carlosking450 161 #1 Posted November 4, 2017 hi friends i need a gas pump for depression, mine after changing membrane and cleaning discs do not send gas Are there new pumps or some type of electric pump? Share this post Link to post Share on other sites
Sarge 3,470 #2 Posted November 4, 2017 Rebuild the old pump or use an electric low pressure Facet . http://www.then-now-auto.com/product-category/fuel-pump-kits/kohler-fuel-pump-kits/ Sarge 2 Share this post Link to post Share on other sites
pacer 3,179 #3 Posted November 4, 2017 Carlos, Yes the fuel pumps can be a headache. I install an electric one right away on anything I buy, then no worries about getting fuel. These two I show here are the types I use and are readily available here in the states through ebay - usually under $25 2 Share this post Link to post Share on other sites
953 nut 63,916 #4 Posted November 4, 2017 Be sure to mount the pump lower than the tank on the tractor so it will work best. Also, be sure to put it on a fuse protected circuit that is turned on and off with the key. 2 Share this post Link to post Share on other sites
carlosking450 161 #5 Posted November 4, 2017 3 hours ago, pacer said: Carlos, Yes the fuel pumps can be a headache. I install an electric one right away on anything I buy, then no worries about getting fuel. These two I show here are the types I use and are readily available here in the states through ebay - usually under $25 You can use the ebay link to buy the smallest pump, to hide it better,thanks¡ Share this post Link to post Share on other sites
