OK even with the pto engage few minute later vroum vroum vroum again . help 1 Share this post Link to post Share on other sites
squonk 45,366 #2 Posted December 8, 2017 Try adding a good dose of Seafoam engine treatment to the tank. 1 Share this post Link to post Share on other sites
Jerry77 1,218 #3 Posted December 8, 2017 This may not help you, but my 516 was doing the same thing - used the seafoam and it helped, but not enough.. I put an electric fuel pump on it and haven't had a problem since then...if you do the same thing , be sure to mount the pump at or below the level of the bottom of the fuel tank...it pushes much better than it pulls.and put an inline fuse on it too....( I added a switch to shut it off if I wanted the key on for other purposes) .. 1 Share this post Link to post Share on other sites
953 nut 63,916 #4 Posted December 9, 2017 Mike and Jerry have given you very good advice. 2 Share this post Link to post Share on other sites
lynnmor 8,544 #5 Posted December 9, 2017 If using the choke improves the operation, you still didn't clean the carburetor completely. Be sure that the welch plug above the idle mixture screw is intact. There are small passages behind that plug and you will need a new one if you remove it for cleaning. 1 Share this post Link to post Share on other sites
ti-jean 45 #6 Posted December 9, 2017 Hi today it is Santa miracle first again I replace all the fuel line for 5/16 instead of 1/4 size and add 1/4 bottel of seafoam full gas tank 91 octane gas the engine run like the devil in person smooth and nice idel all so with the pto engage now it I am sit in on my sofa in front of my fire place waiting for snow real dont know if it is the size of the gas line a replace for biger size or the seafoam but in important thing the and all running fine . thank's every buddy for your help 1 Share this post Link to post Share on other sites
