Adams94 1,069 #1 Posted November 5, 2017 The hood on my 520-8 almost hits the ground when I open it, what is a good way to fix this? Thanks Share this post Link to post Share on other sites
stevebo-(Moderator) 8,527 #2 Posted November 5, 2017 Your missing the small pin in the front tach a matic. 3 Share this post Link to post Share on other sites
grinchsr 647 #3 Posted November 5, 2017 Part #101850 Hood stop rod 2 Share this post Link to post Share on other sites
Mal(Pa) 73 #4 Posted November 5, 2017 I don't know if your 520 is like my 310 but when I had the hood off ,it opened too far when I put it back on and it turned out that I had switched the steel brackets that bolt to the hood and the rod goes through as a hinge around by mistake.Please excuse my Dutch as I described it. Mal Share this post Link to post Share on other sites
Adams94 1,069 #5 Posted November 5, 2017 (edited) Thanks guys i will look at it and get that rod ordered! Edited November 5, 2017 by Adams94 Share this post Link to post Share on other sites
Al C. 1,428 #6 Posted November 5, 2017 This is the solution I used. Cost nothing and it is very effective. 1 Share this post Link to post Share on other sites
c-series don 9,966 #7 Posted November 5, 2017 Looks like you already have the solution, put a 5000W generator on the front!!! 1 Share this post Link to post Share on other sites
Adams94 1,069 #8 Posted November 5, 2017 1 hour ago, c-series don said: Looks like you already have the solution, put a 5000W generator on the front!!! That does work! but the hood hits the generator haha and when it goes back to mowing duty the hood stops on the mule drive and wth nothing on the front it will almost touch the ground Share this post Link to post Share on other sites
Adams94 1,069 #9 Posted November 7, 2017 The hood stop rod is missing! I ordered it last night! Share this post Link to post Share on other sites
fast88pu 3,370 #10 Posted November 7, 2017 I did this. With a piece of cable. 1 Share this post Link to post Share on other sites
Adams94 1,069 #11 Posted November 7, 2017 49 minutes ago, fast88pu said: I did this. With a piece of cable. Looks like that works good! Share this post Link to post Share on other sites
