richmondred01 2,319 #1 Posted November 5, 2017 I have a pair front AG tires and also front turf tires. I was wondering the thoughts and opinions of the group which I should use for pushing Snow. Ive never used the front AG tires to push snow and was wondering if any one else had. pros/cons? Share this post Link to post Share on other sites
pfrederi 19,278 #2 Posted November 5, 2017 I like to use turfs with roller chain around them. Digs in to hard packed snow ice better than ags alone would. Ags with chains would be good also. But when we get snow it tends to last so it gets packed down and icy . Down where you are it may melt off completely between storms so chains not such a big deal. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #3 Posted November 5, 2017 Just a thought, how about reversing the direction (swapped left to right) of the AGs on the front as they are not driven that may help more for steering traction ...Jeff. 1 1 Share this post Link to post Share on other sites
520hC-120 136 #4 Posted November 5, 2017 With the more fluffy and wet not frozen snow it will do you better because it will grab when you want to turn and won’t slip like the turf tires would. My 520H has turfs and I try to turn sometimes and it just slides. 1 Share this post Link to post Share on other sites
hondagod64 81 #5 Posted November 6, 2017 Last year I had turf tires on my 312-8 and was too much slipping on turns when plowing so I switched to lug tires and was much better in traction but chains would be best on all 4. Share this post Link to post Share on other sites
GlenPettit 1,718 #6 Posted November 6, 2017 Added weight on the front would be the first thing I'ld do. I have exactly the same tires as you do on the front. (1) liquid in the tires (Rim-guard is best, anti-freeze, windshield washer . . . ), (2) weight on the tires (like you have on the back ones), (3) weight hanging in front or on the front axle (chains, barbell, . . . ). With the blade down pushing, the front-end is actually very light, you need the extra weight up there for steering control, not on the 'A' frame of the plow but on the tractor but so the wheels are held down on the ground better. Your bar-lugs or chains will greatly reduce side-slippage with the added weight to hold them down. Good Luck & have fun this Winter . . . Glen 5 Share this post Link to post Share on other sites
953 nut 63,096 #7 Posted November 6, 2017 19 hours ago, pfrederi said: where you are it may melt off completely between storms so chains not such a big deal As Paul said, the majority of our snow falls when the temperature is only a couple of degrees below freezing and once plowed the driveway (paved) will melt off and dry once the sun gets to it. I have found that the tri ribs work best. 2 Share this post Link to post Share on other sites
ri702bill 10,639 #8 Posted November 6, 2017 Red: I run Ag's in the front, filled and wheel weights. Better steering than turf tires. 4 2 Share this post Link to post Share on other sites
richmondred01 2,319 #9 Posted November 6, 2017 Seems that the general idea is that the AG tires may be better. Looks like I'll try the AG tires. Share this post Link to post Share on other sites
dells68 7,499 #10 Posted November 6, 2017 3 hours ago, ri702bill said: Red: I run Ag's in the front, filled and wheel weights. Better steering than turf tires. I'm really digging the look of your tractor! That is one sweet ride. What about swapping out those turfs on the back for ags? She'd look mean! On 11/5/2017 at 3:41 PM, WVHillbilly520H said: Just a thought, how about reversing the direction (swapped left to right) of the AGs on the front as they are not driven that may help more for steering traction ...Jeff. I was thinking the same thing Jeff. Look at farm equipment that is ground driven, when using ags they are turned backwards to bite in better. Seems the same principal would apply to our tractors. 1 Share this post Link to post Share on other sites
Sarge 3,470 #11 Posted November 7, 2017 I run loaded ags/weights on front and rear on two tractors - they never slip . The big D also has ags all around , rear weights and just so much front end weight stock it never slips either - not to mention they look just plain mean... Sarge Share this post Link to post Share on other sites
Deadguy 861 #12 Posted November 14, 2017 I have reversed loaded ags on the front of one of mine, and it turns with much more grip on all surfaces than the turfs ever did. 3 Share this post Link to post Share on other sites
ri702bill 10,639 #13 Posted November 15, 2017 Dells: I did have a wide pair of ag's on the back, but was disappointed with their performance - those are ice chains on the turf tires - great grip. 1 Share this post Link to post Share on other sites
Sarge 3,470 #14 Posted November 16, 2017 RV antifreeze in all 4 front/rear ags , chains on the rear (run 'em year round) and no spinning issues . More traction than the frame can handle for sure...broke the 1277 but so far the 16Auto is holding up fine . Sarge Share this post Link to post Share on other sites
445FEBronco 13 #15 Posted November 16, 2017 I have a few sets of titan three ribs, they look much like the old Ford 8N 19X4 tires. They steer nice in the slop and dirt and do not pull sideways when plowing. 1 Share this post Link to post Share on other sites
richmondred01 2,319 #16 Posted November 16, 2017 I put the ags on. I will see how they do. Share this post Link to post Share on other sites
dells68 7,499 #17 Posted November 17, 2017 On 11/15/2017 at 12:41 PM, ri702bill said: Dells: I did have a wide pair of ag's on the back, but was disappointed with their performance - those are ice chains on the turf tires - great grip. I understand. But I've got to tell you - that's one really nice looking tractor with the ags. I've always thought they give our tractors that big tractor look! 4 Share this post Link to post Share on other sites
Sarge 3,470 #18 Posted November 17, 2017 The dump site where we're allowed to get rid of yard waste is 3/4 mile away - and at times is quite muddy . Hauling out the Agrifab mow-n-vac yesterday to dump the leaves/grass out was interesting - the whole area out there was full of mud . The front/rear ags and rear chains did fine - had to drag another guy's CC mower out pulling a very small trailer of debris , the Horse never spun a wheel . Sarge 3 Share this post Link to post Share on other sites
