BigRedGrizzly 229 #1 Posted November 27, 2017 (edited) Hi all... I just wanted to pass along some information. I needed to replace my wear bar on my 54” snow blade. Warn makes a high density plastic wear bar for their plows which are 54” as well. I ordere on one and attached it. I had to drill new holes in the plastic wear bar to mount it. Much easier to drill through the plastic than the steel. I’m interested to see how long this wear bar lasts. Edited November 27, 2017 by BigRedGrizzly 5 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted November 27, 2017 Please let us know how the plastic holds up this winter, assuming you get snow to plow! 3 Share this post Link to post Share on other sites
ebinmaine 79,601 #3 Posted November 27, 2017 30 minutes ago, KC9KAS said: Please let us know how the plastic holds up this winter, assuming you get snow to plow! 2 Share this post Link to post Share on other sites
Adams94 1,071 #4 Posted November 28, 2017 This is probably the last year for my wear bar. That looks good 1 Share this post Link to post Share on other sites
Eric Friedrichsen 112 #5 Posted December 2, 2017 I have a 1/2" x 4" vinyl wear bar on my 48" plow and using it all of last winter on a 450' asphalt driveway there was no perceptible wear and also no scratching of the driveway. Before i mounted the vinyl edge I planed a chamfer on it with my carpenters wood plane so it would have an edge at the proper angle. I have found it to be much better than a steel edge. Eric 1 Share this post Link to post Share on other sites
