HENRYG 34 #1 Posted November 3, 2017 Hi all need some help with ignition switch, the switch has 3 prongs a S a M and one that appears to be grounded to the housing which prong is the kill to the rectifier the schematic shows the switch having only one wire Thanks Henry. Share this post Link to post Share on other sites
Zeek 2,286 #2 Posted November 3, 2017 If you look at this post http://www.wheelhorseforum.com/topic/68587-551-suburban-electrical-help/?tab=comments#comment-649126 You may find what you need. There is a diagram several posts down that shows the switch and lettering. 2 Share this post Link to post Share on other sites
953 nut 60,685 #3 Posted November 3, 2017 3 hours ago, HENRYG said: the switch has 3 prongs a S a M and one that appears to be grounded You don't have the correct switch. Should have two terminals, one of which is grounded. The "S" would be to the starter and you have a push button for that. Get this one, it will do the trick for you. https://www.ebay.com/itm/Ignition-Key-Switch-Ariens-Exmark-Simplicity-Snapper-Troy-Bilt-NEW-2-Position/271744327867?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p20551 1 1 Share this post Link to post Share on other sites
HENRYG 34 #4 Posted November 3, 2017 So does the grounded one go to the rectifier to kill the engine Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,560 #5 Posted November 4, 2017 No not the rectifier. It goes to the ignition wire which may be on the same panel as the rectifier diodes. Garry 2 Share this post Link to post Share on other sites
