Kenneth R Cluley 659 #1 Posted November 17, 2017 Have breakerless ignition set-up on Charger 12 , Kohler k301s, it will start and run for several minutes then looses spark and shuts off. No set time it seems random and engine not hot. If shut off key it will immediately restart and run for awhile and then again loose spark and shut off. I have tested all the components as per manual and they all check OK. Any idea what the primary voltage to coil should be on this system?. I disconnected wire to switch to eliminate possible ground issue with same result. My gut says probably the trigger but can't be sure because it tested fine with batteries and light bulb. Share this post Link to post Share on other sites
953 nut 64,006 #2 Posted November 17, 2017 Could be a little chafing on the wire from the module to the ignition switch, grounding out randomly. Share this post Link to post Share on other sites
Kenneth R Cluley 659 #3 Posted November 17, 2017 Changed/replaced all wiring and disconnected that wire with same results. Share this post Link to post Share on other sites
953 nut 64,006 #4 Posted November 17, 2017 Could be a wire behind the flywheel has come loose. Share this post Link to post Share on other sites
formariz 12,354 #5 Posted November 23, 2017 On 11/16/2017 at 7:28 PM, Kenneth R Cluley said: Have breakerless ignition set-up on Charger 12 , Kohler k301s, it will start and run for several minutes then looses spark and shuts off. No set time it seems random and engine not hot. If shut off key it will immediately restart and run for awhile and then again loose spark and shut off. I have tested all the components as per manual and they all check OK. Any idea what the primary voltage to coil should be on this system?. I disconnected wire to switch to eliminate possible ground issue with same result. My gut says probably the trigger but can't be sure because it tested fine with batteries and light bulb. Did you solve this? Share this post Link to post Share on other sites
Kenneth R Cluley 659 #6 Posted November 23, 2017 Narrowed down to stator. Figured out how to test using old neon light A/C-D/C tester. Decided to go "Old School" and put points coil on. Parts locally only cost me about $50.00. She's running now with no random shut down. Stator may be charging but I didn't check that for sure yet. Will verify when more time after Thanksgiving. 1 Share this post Link to post Share on other sites
953 nut 64,006 #7 Posted November 23, 2017 8 hours ago, Kenneth R Cluley said: She's running now with no random shut down. The stator has two parts, one for charging and one for ignition, should be OK. Since the rest of the ignition system was good you may want to offer it for sale here, lots of these systems are being used. http://www.wheelhorseforum.com/classifieds/for-sale/?do=form&d=2 Share this post Link to post Share on other sites
Kenneth R Cluley 659 #8 Posted November 23, 2017 Definitely the ignition portion was bad . That was the coil that I had broken terminal and wire issue. It worked after that but would shut down intermittently. I may just look for stator over next couple months and see about fixing in future. I need to fix driveway and ditch area on property this coming week so went with what i new would work for now. But, I did learn a lot about this type of system! Thanks to all ! Share this post Link to post Share on other sites
formariz 12,354 #9 Posted November 23, 2017 (edited) 58 minutes ago, Kenneth R Cluley said: Definitely the ignition portion was bad . That was the coil that I had broken terminal and wire issue. It worked after that but would shut down intermittently. I may just look for stator over next couple months and see about fixing in future. I need to fix driveway and ditch area on property this coming week so went with what i new would work for now. But, I did learn a lot about this type of system! Thanks to all ! When looking for a stator look for one for a Tecumseh. They are more common and a lot less expensive.Quite a few on eBay now. Good used ones usually go for around $60.00 or less.It is the same 10 amp stator as the Kohler the exception being that it usually has 4 wires instead of three .One short wire for ignition module and then three together. The middle one usually green just cap it( shut off wire to some switches) and then the other two are AC wires going to rectifier.You don't need a model # to find it. Their appearance is unique, you will see it right way specially when you type Tecumseh stator. Not a thousand to choose from like Kohler. Edited November 23, 2017 by formariz Share this post Link to post Share on other sites
Kenneth R Cluley 659 #10 Posted November 23, 2017 Thanks for info. Happy Thanksgiving to All. Share this post Link to post Share on other sites
