CX519 11 #1 Posted November 26, 2017 So. I threw a rod in my Kohler K301s. Tractor is down. But, with a little research, the service manual, and guidance from Norman at www.isavetractors.com, I managed to tear it all down to the block. She cleaned up real good. All of it. But the crankshaft is questionable. I will be sending the block, crank, and camshaft out for machining. Looking for a replacement engine...i.e. something more modern. What type and model will fit for a replacement for the K301s? I will update pics in a bit. Share this post Link to post Share on other sites
953 nut 63,920 #2 Posted November 26, 2017 Any K 241, K 301, K 321, K 341 or M 10, M 12, M 14 or M 16 would be able to be transplanted without much problem. If you go with the "M" series some wiring modifications will be needed. 1 hour ago, CX519 said: replacement engine...i.e. something more modern. In my opinion the "K" and "M" series have proven themselves for generations and pound for poundare better than "modern" engines. 1 Share this post Link to post Share on other sites
CX519 11 #3 Posted November 26, 2017 Thank You for serving. My family and I are very thankful. 1 Share this post Link to post Share on other sites
