Ward Clarke 0 #1 Posted December 7, 2017 Looking for an ignition coil for a wheelhorse electro 12, 1969, model # 1 7245, serial # 587106. Kohler engine model # K301S, serial # D045046, spec # 47147C. Can anyone help me locate an ignition coil for this machine? Share this post Link to post Share on other sites
pfrederi 20,675 #2 Posted December 7, 2017 (edited) Based on the spec number if nothing has been changed you have the breaker-less ignition system. The Coil is a triangular shaped device mounted on the front of the blower housing. They are NLA. You should try a wanted add in the classifies section here. Also check ebay. Before you buy one are you sure it is your coil and not the trigger?? Here is a pic of teh coil and the way to test it (or anyone you may buy) You can download the Kohler Service manual that gives complete info on teh system here Edited December 7, 2017 by pfrederi Share this post Link to post Share on other sites
953 nut 66,618 #3 Posted December 7, 2017 A good alternative to the breakerliss trigger ignition system would be a points and coil system. check out this thread. Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted December 7, 2017 @Ward Clarke to Share this post Link to post Share on other sites
