Docwheelhorse 2,847 #1 Posted November 12, 2017 Good Evening Gents, Picked up a 314-8 from a friend that had bought it off a local dealer about a year ago. Upon looking closer with Sparky by my side theres several "wrong" parts... front spindles, steering wheel, front wheels... etc... but who cares--it runs and drives and is a worker. Heres my issue---somewhere along the line the Magnum 14 must have quit and a Magnum 10 was dropped in. This 10 only has the 3 amp un-regulated charging with the AC lighting circuit. When running with a very good battery it just keeps on charging (yah I know... its un-regulated and suppose to) except at W.O.T it will hit 18 vdc and thats when we pulled the meter. Turn on the headlights (hooked direct to battery... A.C. lighting not hooked up) and the voltage goes to "normal range" and stays there. All voltages verified with good meter... Any Ideas? Thanks Tony Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted November 12, 2017 Have a 310-8 that shows around 16 to 17v at wide open throttle with a good battery. I've just kept using it and nothing has expired yet. 1 Share this post Link to post Share on other sites
wallfish 19,107 #3 Posted November 12, 2017 37 minutes ago, Docwheelhorse said: Any Ideas? First thing to do is to question Sparky's credentials and his working knowledge of using that meter! Second thing is to make more jokes about his consumption of all that yogart. 3rd thing is to wait for a reply from someone with more knowledge about the unregulated 3 amp circuit. Personally I would just leave the 12v DC lights connected and leave them on while running the engine. Or leave just one on depending on the amp draw from them for the concern of overcharging the battery. 1 3 Share this post Link to post Share on other sites
Docwheelhorse 2,847 #4 Posted November 12, 2017 Well funny you say that... one headlight and one taillight are burned out. Guess I could rig it so one headlight runs off battery and other off the AC circuit? Tony Share this post Link to post Share on other sites
wallfish 19,107 #5 Posted November 12, 2017 you'll need an AC light, like from a snowblower, to run anything off that AC circuit Share this post Link to post Share on other sites
Docwheelhorse 2,847 #6 Posted November 12, 2017 "you'll need an AC light, like from a snowblower, to run anything off that AC circuit" John... I could be wrong (I'll ask Mike after he finishes his Yoplait). But I dont think lightbulbs care if there fed 12 volts ac or 12 volts dc... the Briggs tractors have an AC lighting circuit and dont use fancy bulbs as far as I know. Tony 1 Share this post Link to post Share on other sites
953 nut 64,011 #7 Posted November 12, 2017 A bad ground on yhe regulator can allow voltage to go higher. Unbolt it and clean up the contact area then tighten it down. 1 Share this post Link to post Share on other sites
Docwheelhorse 2,847 #8 Posted November 12, 2017 2 minutes ago, 953 nut said: A bad ground on yhe regulator can allow voltage to go higher. Unbolt it and clean up the contact area then tighten it down. Except that in these 3 amp systems theres no regulator... there a 3 amp "un-regulated" system... I would expect them to have the potential to go to 15 or maybe 16 vdc... but this one passed 18 vdc. Tony Share this post Link to post Share on other sites
lynnmor 8,588 #9 Posted November 14, 2017 I don't know what voltmeter you have, but the new-fangled digital meters can go crazy on these old systems. I use a simple analog meter, (you know, one with a needle) on these basic systems. 1 Share this post Link to post Share on other sites
