Tankman 3,528 #1 Posted November 4, 2017 (edited) See lots of decent 12” 5-lug wheels, priced decent. Are any other garden tractor wheels a match for our Horses? Correct offset? Edited November 4, 2017 by Tankman Share this post Link to post Share on other sites
pfrederi 21,231 #2 Posted November 4, 2017 To be sure you have adequate clearance you need 1-3/8 inch back set. Many other brands (JD) use a 2-3/8 back set. Depending on your model the 2-3/8 may work if you do not want chains. Hydro fans can be a problem with the deeper backset however depending on your tire size 3 Share this post Link to post Share on other sites
Tankman 3,528 #3 Posted November 4, 2017 Thanks. Guess I could use 1” spacers if needed. FYI. Mrs. born in Binghamton, NY but lived in Montrose, PA. Foggy AM’s lately here by Allentown! Share this post Link to post Share on other sites
Achto 32,845 #4 Posted November 4, 2017 (edited) I borrowed at set of 23x10.50 ag's on Cub Cadet rims from a friend for my Raider 12 ( so I could participate in a plow day) . I liked the look and the 10.50's did not stick out of the fenders much more than the 8.50's did with the rims. Here's a pic with one of each wheels. With both 10.50's Edited November 4, 2017 by Achto 5 1 Share this post Link to post Share on other sites
andyk 83 #5 Posted November 4, 2017 The rims from my old Bolens 850 bolted right up.they looked identical. 2 Share this post Link to post Share on other sites
littleredrider 409 #6 Posted November 5, 2017 I have a set of cub cadet rims on my 520, and is incredibly close, and will rub if air is too low. On my (g/f's) tractor I put some serious diggers on it, and the lugs rub. Can't get the hubs to break free so gonna get a set of automotive spacers. Tho the rims do have the proper offset. I got a set of rims off a grounds keeper type thing, and fit perfect. Share this post Link to post Share on other sites
dtallon 320 #7 Posted November 5, 2017 I run John Deere rims on my C-160 Auto for mowing and "Bronco 12" full-time. I like the look of the tires pulled in closer, and they take up just a little less storage space that way. On the C-160 I have Carlisle 23x10.5-12's on rims made for 8.5's. The narrower rims pull the tire in just enough to clear the hydro motor by about 3/4". It probably wouldn't work with wider rims. Figuring this out was purely accidental. They came on a Deere I had for a while, and I put them on the C-160 to try and it worked. For plowing, I put on 23x8.5-12 Firestones on Wheel Horse rims to allow more space for mud buildup. The picture of the Bronco is deceiving, but there is a little over an inch between the tire and the hydro motor with 23x8.5-12's. Now that I think about it, the rims on the Bronco were originally off of a Montgomery Wards, but the backspacing was the same as a Deere. Dave 2 Share this post Link to post Share on other sites
