Reuben357 1 #1 Posted November 10, 2017 I recently acquired a C195 that's in need of a belt change. The manual that came with the tractor is the operators manual. How do I get the drive belt off and put the new one on? Share this post Link to post Share on other sites
Lee1977 7,224 #2 Posted November 10, 2017 (edited) You will have to remover the seat and rear fender off to get to the belt guard. Remove the belt guard, disconnect the loop from the PTO. Edited November 10, 2017 by Lee1977 1 Share this post Link to post Share on other sites
Adams94 1,069 #3 Posted November 11, 2017 7 hours ago, Lee1977 said: You will have to remover the seat and rear fender off to get to the belt guard. Remove the belt guard, disconnect the loop from the PTO. Should not have to remove seat or fender, I have done it many times, just take the belt cover off. Share this post Link to post Share on other sites
Reuben357 1 #4 Posted December 9, 2017 Didn't take the seat or fenders off. Just removed the belt guard and changed the belt. Worked the belt under the fenders and over the tranny drive pulley and did the same on the engine end. Put the cover back on and away I went. Couldn't find an 87.25 inch belt so I went to Parts Plus and picked up an 87x5/8 and it works fine. Thanks for the help all the same. 1 Share this post Link to post Share on other sites
