JohnnyO64 4 #1 Posted November 20, 2017 Hi all RS fans, I’ve been looking all over RS for info and help on a rear electrical actuator install method for my tiller on my C120. I’m getting to old to lift manually, but would love to fab a setup myself. If anyone can lend a hand with sharing info or some past experiences that would be great. Any advice, steps or vid postings would be appreciated!! Thanks, John Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted November 20, 2017 You might click on the topic of today :1961 Wheel Horse Suburban Followed me home to get freshened up has an interesting hoist for the rear.... Share this post Link to post Share on other sites
JoeM 9,016 #3 Posted November 21, 2017 (edited) Hey John I know what you mean about lifting the tiller. I made up a bracket that bolts to the top of the axle, uses the bottom axle mount and comes up under the fender. I mounted a 12v winch on an mule drive plate and welded the mule drive receiver to the bracket. worked great on my C120-8. It is off the machine now but I can take some pics of the bracket and assembly tomorrow. Joe I even used this on my sleeve hitch, and it will go in the front if necessary. I know you wanted an actuator but just a thought. Happy building! Edited November 21, 2017 by OILUJ52 added pics 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #4 Posted November 21, 2017 John ,there was a thread on using an actuator on the rear hitch in the last couple of weeks . I did one in July 2015 titled Separate rear Hitch lift . i hope this helps. Share this post Link to post Share on other sites
Skipper 1,790 #5 Posted November 21, 2017 (edited) It would be pretty easy to set up a linear actuator 12v. They come in many different lengths, and it would work just as your up/down office desk. Something like this perhaps? https://www.ebay.com/itm/6-Stroke-Linear-Actuator-High-Speed-MAX-5000N-1100LBS-12V-24V-DC/171706002685?hash=item27fa79acfd:g:c9IAAOxy0aBRpBM0 I have not tried this actuator, but it seems strong, and only needs a switch and some simple brackets to be set up. Would think if you find the right length needed, you could mount it under the seatpan, instead of the cable pull. Just an idea. Edited November 21, 2017 by Skipper 2 Share this post Link to post Share on other sites
JohnnyO64 4 #6 Posted November 21, 2017 Gents, thanks so much for taking the time with your replies!! If I do get something started I will try my best to share and add pics. A great Turkey Day to you all !! My best, John 1 1 Share this post Link to post Share on other sites
