Mjhinno 15 #1 Posted November 4, 2017 (edited) Pretty sure this qualifies, though I'm new to WH. Friend sent me a picture of this for sale on the side of the road, deep in a rural neighborhood where he lives. A couple of phone conversations and a visit and it was in my trailer. Have tractor with about 650 on Hobbs, big DR lawn/leaf vac, WH trailer, extra deck wheels, 4 gas cans, 25 foot 6" diameter remote vac hose with hand wand. New turf tires, motor with "rebuild" work done. Everything works. Removed seat, rear fender, and tunnel covers to clean and grease everything. Greased all steering gear and deck points. Pulled starter solenoid and emery'd the bore (was sticky), cleaned air filter, runs like a champ.Guesses on what number a great deal would be on these? Can anyone help with exact year? I'm thinking 1990-1992? Link to pictures Edited November 4, 2017 by Mjhinno 10 Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted November 4, 2017 Nice score there. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #3 Posted November 4, 2017 The 4 numbers stamped on the last line of the ID decal 9235? Garry 1 Share this post Link to post Share on other sites
Mjhinno 15 #4 Posted November 4, 2017 (edited) Yes Sir-9235. And thank you for the downloads! Edited November 4, 2017 by Mjhinno Share this post Link to post Share on other sites
Achto 30,887 #5 Posted November 4, 2017 (edited) Great looking tractor Careful, are know to multiply. Before you know it you'll have a barn full Edited November 4, 2017 by Achto Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #7 Posted November 4, 2017 Thank you. Not the best parts list but all we have Another handy one when the need arises When you use the model number to search for more info understanding the O's, o's and 0's helps. 41-20OE01 20=engine horse power O=Onan engine E=Eaton hydro transmission 01=numbers=parts list identifier Garry Share this post Link to post Share on other sites
Cee245 852 #10 Posted November 5, 2017 1 hour ago, Mjhinno said: Guesses on what number a great deal would be on these? Are you asking how much would be a good deal for your package you got? Share this post Link to post Share on other sites
Mjhinno 15 #11 Posted November 5, 2017 (edited) Yes I was asking what would be considered a good deal. I bought it at $1,100. I have original operators manual part# 810619R1 with a pretty good wiring diagram at the end. Would it be helpful if I scan it and PM it to one of the moderators in PDF for them to publish? Ha--never mind! Just had the chance to download the one gwest_ca sent me and it's the same Edited November 5, 2017 by Mjhinno Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #12 Posted November 5, 2017 Around here you might get locked up for horse "stealing", and by that I mean you got a great deal for the package, the DR itself is still probably a grand alone then the ... Good luck and enjoy your new found toys ,Jeff. 1 Share this post Link to post Share on other sites
Mjhinno 15 #13 Posted November 5, 2017 2 hours ago, gwest_ca said: Thank you. Not the best parts list but all we have Another handy one when the need arises When you use the model number to search for more info understanding the O's, o's and 0's helps. 41-20OE01 20=engine horse power O=Onan engine E=Eaton hydro transmission 01=numbers=parts list identifier Garry Thanks very much Garry. Know if ring gears are still available for this motor? Have not pulled it yet, but grinds like all getout when starting 1 Share this post Link to post Share on other sites
Cee245 852 #14 Posted November 6, 2017 At 1100? That is a really good deal around here too. Someone wants 4k for a 97 520h with only the deck which is imo WAY TO HIGH. C Share this post Link to post Share on other sites
Mjhinno 15 #15 Posted November 6, 2017 Can anyone point me in the direction of a ring gear for this buggy? Haven't opened it up yet, but starter grinds like metal recycler Share this post Link to post Share on other sites
ericj 1,579 #16 Posted November 7, 2017 1 hour ago, Mjhinno said: Can anyone point me in the direction of a ring gear for this buggy? Haven't opened it up yet, but starter grinds like metal recycler you can buy just a ring gear and replace it on the flywheel, I have found 2 of the onans I have that someone apparently didn't tighten the starter up and broke the boss on the block where the starter mounts, causing the starter to move and chew up the ring gear and starter drive gear. Something you may want to check. At this point I haven't had either block repaired yet, A little short on $$$$ to have fixed. A friend says he knows where I might be able to get fixed, hopefully get then repaired soon. good luck p.s. check onan parts.com or boomer's influence for the parts you need eric j Share this post Link to post Share on other sites
Mjhinno 15 #17 Posted November 7, 2017 (edited) Hey Eric. Yes thanks I will check that. Starter has been replaced by previous owner and I saw that the solenoid was loose, one bolt of improper size holding it on cockeyed. I removed it, emoried the bore, and found two metric bolts to attach it. Starter seemed tight but I did not specifically check Edited November 7, 2017 by Mjhinno Share this post Link to post Share on other sites
Mjhinno 15 #18 Posted May 10, 2018 Has anyone found an aftermarket bagger that attaches and works reasonably well for this model? Share this post Link to post Share on other sites
Mjhinno 15 #19 Posted June 2, 2021 On 11/6/2017 at 7:48 PM, ericj said: you can buy just a ring gear and replace it on the flywheel, I have found 2 of the onans I have that someone apparently didn't tighten the starter up and broke the boss on the block where the starter mounts, causing the starter to move and chew up the ring gear and starter drive gear. Something you may want to check. At this point I haven't had either block repaired yet, A little short on $$$$ to have fixed. A friend says he knows where I might be able to get fixed, hopefully get then repaired soon. good luck p.s. check onan parts.com or boomer's influence for the parts you need eric j So, just rereading this old post and a busted mounting boss was exactly the problem! I JB Welded it together and then drilled a hole in the base mount plate and ran a jack bolt up against the starter right at that boss to support it. 4 years and still holding 1 Share this post Link to post Share on other sites
seuadr 489 #20 Posted June 3, 2021 4 years is pretty good lasting power! Share this post Link to post Share on other sites
