cearles 0 #1 Posted November 27, 2017 Where could I get a Left Steering linkage for my first Wheel Horse tractor? Model-T1058 Serial # 216958? I will also need a carb for the K301S, Spec 97482d, S# 6370915. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,849 #2 Posted November 27, 2017 Welcome to the forum. Is it possible you have a model 1056? 10 = engine horse power 5 = 3 forward speeds with electric start 6 = 1966 model year Garry 1 Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted November 27, 2017 @cearles to Try http://www.wheelhorseforum.com/forum/141-wheelhorse-parts-and-more/ from our vendors section. 2 Share this post Link to post Share on other sites
WHX?? 53,357 #4 Posted November 27, 2017 On the carb quite a few of us get the cheap knock off carb commonly found on Many here have had good results with them. Just search on k301 carburetor and you should find hoards of them. Double check to make sure you order on with the correct choke lever/configuration. A K301 will be a 12 HP but the tractor model number you gave suggests a K241 or 10 HP. No matter carb is the same, somebody did an engine swap? 1 1 Share this post Link to post Share on other sites
953 nut 63,068 #5 Posted November 28, 2017 We do have one expectation of all new members. 1 Share this post Link to post Share on other sites
